Old 04-24-2016, 09:55 PM   #15
2016 30' Classic
Bend , Oregon
Send a message via Skype™ to synapticon
Concern about conversion to propane
Is there a concern of the higher ignition temperature of propane (920-1020 F) vs. gasoline(475-536 F)? Apparently these conversions are not recommended by any manufacturer and can void the warranty. Does it damage the engine?
synapticon is offline   Reply With Quote
Old 04-25-2016, 05:36 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
No...
1. Storability,*Propane does not go bad and can be stored indefinitely. Modern gasoline, on the other hand, has a shelf life of only a month or two without stability additives, and even then cannot often be stored longer than six months before degrading.
2. Cleanliness,*Propane is not spilled like gasoline when refueling. It is estimated that Americans spill 17 million gallons of gasoline each year refueling small engines. This represents an environmental hazard as well as a safety hazard, since hot engine parts can cause spilled gasoline to catch fire.
3. Reduced Emissions, Propane burns much more efficiently (around 90-95% efficient) than gasoline and produces less carbon monoxide and other greenhouse gases. Propane does not evaporate like gasoline, so the evaporative emissions are reduced as well.
4. Extended Engine Life,*Propane has less BTUs of energy per unit than gasoline.*While this means that it takes more propane than gasoline to power an engine, the advantages are that less energy is wasted in combustion of propane. Engines run on propane run cooler, which means less stress on internal engine parts and extended engine life.
5. Extended Service Intervals,*Propane does not gum up over time like gasoline, because it is a gaseous and not a liquid fuel,*so carburetor problems are not an issue. Propane combustion does not produce excess carbon and gunk like gasoline, and so propane engines typically have a longer interval between oil changes.
6. Portability, *Propane in the disposable cylinders is easier to transport than gasoline.
7. Adaptability, Mixture adjustment, altitude compensation.
Nine years & counting...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-25-2016, 08:23 AM   #17
2016 30' Classic
Bend , Oregon
If all your points are true, and I'm in agreement on these, why does a conversion void the warranty and why don't Honda and Yamaha offer conversion kits? Seems like a no-brainer with the advantages of propane. Odd that this point hasn't surfaced in this forum. In the Q&A at Power Equipment Direct they give a lengthy warning implying engine damage. Clearly you haven't experienced this damage. Maybe it's a CYA statement where they are concerned with "certification" for emissions compliance.
Old 04-25-2016, 11:55 PM   #18
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
Originally Posted by ROBERT CROSS View Post
No...
hey Bob, got any close up shots o your mounting??
use two holes and spacers?
Does your line to tank have a regulator to step down pressure?
twolanehwy is offline   Reply With Quote
Old 04-26-2016, 12:14 AM   #19
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I did the GenConneX propane only conversion of both of our Honda 2000 watt generators. The entire conversion is installed inside the case of the generator so there are no new external parts to get broken off the unit. They both started on the first pull after the assembly process.
We can carry one generator unit inside the Mercedes when towing the 23D and have no gasoline fumes inside the car from a gasoline can or the generator gas tank. I have the choice of carrying my spare 20 or 30 pounds propane tank, or on a short trip, just connect to the front propane outlet on the hitch (of either) trailer. We have their special regulator with two hoses to be able to run both units off of the 30 pound propane tank when taking the truck and Classic.
The first conversion took me about 90 minutes as I double checked each step. The second took about 45 minutes as I was familiar with the process.
Old 04-26-2016, 06:20 AM   #20
Thumbs up
Yes..three mounts & spacers w/washers..two on top, one on the bottom.
Better pic of the lower mount...POI...the foam doughnut keeps the dirt out
Yep..
Storage...
PFC
"Tahawus"
RLC
John Prine
Old 04-27-2016, 05:23 PM   #21
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The Yamaha conversions performed by USCarburators does not void the three year Yamaha warranty according to USC because they are licensed by Yamaha to do the work. I just got off the phone with them to verify this. I am looking at their EF24iSHX YAMAHA GENERATOR converted unit. Price is basically the cost of the generator plus $185 for the installed kit. Free shipping and no tax. Interesting info, they say run the new generator for a minimum of two hours on gas before using propane. I was hoping to totally avoid using gas at all.
MICHAEL
Old 04-28-2016, 03:25 AM   #22
Long Island , New York
Thanks for this info. Michael. Here is the Yamaha 1000 available complete for $1071.19.
http://www.yamaha-propane-natural-ga...m/ef1000is.htm
Comparison of the 1000 vs. 2000:
https://www.yamahamotorsports.com/ge...20091d7ca01773
We are considering the 1000 for our FC20 to save on weight (27.9 lbs. vs. 44.1 lbs.). Its only function would be to keep the batteries topped off (7.5 Amps rated AC current).
Thanks again,
Peter
PS -- I will also post this in the following Honda 1000 vs. 2000 thread:
http://www.airforums.com/forums/f448...0i-147804.html
Help! Transporting gasoline for generator,where, Suburban and AS, no open truck. airdreamers On The Road... 37 11-03-2014 09:33 AM
Gasoline Can For Generator Fuel PARKS1963 Generators & Solar Power 9 08-12-2006 08:14 PM
Gasoline prices myoung Dollars & Cents 5 02-09-2006 07:47 AM
gasoline smell after fill-up Astrodokk General Motorhome Topics 2 10-19-2004 04:54 PM
