We just finished our 2nd trip in our Argosy. The first night was great but the second night we lost power. It only has a single 24 type battery. I tried to recharge via the connection to the truck but no luck. I have seen some threads that suggested a 27 type battery or perhaps 2 batteries. What about a small generator just to run the basics? Any suggestions will be greatly appreciated.
Thanx Jim
What do you cconsider the basics? Water Heater? gas or Electric? AC? lights? ....
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years! http://Michelles-Adventures.US
You most likely ran out of battery because you used your furnace, it is a big draw. Without the furnace you should be able to go several days on one battery. A larger battery would increase your battery life somewhat and two batteries would double it. I have a Honda eu1000 generator. It is very light and very quiet. It will run the basics and charge your battery. It will not run a microwave or an AC unit. It works well for me.
Everyone agrees that a Honda 2000 or 2 will do just about anything they need. BTW 2 is what you'll need if you want to run A/C.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom
"I'm not an expert. But I did sleep in an Airstream last night."
I was not plugged into shore power. The basics would be lights,waterpump, perhaps furnace fan. Water heater and furnace are gas.
The furnace can be a large battery consumer. Add that to the lights, waterpump. T.V. and anything else you may use, it does add up quickly.
You may also have a weak battery. Make sure you have it charged fully with a battery charger (my preference). The vehicle connection just doesn't do much for charging batteries. Your converter may when you're plugged in, depending on type.
Here's a good link for everything 12 volt, including batteries.
Have you ever tried to lift an EU3000i? 2 EU2000i are much easier to carry around and gives you a spare in the unlikely event one of them should ever die.
One EU3000=25Amps Two EU2000=33Amps available.
Michelle
Sarah
I have not lifted a 3000. What I have now is about 125lbs and loud. I think I like the idea of only one unit... the 3000 looked like it would work and be quieter.Steve
According to Honda. THe EU3000is is 134 lbs. Light enough?
Michelle
Sarah
A honda 3000 puts out about 24 amps max. It will not run everything on a 30 amp circuit. It will run most Ac's It wouldn't start the compressor on my 91 AC until I had a extra starting capacitor installed. Also with altitude, and as temps climb, generator capacity gets lower.
