Old 03-01-2010, 08:54 PM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Generac iX 2000 Watt Portable Inverter Generator
Has anyone had any experience with the Generac iX 2000 Watt Portable Inverter Generator?
Model# 5793
  • Max Watts : 2200
  • Running Watts: 2000
  • Engine SIze : 126CC
  • Engine Type : 4-Stroke OHV
  • Starting Method : Manual
  • Outlets : 2x5-20R 1X 12VDC
  • Circuit Breaker Protection : Yes
  • Indicator Lights : Yes
  • Low Oil Shutdown : Yes
  • Flex Power : Yes
  • Fuel Tank Size : 1.0 Gal
  • Run time @ 50 percent load : 4.7 hrs
  • Handle : Integrated
  • First Oil Included : Yes
  • Emissions certified : 49 States
  • Warranty : 2 Limited Residential ; 6 Month Limited Commercial
  • Dimensions : 22x12x18
  • Weight : 49.6 Lbs
I want something that others won't find to be too loud and something that is of decent quality ... but I'm struggling to justify the price difference between the Generac generator versus the Honda and Yamaha generators. Your thoughts and input are most appreciated.
Frank&Mike is offline   Reply With Quote
Old 03-01-2010, 09:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I don't see a decibel rating in those specs. If it was quiet, they would tell you so.
Old 03-01-2010, 09:37 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
This may not be what you wanted to hear, but it's the truth.
Model# 5793
Hi, many of us [including me] had similar thoughts about generators as you, but some have found out that the cheaper models have no real warranty [parts without labor] and parts are almost non-existant. Some copy cats claim that you can use Honda parts, but they won't fit or work. These copy cat generators are also louder. The only plus I can think about is that if it is stolen, you lost less money.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-01-2010, 09:40 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have looked at several sites that provided all the specs for the Generac 2000. None specify the decibel output while running. I would want to hear it run before buying.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 03-02-2010, 01:56 AM   #5
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
This ad says 64 db - "comparable" to the Honda. I'd spend the extra for the Honda, and know for sure what I'm getting. In fact, after seeing how well the EU2000i performed for three straight days during the recent blizzard, I just bought a Companion.
Generac Power Systems 5793 IX Series 2000W InverterGenerator
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 03-02-2010, 04:21 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The Honda EU200i is rated at 59dB at full load, 53 at 1/4 load. The Generac is 64dB - but is that full or 1/4 load? It's at least 5dB louder, maybe as much as 11dB.
Perceptions of Increases in Decibel Level:
Imperceptible Change 1dB
Barely Perceptible Change 3dB
Clearly Noticeable Change 5dB
About Twice as Loud 10dB
About Four Times as Loud 20dB
Old 03-02-2010, 07:03 AM   #7
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
The first question you need to ask is how much power do you need? If 900 watts will met your needs (enough for a small microwave or battery charging) look at the Honda or Yamaha 1000.
I decided on the Yamaha for my small generator because it's lower dB rating, 47-57, noticably quieter in the campgrounds then the ubiquitous Honda 1000 and 2000's. About $750
snake is offline   Reply With Quote
Old 03-02-2010, 08:25 AM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I noticed on the Generac web site that it had a "flex power" feature, hi or lo. The Honda has the "eco-throttle" that is load specific. I would suspect the Honda would be much quieter and also that the engine in the generac is made by ?. A gen is only as good as the engine and my experience with Honda engines is that they run forever with just reasonable attention. An the start with ease.
Old 03-02-2010, 08:30 AM   #9
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I wonder what loud means in this table? A db is a mathematical relationship ship between two quantities. This table attempts to express this in qualitative terms.
The blue font is a quote:
"For instance, suppose we have two loudspeakers, the first playing a sound with power P1, and another playing a louder version of the same sound with power P2, but everything else (how far away, frequency) kept the same.
The difference in decibels between the two is defined to be
10 log (P2/P1) dB where the log is to base 10.
If there are two sounds sources and the second produces twice as much power than the first, the difference in dB is: 10 log (P2/P1) = 10 log 2 = 3 dB."
It sure seems to me that twice the power out to be more than barely perceptible.
Is my logic going wrong somewhere?
Ken
Old 03-02-2010, 09:06 AM   #10
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I think Id stay with Honda or Yamaha. This may be a relatively new Chinese engine. Not sure. I have not seen this one yet. I have worked on Generac engines and parts can be a problem.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-02-2010, 10:58 AM   #11
Frank&Mike's Avatar
Georgetown , Texas
A sincere "Thank You" to each of you for your input and thoughts. I needed your thoughts on this subject to help me justlify the extra $$$. I'm convinced ... now I guess I need start my search to find the best deal on a Honda or Yamaha. I think I need at least the 2000 because I'll need it to power more appliances ... I assume it will power an Air Conditioner if nothing else is running????
Old 03-02-2010, 03:00 PM   #12
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
The man in the suit prefers Hondas
... I think I need at least the 2000 because I'll need it to power more appliances ... I assume it will power an Air Conditioner if nothing else is running????
Mike,
I think you have received good advice on brand-name selection. Unfortunately, a 2000 watt generator will not run most air conditioners.
While you will find a bedazzling number of threads on this forum about what is best, the man in the suit suggested I point you to this particular web page for more insight.
Tom
Old 03-02-2010, 03:38 PM   #13
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Our 2000i Honda will do the microwave, but NOT the AC!!!
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-02-2010, 07:16 PM   #14
Frank&Mike's Avatar
Georgetown , Texas
TomW ... thanks so much to you and The Man in the Suit for the advice (every time I see the photos of him in his suits it brings a smile to my face). Especially seeing him all decked out ready to camp.
I decided this afternoon that if we are boondocking ... then who needs air conditioning, right? As long I have some water to shower ... So I opted for the 2000 Watt.
The generator overview you wrote is very helpful ... and entertaining to read. I called everywhere today, googled websites, etc. I found a local Yamaha dealership that offered me the best price I found anywhere ... so tomorrow I pick it up. Now I'm going to be figuring out how to run this piece of equipment. Wish me luck!
Portable Generator Marks Generators & Solar Power 38 11-04-2017 08:36 PM
Husky 5000 Watt Generator The Flintstones Generators & Solar Power 18 09-27-2008 10:44 PM
1975 Argosy 20 Generac Generator Info Needed 911rs Generators & Solar Power 1 06-29-2007 01:38 AM
