03-10-2013, 11:19 AM
Foothill Ranch
Flexible Solar panels... Opinions?
I did a search here and found the Unisolar stick on panels.
Did not find anything about this style that are on an aluminum substrate.
Its says they can be walked on...
100W 200W 300W 400W 1000W Semi Flexible Solar Panel RV Boat Portable PV Panels | eBay
I was thinking, rather than having the clunky heavy flat panels, add some of these with some, say 1/2 sheet type insulation under them.
This would protect them from the rivets, add an extra layer of insulation to the roof, and make it smooth and integrated looking.
Opinions on the solar panels output etc, and the idea?
I was thinking about getting just one to start with as a test...
What would be a good size in term of output that would NOT need a controller, and charge my 2 6v batteries during storage her in CA?
10w, 20w, 50w?
03-10-2013, 11:36 AM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
If you install solar of any useable amount you will need a controller as you expand the system, especially where you are located. So I would say include in your plan a controller.
Those panels look interesting for your application. You could mount them off center and leave a walk/work path at the top of the roof. Where are you getting these panels?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
03-10-2013, 11:45 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
I believe these are the same panels that Unisolar did/does offer in a frame also. They have a flexible plastic covering instead of the usual glass.
If that is the case i have had 3 32 watt frame mounted ones in service since 2000 and they work fine. (also using 2 75 watt conventional in the system)
If you are planning anything above 15 or 20 watts I would agree that you should use a controller. Might as well get something in the 20-25 amp range if you are permanently mounting your system you will undoubtedly want to expand on it later.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
03-10-2013, 12:49 PM
Foothill Ranch
I knew I need a controller for larger panels/wattages, but wondered what the safe cutoff wattage was for a smaller panel for now.
If these panels are just the same panels as the roll out ones, maybe I could get those and build onto an aluminum sheet... that way I could totally custom build to suit the shapes and spaces I have.
Either way, it would require a lot of planning.
I have done a dimensioned plan of the roof, so I know what space I have where.
Just do a search on Ebay for "Flexible Solar Panel" and there are a lot of suppliers and diferent sizes. The come is many shapes and wattages.
I saw some semi ridged 1/2 foam insulation somewhere, and I thought if I planned carefully, I could have a neat solar instalation that would barely impact the look and aerodynamics, but help with roof insulation too.
03-10-2013, 01:00 PM
1994 30' Excella
Mississauga
, Ontario
search ebay for unisolar flexible panels. the company went bankrupt so their panels are cheap.
they have glue on the back for full contact to the roof. I picked up four for my trailer.
There is a thread on the forum from ddruker that details his install.
You should be able to fit a 144watt panel on your moho.
Al
Al and Jean
TAC ON-3
03-10-2013, 01:15 PM
Tub City
, British Columbia
The controller can always be changed or added. Just have a plan to where you are going to install it. As close to the batteries as possible. Leave enough wire so you can insert the controller. I used 8/2 marine wire for my longest run from solar to controller. That is probably overkill, but use as big a wire as you can manage in the space allowed.
I would be concerned about the exposed insulation breaking down in the sun??? Good idea if you can make it work.
You have more sun than me, but I have 40W polycrystaline panels on both the #1 and #3 battery banks without charge controllers.
http://www.airforums.com/forums/f313...ml#post1107521
I do have the ability to reinstall the controller on the #1 bank if I was parked in the desert. All my batteries can be tied together or separated as needed for solar, or any charging.
Dave
03-10-2013, 02:11 PM
Tub City
, British Columbia
One other concern with that panel is that it may not have blocking diodes and would then require a controller to avoid backfeed.
Most older panels and larger panels had the diodes, but I see some of the newer ones are not equipped with them as they are designed for use with controllers which incude diodes as part of their construction.
Diodes can be installed in line, if you needed them.
http://www.airforums.com/forums/f463...ml#post1120972
Dave
03-10-2013, 05:44 PM
Cranbrook
, BC
I have very similar flexible panels on my trailer. I bought them from Amazon two years ago with a solar controller. They are both 20 watts and we can now boondocks for several days without worry. Mind you, our trailer is small and the only electrical is lights, water pump and stereo so we don't have a lot of draw. We mounted the panels on the roof but did not adhere them directly to the surface. We used rubber grommets so that there would be a small space under the panel. Then we fastened the panels (through grommets) at the corners and halfway down each length. We wanted to have the spacers to ensure no water got trapped under the panels and so that they could be removed if necessary in the future. We apply a UV protective wax to the top of the panels a couple of times each year to keep them in good shape and to help grime from building up.
We couldn't be happier with the panels. I would post pictures but the trailer is all wrapped up in its winter cover right now.
03-14-2013, 01:21 PM
Foothill Ranch
Would love to see some pics Alumacoach!
My master plan would start with having 4 x 6v Golf cart batteries... I have just 2 now..
Later, by relocating the chassis battery, I have space for 8..
When I buy a controller, it would need to have enough "headroom" to handle adding extra panels and batteries..
Suggestions?
05-04-2014, 09:21 PM
1974 31' Excella 500
Roy
Just wondering if you did go ahead with these panels? If yes - report? If no, did you go with something else? - Cheers!
05-16-2014, 09:59 AM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
I was just down at my dealer in Penticton and was talking to a couple who were picking up their new 25ft and as he was leaving he mentioned he had solar installed.I was curious as I couldn't see the panels and he said they were a new panel made by GPElectric, called Solar Flex,and marketed through Carmanah.It looked like a very clean install and the three panels he had all fit very neatly over the front bedroom.They can apparently be either screwed down,or stuck down with special tape.
Has anybody else heard of these or used them yet?
George
05-16-2014, 10:48 AM
Refugee from Napa, CA
2015 25' Flying Cloud
Formerly Napa
, On the road
They look like a great idea...
05-16-2014, 12:09 PM
Naples
Flex solar panels, while a great idea, are not quite ready for prime time. We have been testing some from various makers, and have found several problems:
• the panels get extremely hot as they are bonded to the roof and have no way for cooling air to flow under the panels
• due to the extreme surface heat, the panels tend to cup in a concave fashion ever so slightly, capturing morning dew and the associated dirt....they are extremely hard to clean when this happens.
• the biggest problem, which is also heat related, is panel over heating. As solar cells heat, they loose efficiency. With no way to cool down, they can reach surface temperatures of up to 160ºF, which can reduce the output by as much as 50%, making your 100 watt, $600 flex panel essentially a 50 watt, $600 flex panel. That 1000 watt output specification was measured at 'standard test conditions, or STC, which is a lab figure calculated at 77ºF and assuming 1000 watts/sq. meter. Not a real world measurement!
•*as stated above, real cost per watt output is still several multiples of flat mono crystalline panels.
As I said, when the construction and cooling problems are mitigated, they will be a great panel........JUST NOT YET!
lewster
05-16-2014, 12:14 PM
1974 Argosy 20
Kooskia
, Idaho
Lewster is completely correct in his evaluation. Cooling is a big issue.
05-16-2014, 01:26 PM
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
So, have you tested these particular panels or are you lumping all flexible panels together?
George
05-16-2014, 03:36 PM
1994 30' Excella
Mississauga
, Ontario
I have no numerical data. But I have four amorphous silicone flexible panels glued to the roof of my trailer. Each is 68 watt potential output. In full sun in Ontario Canada they perform as rated. They also have good output when patially shaded or under overcast skies. Since the company was bankrupt the cost of the panels was very low on Ebay.
I personally like the fact that they are not proud of the roofline on my trailer.
From my experience over almost one year, they do not seem to get dirty. The roof does flex a bit when the sun is on them.(oilcanning). Could I have had more solar power on my roof; definitely. But I would have had to spend a lot more money.
From what I have read online the amorphous solar panels are much more heat tolerant than the other panels which is a good thing since these are glued to the roof and don't have the advantage of air flow under them. That is why I painted the roof of my trailer with Supertherm(a ceramic paint coating which insulates against heat gain) before adhering the panels to my roof. The trailer stays cooler in the sun than before I installed the panels.
I'll try to post a photo later.
I did post a photo previously on a thread titled show me your solar panel
Al
Al and Jean
TAC ON-3
05-16-2014, 03:41 PM
1994 30' Excella
Mississauga
, Ontario
Al and Jean
TAC ON-3
05-16-2014, 04:17 PM
1981 28' Airstream 280
Austin
I like those! How much does it pull in?
Austin
Sorry I just saw it in your post
05-17-2014, 04:46 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Here is one solution to the battery issue.
Custom stainless steel battery box for four Lifeline 6Vdc 300 amp-hour batteries adds about 350+ pounds to the front of the trailer deducting the weight of the two stock batteries. Wired in series and parallel, these four batteries are capable of 12VDC and 600 amp-hours of storage.
The original battery box was converted to the home of the Titan disc brake pump and it's electronics control module.
The solar installation used eight metal framed 100 watt AM Solar panels. AM Solar is still in testing mode for the flexible panels. Note that the AM Solar 100 watt panels are narrow enough to go on either side of the air conditioning units.
