Old 09-04-2016, 02:49 PM   #15
2014 25' FB International
2014 Interstate Ext. Coach
Indianapolis , Indiana
See our post about this issue here: http://junebugjourneys.com/2016/03/3...tor-gastapper/
The Gas Tapper is a FANTASTIC addition to our boondocking supplies.
OurJuneBug is offline   Reply With Quote
Old 09-04-2016, 02:55 PM   #16
Lkjdude's Avatar
2015 25' FB Flying Cloud
Nebo , North Carolina
BERG fuel extender.
I am new at this so hang on.
I purchased a BERG fuel extender. The dual feed, which will feed 2 Honda generators. You can get a single feed also.
It works great and was easy to set up. It will feed two Honda 2000 generators for over 24 hours. The fuel tank holds 6 gallons and each generator holds approx 1 gallon each. The tank also has a no spill screw in cap, and quick disconnect.
The fuel tank is plastic. So are the tanks in the generators. So are the ones in most TV's.
I have seen gas cans burn and LP tanks explode. I think one must be as careful as possible and I think this is a choice which (as you are doing) you educate yourself and make a choice. For me the BERG system seemed the best as you can also use the gasoline in the TV if needed.
Lkjdude
Lkjdude is offline   Reply With Quote
Old 09-04-2016, 03:03 PM   #17
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
WARNING: I learned early on on these forums that syphoning is not a good idea. To get the flow going you'd need to somehow suck the gas through a tube like in those mad max movies. Only one problem: this is likely to either kill you or make you quite ill.
I carry a two gallon plastic gas can that I fill up when I get close to destination. Between a full tank in gen and the two gallons that gets me through three to four days and thats with running it several hours per day.
If there is any gas left in the can on moving day, that will get pour into tow vehicle tank. At home I leave the can outside to help evaporate any residual in hopes of avoiding old gummy gas.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 09-04-2016, 04:01 PM   #18
Boxite's Avatar
2008 22' Sport
I've got a non-vented (capped-off) 5 gal plastic gas can I carry externally in the bed of the truck and replenish the generator from that. It has also come in handy on one occasion when I ended up in the boonies and very low of TV fuel...just poured it in, and VOILA!... there's another 75 miles!
But what concerns me are the comments about the bad "smell".
WHAT smell? I certainly HOPE no one is carrying this stuff inside a passenger vehicle compartment!
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-04-2016, 04:16 PM   #19
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Originally Posted by Wayne&Sam View Post
We went with propane and like it. We already have two thirty pound tanks with us, so why carry gasoline
Same here. So far we're happy with our propane-fired Honda EU2000i. If you don't already have a genny, that's worth considering vs. a gasoline-fired unit.
Rocinante is our 2014 International Signature 27FB
Old 09-04-2016, 04:28 PM   #20
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
I carry my sealed can in the van wedged securely between something, again last leg of travel.
If you smell gas, something is not right. Either a leak or loose cap/cover, both not good. Also drive with as many wondows opened as possible.
Old 09-04-2016, 04:54 PM   #21
Lkjdude's Avatar
Correct
Crazylev is correct. I don't like the taste of gasoline. That is why I purchased the BERG system. All you do is fill up the generator, attach the air tight cap supplied for the generator and the hose. As the gasoline is used out of the generator tank, the suction created in the generator tank pulls the gas out of the 6 gallon tank. Works great, no mess.
If you want to suction it your self, don't smoke!
Lkjdude
Old 09-04-2016, 06:20 PM   #22
2005 19' Safari
GLENDALE , AZ
We use this to fill our Hondas: Flo N Go MaxFlo Siphon Pump - Amazon
After siphoning, it is stowed inside the propane cover until the gas fumes dissipate.
Old 09-05-2016, 09:16 AM   #23
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by Sav'h Steve View Post
My next door neighbor just bought the new 3500 max duel fuel inverter at just a couple hundred more thru Cabella's. Wt just over 100 lbs. Too heavy for me. He plans to leave it in the truck bed.
Weight is surely a consideration and I think leaving it in the truck is a good option for sure. A camper across from us earlier this year had a Honda 3000 in his bed, mounted on foam of some sort, to arrest the noise. He used the siphon method from a 10 gal tank he had mounted on his rack. It was very quiet. The DB rating of the Champion unit is rated same as Honda. Leaving in bed most of the time may be a great option, assuming the noise is not an issue. I know another camper had a regular portable generator used for construction in his bed with cover over it, and it was extremely loud when he ran it. I don't want to be one of those noisy campers, so having the ability to move it around without much hassle is a plus. I was able to lift and move my neighbors Champion duel fuel, when we tried it out on my AC earlier, as it pulls with the wheels and handle easily. I lifted it and seemed like around 85 lbs; could be heavier; specs say 93 lbs, but did not feel that heavy.
Old 09-05-2016, 08:07 PM   #24
2016 30' Classic
Houston , Texas
Thanks for the discussion. I decided to go 100% propane - sent my Honda EU2000i to GenConnex to have them do the internal conversion as I didn't want the propane conversion equipment attached externally to the generator. My 2016 AS Classic has two large propane tanks with a convenient propane port near the trailer's tongue. So, the decision was part convenience, part safety.
dhroberts is offline   Reply With Quote
Old 09-06-2016, 08:08 AM   #25
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Just a thought that I have not seen mentioned, should you stay with gasoline that is, if you live in a part of the country where non-ethanol fuel is available consider using that. If not ( I don't) you should try to keep the fuel fresh by using it frequently either in the generator or mower or your gasoline tow vehicle. The point is that the ethanol fuels do not have a very long shelf life and best to try and keep it fresh. NOW, that being said, should you go to a propane conversion I think you will not be sorry.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-06-2016, 12:14 PM   #26
Rivet Slave
Rocinante's Avatar
Gasoline supply for generator: To can or not to can?
That's exactly where we got our propane-fired EU2000i. So far, we love it, hope you do too!
Originally Posted by polarlyse View Post
...if you live in a part of the country where non-ethanol fuel is available consider using that.
Out here, the local Grange sells gasoline without ethanol. That seems ironic since the grange is focused on serving agricultural folk, but we suspect it's because sometimes that gas sits around in farm equipment between uses and ethanol in that gas would only bring sadness for the reasons you mentioned. So, for the large gasoline-powered generator we leave at home (too big and noisy for camping) and use when storms knock out power, we also add "Sea Foam" stabilizer to the Grange-sold ethanol-free-gasoline. Sea Foam is a product designed for marine use to help keep that ethanol-free gasoline fresh. There are, of course, other gasoline stabilizers out there, and they probably work fine too.
Old 09-06-2016, 01:15 PM   #27
gypsydad's Avatar
Gas being sold in local hardware/feed store?
Not sure if you have seen this yet, but I noticed in Murdoch's in Helena MT, 1 gallon cans of "VP Small Engine Fuel" (ethanol free gas), for sale $17.99, on shelves by the Honda generators... Propane is looking better and better! LoL
Old 09-06-2016, 01:41 PM   #28
2015 16' Sport
Portland , Oregon
she don't lie, she don't lie, she don't lie ... PROPANE!
leedav is offline   Reply With Quote
Gasoline Generator to Propane NoResults Generators & Solar Power 21 04-28-2016 03:25 AM
Help! Transporting gasoline for generator,where, Suburban and AS, no open truck. airdreamers On The Road... 37 11-03-2014 09:33 AM
Gasoline Can For Generator Fuel PARKS1963 Generators & Solar Power 9 08-12-2006 08:14 PM
gasoline smell after fill-up Astrodokk General Motorhome Topics 2 10-19-2004 04:54 PM
