Old 01-07-2014, 07:39 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by goshawks00 View Post
Lew thanks for your explanation. Now I have to ask how do you adjust the angle of the panel while it's atop the airstream? From inside the trailer or is there some niffy rod or crank used from the ground? Thanks again,
Barry
Rocker mounting feet allow the panels to tilt in either direction by using AM Solar's tilt bars. This involves loosening one side of the panel and adding the tilt bar to each end. You will need a ladder to access the panels, but not a very tall one as Airstreams are one of the lowest profile RVs available.
Old 01-17-2014, 01:29 PM   #16
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
I bought a collapsing aluminum ladder to access my roof to tilt panels and whatever up there. Not cheap, but perfect for an airstream. Not terribly light either but I guess it's as light as possible since it is aluminum.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
