Old 12-20-2014, 04:52 PM   #1
ewbradshaw's Avatar
2008 27' International FB
Sioux Falls , South Dakota
Factory solar preside
Anybody know if '08 internationals came prewired for solar panels? I have a 27FB and would like to install a panel or two.
ewbradshaw is offline   Reply With Quote
Old 12-22-2014, 12:43 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My 2008 Classic 25fb has a bundle of wires marked solar in the electric box that encloses the Store/Use relay and battery buses. Check in there and if you find them your AS should be ready.
Kelvin
Old 12-22-2014, 02:08 PM   #3
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
My understanding on this issue is the pre-wired set up is inadequate for a really efficient solar panel set up and that heavier gauge wire must be pulled regardless of the factory set up. But, i am certain someone with expertise will confirm this and offer some thoughts about how to get a solar power source which meets your needs.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Factory Installed Solar Charging System SilverGate Generators & Solar Power 423 04-08-2018 08:57 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Non-Factory Solar Installation on New AS JamuJoe Generators & Solar Power 21 03-01-2011 05:52 PM
Adding a New Panel to the Factory Solar richschafer Generators & Solar Power 1 04-03-2008 09:32 AM
