Old 06-13-2016, 09:48 PM   #1
2015 28' International
Ofallon , Missouri
Generator
I just ordered my Yamaha EF2000iSv2 tri-fuel generator from US Carb. Shipping and handling is free right now. Can't wait to hit the road.
mpsgolf is offline   Reply With Quote
Old 06-24-2016, 02:16 PM   #2
2018 25' Flying Cloud
Hillsboro , Oregon
I just fired mine up for the first time today. Seems to work fine, running of the propane quick connect on the trailer. Woo hoo!
Roguegaston is offline   Reply With Quote
Old 06-24-2016, 03:20 PM   #3
2016 23' International
Salem , Oregon
Converted mine with a kit from US carg over two years ago. Works great.
NoResults is offline   Reply With Quote
Old 06-24-2016, 04:55 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We've had ours for three years and love the convenience of not having to haul gasoline around with us. Just plug into the LP port on the Airstream and make power!
Bob Martel
WBCCI# 5766
Old 06-25-2016, 07:40 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Generator
Have any of you with these tri-fuel units run them at home on natural gas? I'm trying to figure out whether my natural gas quick disconnect and line that supports it that is used for my gas grill out on my rear deck can provide enough natural gas to operate my Ef2000iSv2. My goal is for the gen to supply enough power to run my fridge, gas furnace, and the 600 watts of power necessary for my wife's dialysis machine.
That same line supports enough gas flow to supply fuel for a 42,000 BTU fireplace and the dual gas burner on the grill to run full blast. In the past, the fireplace insert has been my backup heat source in case of furnace failure. It held the house at 65 degrees all night when it was -3 F a couple of winters ago and the furnace blower failed.
Jack
Jack Canavera
STL Mo.
AIR #56
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
1998-1999-2000 Excella Generator fphil Airstream Motorhome Forums 0 07-01-2002 09:34 PM
