06-03-2014, 09:13 AM
2004 16' International CCD
Chicagoland
GenConneX Propane Conversion for Honda EU2000i
I'm seriously considering converting my Honda EU2000i from gasoline to propane. For those of you who've dumped gasoline any regrets? For those of you who've considered LPG but not gone for it, why not?
If I make the switch I plan to use the GenConneX conversion. I really like how well-engineered the unit appears to be. I love how the unit maintains the factory appearance. I've worried about tearing off the external kits.
Honda Eu2000i Propane Kit
Here is a video review of the system:
What do you generator gurus have to say about all of this?
06-03-2014, 10:02 AM
2012 25' FB International
Trent Woods
, North Carolina
I have the same Yamaha that I bought converted to trifuel and I have converted a larger generator to trifuel with a different kit. This installation looks a little more complicated as you are actually removing everything that is gasoline, but I do like the clean look when you are finished.
The one possible drawback is that you have eliminated any possibility of using gasoline if you cannot get propane to the generator. I like that fallback position, but it plan C and I may never need plan C. I can run my generator off the trailer's low pressure propane connection.
Larry
06-03-2014, 10:10 AM
Port Hadlock
That really looks like a neat installation. I've seen the one with the external mount and I just can't make myself add that to the outside of my generator. While this one is a lot more money, I might go this way.
06-03-2014, 11:41 AM
Wise Elder
2010 30' Classic
South of the river
I don't use a generator in large measure because of concerns about fuel handling.
That's the nicest propane setup I've seen.
06-03-2014, 12:27 PM
Princeton
, New Jersey
I like that kit and the fact that the regulator in inside.
I converted my Honda 3000i to trifuel with a Central Maine Diesel kit. On the 3000i the regulator had to be mounted on the outside. I was told by CMD that they do not convert the 3000i because of time it takes. However I devised a method of mounting the regulator that was very quick. I did have to cut the fuel stem on the carburetor supplied because of space limitations.
While I retained the ability to use gas I will never use it. Propane/natural gas is the way to go.
2004 Excursion 4x4
06-03-2014, 02:53 PM
2012 27' Flying Cloud
W
, New England
Real noob question - but with that conversion, why would you use a separate 20lb tank? Would there e a way to connect to (in my case) the two 30lb tanks on the a frame?
06-03-2014, 03:02 PM
Princeton
, New Jersey
Once converted you can hook up to any propane fuel supply you want to.
You can connect directly to one of your tanks with a Tee connection. You could connect after the high pressure regulator. Depending on which you choose you may need an additional high pressure regulator.
If I connect to the Nat Gas at home I can tape directly to the house system feeding directly to the conversion regulator.
2004 Excursion 4x4
07-07-2016, 05:33 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
I started another related thread, which may provide some additional insight. It's specifically asking about connecting a propane-fired generator to the low pressure port that comes standard on many Airstream trailers now: http://www.airforums.com/forums/f448...se-153363.html
07-07-2016, 06:35 PM
W
, New England
Funny to see my reply 2 years ago knowing that earlier this year, I just converted my 2 Hondas to the Genconnex which I can connect to the low pressure port or tanks directly. 😀
07-07-2016, 06:37 PM
Luminous
1983 27' Excella
Vesuvius
, Virginia
Can 2 2000s still generate enough wattage to start a 15k AC, given the loss in energy density with propane?
Steve
83 Excella 27
07 Tundra Limited
07-07-2016, 06:43 PM
W
, New England
They definitely start and run a 13,500 - I don't have a 15,000 so I can't answer that for sure.
07-07-2016, 07:00 PM
Green Cove Springs
Haha, yeah, I accidentally brought this thread back to life, forgetting it was 2 years old.
07-07-2016, 07:17 PM
2006 25' Safari
St. Augustine
I would go with this one because you still have options of Gas, LP OR Natural Gas
http://www.motorsnorkel.com/motor-sn...-kit-3437.html
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
07-07-2016, 08:15 PM
Green Cove Springs
Excellent point, though we love the elegance and simplicity of the internal propane / natural gas conversion.
07-07-2016, 08:46 PM
2016 28' Pendleton
Scottsdale
Hi from AZ. . . just got my 2 Hondas w/propane from Genconnex today. . . Our new Pendleton will be my 1st with 50 amp power, & these are my 1st generators. . . . sure hope I can figure this all out when we get to Pagosa Springs next week. . . Be careful out there, Craig
WBCCI 2851,4CU
07-07-2016, 09:18 PM
W
, New England
If you have two 2000s, I think the only thing you want to watch out for is to run only one of your AC units on generator power.
The Genconnex conversion is very clean and the Pendleton is a really beautiful trailer. Have fun!
07-08-2016, 11:31 AM
Green Cove Springs
To put this thread back to bed, here's what we bought: http://www.genconnexdirect.net/honda...g_packages.htm
Scroll down to Package RV2. It should be perfect for us, ready to go, easy as pie.
As rodsterinfl noted above, this is a pure propane solution - no gasoline with this conversion. That's fine with us, though others may prefer a tri-fuel product. Thanks!
07-14-2016, 12:45 PM
2008 25' Classic
Full Time
I'm thinking going with just the standalone Honda 2000, $1499. It comes with the 6ft hose. I don't have a low pressure LP port on my 2008 Classic so don't need that hose that comes with the packages. I can do without the cover and I may just modify a plug for internal ground or purchase one from Progressive Dynamics if I feel I need one. I'll have to pick up a quart of Mobile 1 from my local automotive store and a small funnel.
Kelvin
07-17-2016, 11:16 AM
2008 25' Classic
Full Time
Rocinante, have you received your generator?
Kelvin
07-17-2016, 03:13 PM
Green Cove Springs
Kelvin
UPS says the package is in my town and they will deliver it tomorrow evening. I'll report as soon as I get it up and running.
