Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 02-13-2007, 07:37 PM   #15
Ambie '64
Ambie '64's Avatar
Profile:  1964 28' Ambassador
Phoenix , Arizona
I guess a rule of thumb is not to buy any generator too heavy that the wife can't get out of the truck bed, nor too light that she could heave at you.
Ambie '64 is offline   Reply With Quote
Old 02-13-2007, 07:40 PM   #16
DreamWeaver
Profile:  1976 31' Sovereign
St Petersburg , Florida
Good Point!!
DreamWeaver is offline   Reply With Quote
Old 02-13-2007, 08:01 PM   #17
Wallygator
Profile:  2006 28' International CCD
Walden , New York
Being in charge of our shows fleet I know a few things about generators since that’s where we get our power three 350 KVW Caterpillar units, between moves I personally don’t own a generator Most here use one EU 2000 Honda will run everything but the A/C and its quite . As for the battery you can upgrade to a 27 group easy enough I squeezed a 31 group in my old trailer and last year in Boston I ran my furnace for 10 hours one cold night no problem you want to look for amp hour or cold cranking amp rating on the battery ,better manufactures are higher a good 27 group will be around 700 cca a 31 group around 1000 cca I would also recommend changing the battery every 3 to 5 years depending on how much you discharge it . If I were to buy a generator it would probably be a small EU 1000 to keep the batteries charged and the TV on. good luck
Walter
Wallygator is offline   Reply With Quote
Old 02-13-2007, 09:49 PM   #18
SnorkyII
SnorkyII's Avatar
Profile:  2008 22' Safari
Escondido , California
I have a Kipor 3000 which is a copy of the Honda. It will barely run the AC on my Safari. It is also heavy! If I had it to do again, it would be 2 of the 2000i units.
Sam
Snorky II
Escondido, CA
WBCCI #2055, VAC
Charter Member FCU, WBCCI Unit #004
ESCAPEES SKP 58345
AIR #13642
08 Safari Sport 22, 03 Toyota Tundra
73 Argosy 22
SnorkyII is offline   Reply With Quote
Old 02-13-2007, 10:09 PM   #19
ScottW
ScottW's Avatar
Profile:  2007 30' Classic
Hernando , Mississippi
For what it's worth...I just ordered a Honda eu20001 w/hourmeter. I plan to order another one w/parrallel kit when it gets warmer. It's the only way to go.
rgds
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-13-2007, 10:22 PM   #20
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Used two this summer boondocking 4th of July weekend. Ran one on propane and the other on gasoline. Nice not to refuel the propane unit, as I had it hooked to a 140 lb tank in my truck bed!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 02-13-2007, 11:07 PM   #21
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Originally Posted by DreamWeaver
Is anyone using a 3000? Or are 2 2000's really the way to go.
Steve
We went with Yamaha EF3000iSE/B, rated at 3000 watts/25 Amps and with the boost function (Thats what the "B" stands for in the number ID) it puts out close to 3500 watts. It is heavy at 151.8 lbs, but does come with wheels. It is very quiet and some say it is the quietest of all of the Inverter gens on the market. It runs a 15000 btu A/c without a skip and everything else at the same time except the convection/micro if the A/C is in the start up mode.
If portability is important, meaning you have to take it out of the TV, get 2 Honda 2000s. We keep our 3000 in the bed of the truck and simply plug it into the 30Amp circuit on the AS with our factory supplied cable. We like the long run time (3.5 gallons gets us in excess of 10 hours and sometimes as much as 18 hours) and the electric start that allows remote start/stop. The weight does have one advantage, not too many loosers will be "walking off" with the generator without a lot of work.
The extra wattage and the blue color is why we took the Yamaha over the Honda, so there is always some emotion in the decision.
TIMEMACHINE is offline   Reply With Quote
Old 02-14-2007, 01:06 AM   #22
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
In Winter I use a Honda 1000 to top off the batteries. Light and quiet.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 02-14-2007, 06:38 AM   #23
rseagle
rseagle's Avatar
Profile:  2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Buy 2 items:
1) Honda EU-1000 generator
2) Book: Managing 12 Volts
Managing 12 Volts - Camping World
Smart 12V power management is essential while boondocking. Make the most from your charge.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
WBCCI# 1430
AIR# 4749
rseagle is offline   Reply With Quote
Old 02-14-2007, 06:59 AM   #24
Phil and/or Sue
Phil and/or Sue's Avatar
Profile:  1983 31' Excella
1973 31' Sovereign
Ellijay , Georgia
Images: 68
Originally Posted by rseagle
Buy 2 items:
Seems like an excellent suggestion! While I am not doing boondocking yet, I am learning that a change from day-to-day house living is needed: you do not need video games and TVs every hour of the evening.
Spare the battery for essential items, such as light when needed, and furnace power if needed. Or refrigerator if that is on battery.
At least that's my impression. I do have a heavy generator myself in prep for off-line use, but it will probably be mounted in the back of the truck.
Phil and/or Sue (with Gus, Penny and Roger)
(Buffett RIP 9/15/08)
1983 31' Sovereign
1973 31' Sovereign (project)
'01 Dodge Ram 2500 Quad LWB 2x4 6sp
Cummins Turbo Diesel
AIR 1753
Phil and/or Sue is offline   Reply With Quote
Old 02-14-2007, 07:17 AM   #25
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Congrats. You will like the Honda.
I made my own parelleling kit for about $50 using high end stuff. If you are electricly inclined look at the wiring digram for the generator that will tell you all you need to know.
Michelle
Think you are having a bad day? Go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 02-14-2007, 07:25 AM   #26
flitzwhopper
flitzwhopper's Avatar
Profile:  1976 24' Argosy 24
Tempe , Arizona
I have a Honda EU-2000. It will run the AC unit if that is the only 110V draw - just barely. I did it for most of last summer in Phoenix without any problems with the AC unit.
FYI
MIke
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 02-14-2007, 09:10 AM   #27
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
Another advantage of the E2000i is it has a port to plug in to charge your trailer battery.
Sooo, two E2000i's one parallel kit, and one battery charging adapter. I have run our 2000 for several hours on a tank of gas, and that was at nearly full load, so it is still easy on gas. A log chain (big chain) locked through the handles, and tongue of the trailer, will help keep all but the most determined would-be "borrowers" from helping them walk off. The generators weigh around 60 pounds or so each.
Old 02-14-2007, 04:25 PM   #28
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Buy 2 items:
The book MAY be a good purchase but before you buy, check out this site. He has a very extensive article on various 12 volt issues.
The 12volt Side of Life (Part 1)
If that doesn't answer your questions, spring for the book.
Dave
Fyrzowt is offline   Reply With Quote
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 06:31 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 10:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 09:47 AM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 09:51 AM
Take this Generator and Stuff It..... kzener40 General Motorhome Topics 8 07-24-2002 08:30 PM
