Old 02-12-2013, 11:21 AM   #1
Mooresville , North Carolina
Generator 20 amp fuse keeps blowing
I recently purchased a Yamaha 6300 inverter generator to power my 31 ft. Sovereign. I run power from my garage (20 amp fuse) to the airstream through a combination of 30 amp extension cords and a 20 ft. heavy duty extension cord. I can run pretty much anything I want and have had no problem with the fuse blowing. When I plug just the power cord from the airstream (using an adapter to get the proper plug design) into the 120 volt, 20 amp outlet on the generator and have nothing turned on in the airstream, the fuse trips on the generator. Anyone have a suggestion on what may be causing the problem.
John
jtsanchez is offline   Reply With Quote
Old 02-12-2013, 11:35 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, maybe a picture of your generator and the adapter might help. If, on your generator, the dual 20 amp outlets are wired separately, you can't use an adapter that connects the two of them together. I use an Orange adapter that connects my my dual outlets, on my Yamaha 2400 with no problems; This might not work on yours.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-12-2013, 11:39 AM   #3
1974 Argosy 20
Kooskia , Idaho
Does the generator have a GFIC outlet on it? Is that what is tripping? I doubt it has a "fuse" which requires replacement. It may have a circuit breaker though, which trips and is reset. If it is a new generator, look in the manual to see what it has, a GFIC, or a normal Circuit Breaker.
Plug an electric heater into the Generator and see what happens. If it works, the generator is OK most likely, and some other issue is occurring.
Old 02-12-2013, 11:44 AM   #4
1974 Argosy 20
Kooskia , Idaho
Good call, I had forgot that some generators do that, and some adaptors will not work with them.
Old 02-12-2013, 01:22 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It looks from Yamaha's photos of the panel on that generator like the 20A plugs are protected by a GFCI. It may be that idroba's suggestion that it's an issue with the GFCI is correct. It may also be that there's a heavy initial load from the converter or something that the house breaker tolerates long enough for it to drop off, and the generator's breaker opens immediately.
I have to ask why you're not using the 30A output on the generator, though. Just don't have the twist-lock to 30A RV adapter?
— David
Old 02-13-2013, 06:04 AM   #6
Thanks for the comments. I realized it is does have a GFCI outlet and that is causing the problems. I'll just get the adapters and use the 30 amp. outlets.
Old 02-13-2013, 10:48 AM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
GFCI nuisance trips are almost always caused by a short between neutral and ground in the trailer somewhere. The first place to check is the breaker panel, where someone might have put in a bonding screw. If so, remove it.
