Old 12-07-2011, 03:27 PM   #1
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Generator, 2 smaller? Also, solar panel size?
I've decided that I'm going to purchase in this order: generator(s) for 2000W/portable solar set up for laptop/roof-top solar panel to keep batteries topped up.
Question #1: A dealership I talked to suggested getting two 1000W generators, so it's easier for me to lift them, and then chaining them together. Are there any downsides to doing this?
Question #2: how much actual physical space is available on the top of a 19' Safari SE for a solar panel?
TIA for any help!
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 12-07-2011, 03:40 PM   #2
More noise, less signal
Jammer's Avatar
2010 30' Classic
The main drawback is cost.
Also, 2000w is not enough to run air conditioning. You may want to do that at some point, in which case you would want a pair of 2000w generators.
Old 12-07-2011, 03:54 PM   #3
1974 Argosy 20
Kooskia , Idaho
I think the Honda 1000 weighs 29# and the Honda 2000 weighs 43 #. Not too much difference there. But two 1000's would weigh more than one 2000.
BTW, I have a Honda 1000 and like it very much. It will run anything I want and I don't use AC. it is light, small, and quiet. And yes there may have been times when a 2000 would have been better, but not often.
No real answer to the question, depends on which compromise you might like to take.
Old 12-07-2011, 04:33 PM   #4
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Thanks! I suspect he was maybe thinking it would be easier for me to lift 30# twice than 45# once? Perhaps I'll think about getting one 2000w, if I can afford it...and move to cooler regions if it gets so hot I need a/c, or make sure I'm hooked up...
Old 12-07-2011, 05:22 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Generators: How about what we did? We bought one 2000w Honda first — a Companion model with the 30-amp plug + the adapter you need to convert the twist-n-turn 30-amp outlet on the genny to a standard 30-amp female plug ($15-ish) + the parallelling cables ($40-ish) in case a buddy has another 2000w Honda so at least one of us can have AC if needed...(and therebybecome the "party trailer")... Then about a year or 18 mo. later if you still think you need another and want to have AC ability, get the 2nd 2000W (the Regular one)...
Solar Panels: There is really only room for one solar panel on top of your 19" ...it will go in front of the AC...so make that panel count! (Our factory panel is only 53watt...you can do better with an after-market installation.)
TB & Greg - Sadie Cocker & Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside AZBambi: AZBambi Décors
Old 12-07-2011, 05:49 PM   #6
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Hi TB! Yes, I think that's exactly what I'm going to do with the generator. You so smart.
I'm just trying to find out how much room is up there. I like the idea of the very thin ones that have adhesive on the back, not least because no one can see it up there, but 86" long? I'm definitely thinking of 60W or more, though, if it can be managed. (The portable set up is the necessary redundant system, as J is hosed if he can't get online for work, and thinking about it, might come third after all.)
Man. There's a lot of stuff to buy.
Old 12-09-2011, 10:16 AM   #7
moderator
Central , Mississippi
Some folks subscribe to the notion if you get a big enough generator, you don't need solar...plus, the shadow of the genset blocks the sun most of the time...
Actually, this morning I parked next to our backup generator and HAD to share this photo...
Name:	Big Generator.jpg
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 12-09-2011, 10:27 AM   #8
Foiled Again's Avatar
Virginia Beach , Virginia
Don't forget the 3000 HANDI from Honda - it's a LOT lighter than a regular 3000, but it doesn't have the electric starter. It's the old lawnmower pull thing.
It also has wheels and a handle to drag it around fairly easily. A ramp or long board and it's no big deal to get it back up in the truck bed.
Paula
VA-6 yah!
Today is a gift,
that's why they call it the present.
Old 12-09-2011, 10:30 AM   #9
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Well, no problem running the a/c there...
Old 12-09-2011, 10:31 AM   #10
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
I'll go take a look, but I don't know - I'm not really that great at starting lawnmowers...
Old 12-09-2011, 10:42 AM   #11
Wayne&Sam's Avatar
2007 20' Safari SE
Cuddebackville , NY
The Handi will start easily, but it won;t be as quiet as the 3000i.
Old 12-09-2011, 11:08 AM   #12
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
The problem with those flexible panels is that they require more surface area to produce the same amount of power as a flat panel. I think they are just like the thick film panels. The only plus to thick film panels is that they aren't affected so much by shading. They also don't last as long, they degrade quicker.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2006 F250 superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 12-09-2011, 01:53 PM   #13
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Don't discount putting a smaller, square-ish panel on top of the AC in addition to one on the roof proper.
We run one Honda 2000i every evening from dark until batteries have reached full charge and/or TV cravings are satisfied. We both use CPAP's every night so one 100 amp deep-cycle is devoted to supplying current to those and another covers lights and circuit boards. It takes two separate chargers about 3 1/2 hours to charge everything.
A second, parallel unit is deployed in we need AC and are not at a hookup. Frankly it is a noisy and expensive way to be cool, but sometimes circumstances force that choice upon us. Not having mains electricity at either the old farm nor the lake makes the generators an economic choice for us.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 12-09-2011, 06:02 PM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The 1000 is a nice, trim generator that is easy to handle. The 2000 is a handfull for me. It weighs enough when full of fuel for me to notice. I went with the 2000 because it seemed more cost effective. $850 or so for the 1000, $1000 for the 2000, plus I could add another 2000 if I wanted to use it for airconditoning. I look at the 3000 but it would not fit in our truck bed with the hard bed cover we have. I think the real advantage of the 1000 would be the size and weight if you are trying to pack it in a SUV or in the trailer. I generally just fire the 2000 up on the tailgate and seldom have to lift it.
I am just not into the solar thing yet for camping. I know people who have them to keep the battery charged in storage. I do not boondock a whole lot and when I do I am generally in a gully in the trees.
Solar Panel Question marvinr Generators & Solar Power 2 09-20-2011 04:06 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
28' Ambassador v. smaller size Airstream Nigel Member Introductions 13 01-25-2011 04:34 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
