Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 03-24-2007, 11:09 AM   #43
Waynon
Waynon's Avatar
Profile:  1986 34' Excella
Generator Hour Meter
Originally Posted by davidz71
Waynon,
It sounds like you did your homework. I'd now suggest you mount an hour meter on each generator so that you get equal work out of each.
Well, that's a great idea. I almost bought the hour meters, but couldn't think of any reason to other than just curiosity or re-sale, and I don't intend to do that.
I think they said they were about $50 ea. Sometimes I miss some pretty obvious things. smile
Waynon
Waynon is offline   Reply With Quote
Old 03-24-2007, 11:47 AM   #44
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Waynon
There are a couple reasons, first they keep track of hours for routine manintance; second, they also have rpm gauges. Mine came with it installed as part of the propane conversion. Good idea I think.
on edit: this tacometer helds to set the fuel mixture at the optimal level.
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 03-24-2007, 03:16 PM   #45
Waynon
Waynon's Avatar
"Good idea I think"
I'll get them ordered as soon as they open again.
Waynon
Old 03-30-2007, 09:05 AM   #46
Swanny
Swanny's Avatar
Profile:  1990 34' Excella
Windcrest , Texas
Hour meter resource
Any suggestions on where to purchase a pair of hour meters? Thanks
Texas Streamer
1990 Excella 1000---34'
WBCCI #18303
2005 F-350 Diesel 4 X 4
Swanny is offline   Reply With Quote
Old 03-30-2007, 10:28 AM   #47
Cracker
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
Is the extended run gas tank a Honda accessory? When I bought my pair of Hondas I don't recall anything like that being available. Same for the hour meters.
Cracker
Cracker is offline   Reply With Quote
Old 03-30-2007, 12:37 PM   #48
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
FWIW, I bought a Yamaha 1000 propane generator for the basics and couldn't be happier with it.
Old 03-30-2007, 05:58 PM   #49
Gen Disarray
Lawton , Oklahoma
US Carb
Try engine meter and tachometer
Rodney
Old 03-30-2007, 07:57 PM   #50
Waynon
Waynon's Avatar
Hour meter and gas tank
I bought all my "stuff" from Wise Equipment (they are in Schaumburg, IL). The hour meters are available from them and I can't say enough good things about them. (I am difficult to please) My only problem with them is that they only ship FedEx and I had unpleasant experiences with them the previous week in getting my new AC delivered. However, this went very smoothly, guess it was just one of those once-in-a-while things.
The gas tank is not a Honda branded item. But it is well made and works fine. I didn't want to get up in the middle of the night to play with re-filling the gen tanks.
I was very well pleased with this whole transaction. If you're going the Honda route I think you'd be happy with this family owned business. Owner's name is Ed. Daughter answers the phone and does the paperwork end. Very nice people.
Waynon
Old 04-03-2007, 10:53 PM   #51
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Look up Sendec hour meter on google or on ebay. I bought my Sendec, which looks like the Yamaha one on the earlier post, off ebay last year.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-04-2007, 07:05 AM   #52
Phil Gobie
Phil Gobie's Avatar
Profile:  1977 31' Sovereign
Miami , Florida
I bought from Wise also and it was a great experience!
Phil Gobie is offline   Reply With Quote
Old 04-05-2007, 05:56 PM   #53
safarijim
safarijim's Avatar
Profile:  2007 28' Safari SE
Fresno , California
I am also, looking at the Honda EU 2000ia for my 2007 AS Safari 28'. I want to be to charge the batteries and dry camp when needed. If I am reading this correctly I should be able to run everything but the A/C? Also, if I get the battery connection kit, will it charge both batteries? I think I just need to get the 15amp male to 30amp female connection to connect to the AS? I am very new at this and need a little help and wisdom.
Thanks!
Safari Jim
N6QYV
GMC 2500HD Diesel
"The Older I Get - The Better I Was..."
safarijim is offline   Reply With Quote
Old 04-11-2007, 09:52 PM   #54
davidz71
davidz71's Avatar
Thanks!
Jim, the 15 amp male to 30 amp female dogleg connector is all you need to run your converter/charger and everything but the A/C.
Craig
AIR #0078
3.73 rear end
Old 04-15-2007, 08:09 AM   #55
Krazyjohnny
Profile:  2007 27' Safari FB SE
McKinney , Texas
You can always install a pair of 6 volt golf cart batteries in series to extend your battery life. I have gone a whole weekend on a pair running the furnace and other 12 volt stuff. They bounce back very well after a deep discharge. Sams has some by Interstate battery and Gander Mountain and Bass Pro sells some by Trojan. the Trojans would be my choice if you can find them. These batteries have a much higher amperage rating (not cca). Look them up on the web for the exact figures.
Krazyjohnny is offline   Reply With Quote
Old 04-15-2007, 10:40 AM   #56
ScottW
ScottW's Avatar
Profile:  2007 30' Classic
Hernando , Mississippi
I bought my 2000i from Mayberry...good folks and competitive on price. Also got an hour meter. Good investment. Plan on another 2000i soon and will then get the parallel kit and a second hour meter. Need to keep 'em even. Hour meter is also good to plan maintenance.
Rgds
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 06:31 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 10:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 09:47 AM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 09:51 AM
Take this Generator and Stuff It..... kzener40 General Motorhome Topics 8 07-24-2002 08:30 PM
