Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 10-30-2004, 10:53 PM   #1
ardenrj
ardenrj's Avatar
Profile:
Generator for air conditioner
I have a 2004 19' CCD Bambi with an 11,000 air conditioner unit. I'm wanting to buy a Honda generator. Would the 2000 unit power the air conditioner?
ardenrj is offline   Reply With Quote
Old 10-30-2004, 11:02 PM   #2
dmadam
Profile:  1983 34' Limited
Henderson , Nevada
It would be a little tight on the power. To be sure you will need to know the amps used by the air conditioner. Also realize that an AC takes considerabely more to get the compressor started and I think that 2,000 may not quite do it. Look at the specs for the AC unit to find the amps then multiply amps X Volts (110) to get the wattage needed for the air conditioner.
Good luck
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 10-31-2004, 12:00 AM   #3
jordandvm
jordandvm's Avatar
Profile:  2005 28' International CCD
1977 Argosy 22
Western , Oregon
Images: 58
We have a 22' 2004 with 11,000 BTU AC, and had to buy a Honda 3000 EU.....super quiet and economical (not to purchase) to operate. Paid about $1600 for demo floor model with 5 hrs on it. But it comes in handy when you need it. Just make sure you have some help to load it in your PU (Weighs about 130 lbs empty)!
Jim & Cheryl
2005 28' CCD
1977 22' Argosy
2004 Chevy Avalanche 2500, 8.1L 4.10 rear axle
Prodigy brake controller/Equalizer hitch
Honda 3000 genset
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 10-31-2004, 12:06 AM   #4
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
You can put 2 2000s in par or buy a single 3000. A single 2000 most likely will not be kind to the compressor at startup.
I've seen 2000s on eBay for about $700.
Old 10-31-2004, 03:51 AM   #5
hmsteader
hmsteader's Avatar
Profile:
Rivet Generators & Power Ratings
You might want to check out this Web site. Its an Ohm's Law caluator. Its really easy to run the numbers.
http://www.angelfire.com/pa/baconbacon/page2.html
Hope this might help.
hmsteader is offline   Reply With Quote
Old 10-31-2004, 08:25 AM   #6
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
Looks like your unit will draw a little over 1900 watts at startup, pretty close to the edge for the 2000.
Old 10-31-2004, 11:49 AM   #7
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
I can tell you first hand that one eu2000 will not start the 11k AC. compressor. I tried this experiment about two weeks ago very briefly, and indeed, the AC does require a substantial amount of juice for start up. The AC and the generator just sort of choke.
You would need 2-2000's hooked up in parallel or one 3000. Do a search on parallel or honda and you willl come up with loads of info.
The 2000 is a great unit, and easy to schlepp around.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 10-31-2004, 04:08 PM   #8
Silvertwinkie
Aluminut
Darn...and I was hoping one 2000 would fire up our 15k BTU Penguin.
how to install a new air conditioner Steve Wong Furnaces, Heaters, Fireplaces & Air Conditioning 29 03-24-2007 12:09 PM
Armstrong Air Conditioner Kurt & Eve Furnaces, Heaters, Fireplaces & Air Conditioning 23 09-21-2004 08:00 AM
Rear Air Conditioner Wiring cooperhawk General Motorhome Topics 3 07-11-2004 10:00 AM
Air Conditioner Draft w9det 2001 Safari 11 09-01-2003 11:01 AM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 11:21 AM
