02-24-2016, 06:05 AM
#161
Naples
Not only that, but their output is limited when compared to hard panels….especially on a curved roof surface like an Airstream.
I have been using 5 X 100 watt flex panels from Grape Solar on my Sprinter service van for 18 months and can state unequivocally that their output is, at maximum, only 55-60% of what a GS-100 hard panel produces.
Using the same physical components from my prior system when I used 5 of the GS-100 panels (Blue Sky 3024iL controller, iPN-PRO remote, 200 amp/hour lithium battery and Magnum MS-2812 inverter), the new array of flex panels only produces a maximum of 22-24 amps to the batteries, while the GS-100 panels would often show 32-35 amps at maximum output.
My flex panels are mounted to a sheet of .090 aluminum which is bonded to the roof of the Sprinter. This produced a smooth, flat surface which is also slightly elevated above the roof, as the Sprinter has raised ridges for structural stiffness, and totally free of any obstruction which enables 100% of the available solar radiance to reach the panel surface. This allows for air flow under the panels and also utilizes the aluminum base as a heat sink.
I would NOT RECOMMEND flexible panels to anyone looking to obtain the maximum efficiency and output from their solar array. These will be coming off the roof in the next few weeks and replaced with another array of 5 GS-100 panels.
lewster
02-24-2016, 09:10 AM
#162
2020 Classic 33
Box Elder
, South Dakota
Saw this in the last couple of days on the Renogy panels that are affected.
http://www.cpsc.gov/en/Recalls/Recal...-Solar-Panels/
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
02-24-2016, 10:22 AM
#163
Foothill Ranch
Does anyone have experience with a small portable Charge Controller I can use with my 35w panel? I have been moving it about between 3 different vehicles, and want to have a little charge controller to wire inline with it...
05-10-2016, 06:05 AM
#164
2004 30' Classic
Johnson City
Grape Solar vs. GoPower Flexible panels
Have heard good reviews of these two panels:
Grape Solar GS-PHOTOFLEX-100W: $250 Module eff. 17.6%
GoPower (Carmanah) GP-FLEX-100E: $500 Module eff 19.6%
Warranties seems to be the same.
What more do we get for twice the price?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
05-10-2016, 07:18 AM
#165
Naples
73/gus
MARKETING!!!!!
And don't believe those high efficiency ratings from Go Power!! They use the same SunPower cells that every other flex panel uses, so why another 2% on panels that are virtually identical.
Show me an INDEPENDENT TEST of all of the 100 watt flex panels out there and they will be within tenths of a precent of each other.
lewster
05-10-2016, 08:11 AM
#166
2004 30' Classic
Johnson City
Thanks. Any other differences in packaging, etc between the two? Cannot discern much difference in the tech specs.
05-10-2016, 12:47 PM
#167
Naples
Nope! Like I said........ marketing!!!!!
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster
05-10-2016, 11:08 PM
#168
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Not everyone has had positive experiences with the "flexible" panels regardless of brand.
05-12-2016, 09:42 AM
#169
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
So that statement would suggest that some have had a positive experience?
Those people are the ones I and others want to hear from.
George
05-12-2016, 01:41 PM
#170
Foothill Ranch
Personally, I have decided and started this thread to discuss flexible panels that bend to match the shape of AS roofs. I am glad people posted experiences, but let's focus on the positives from now on.
I want to see installations that blend in and function!
05-12-2016, 01:59 PM
#171
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Exactly. What I said. That's why I subscribed.
George
05-13-2016, 10:48 AM
#172
2009 30' Classic
Melbourne, FL
, Searsport, ME
About two years ago I installed 5-120 watt flexible panels on my 30' Classic. Despite all the negative comments I've read here, I've been completely satisfied with mine. In addition to the 600 watts of panels I installed a Midnight Solar "The Kid" controller, a 1000 watt inverter, and 2 Lifeline 6 volt batteries. I've traveled throughout the US from Maine to Florida to San Diego, the desert Southwest and am now at Yellowstone N. P. They've been through summer heat and freezing weather. Even on a streak of overcast and rainy days I've been able to keep my batteries fully maintained most days by 10:00 or so in the morning. Consider me a happy camper and a very happy solar power user. No regrets thus far.
05-13-2016, 10:50 AM
#173
1976 25' Caravanner
Kansas City
, Kansas
Thanks for the report acstokes, just what the people wanted!
Follow our shell-off renovation on Instagram @LifeIsRiveting
05-13-2016, 10:52 AM
#174
1976 25' Caravanner
Kansas City
, Kansas
Oh, and what size are your batteries? Thanks!
05-13-2016, 11:00 AM
#175
Foothill Ranch
Thanks ACStokes,
Can you post some pics of your install please????
05-13-2016, 11:19 AM
#176
2009 30' Classic
Melbourne, FL
, Searsport, ME
Thanks ACStokes,
The two batteries I installed are Lifeline 6v GPL-6CT. The first pic here shows 3 120 panels. I later installed 2 more toward the rear of my trailer. The second pic just shows how I used the refer vent to run the wire.
05-13-2016, 12:53 PM
#177
Foothill Ranch
Very nice!
Thanks for posting that!
05-13-2016, 02:24 PM
#178
2004 30' Classic
Johnson City
Very nice flexible panel install. What brand panels are they, and how did you attach them to the roof?
73/gus
2004 30ft. Classic
05-13-2016, 02:45 PM
#179
1951 21' Flying Cloud
Sacramento
Here's the two 50w flex panels from Renology we have on our '51 FC (fastened w. VHB tape). Still in the middle of the resto, so haven't got any practical experience as yet, but very happy with how the look from ground level (not visible). Keeps the original lines of the rig intact.
We're also adding a plug for portable panels for more juice when boondocking. Both the portables and the roof panels are hooked to a marine battery selector switch to disconnect one when the other is in use.
05-13-2016, 03:33 PM
#180
Biloxi
, Mississippi
Originally Posted by calais66
Here's the two 50w flex panels from Renology we have on our '51 FC (fastened w. VHB tape). Still in the middle of the resto, so haven't got any practical experience as yet, but very happy with how the look from ground level (not visible). Keeps the original lines of the rig intact. Attachment 262445
Have you spoken with Renogy about their flex panel recall? I was all set to buy several of their flex panels until they stopped selling them. They are working on new flex panels. I ended up with their 100 watt suitcase for the time being.
MICHAEL
