Generator
Have any of you with these tri-fuel units run them at home on natural gas? I'm trying to figure out whether my natural gas quick disconnect and line that supports it that is used for my gas grill out on my rear deck can provide enough natural gas to operate my Ef2000iSv2. My goal is for the gen to supply enough power to run my fridge, gas furnace, and the 600 watts of power necessary for my wife's dialysis machine.
That same line supports enough gas flow to supply fuel for a 42,000 BTU fireplace and the dual gas burner on the grill to run full blast. In the past, the fireplace insert has been my backup heat source in case of furnace failure. It held the house at 65 degrees all night when it was -3 F a couple of winters ago and the furnace blower failed.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
