Old 05-03-2013, 10:10 AM   #181
2009 34' Panamerica
weyburn , Saskatchewan
Mine is a Sunexplorer and when trailer is out in sun it says charg no number on charge amps display and on solar amp hours display it says 0. So why is it not working. Or has anybody else had this problem is there something that I need to adjust or look at. Thanks for any help.
Pedecanada is offline   Reply With Quote
Old 05-03-2013, 11:30 AM   #182
richinny's Avatar
2011 34' Classic
what is the battery voltage. the controller will only charge the batteries when the voltage drops below about 12.4 or so volts. the manual gives the exact specs.
Ricky
Old 05-03-2013, 11:49 AM   #183
richinny's Avatar
2011 34' Classic
this is the unit in my trailer...
Ricky
Old 05-03-2013, 12:22 PM   #184
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Others have had this problem, see post #103 of this thread. Things to have checked out: the charge controller, wiring, and display monitor.
SilverGate is offline   Reply With Quote
Old 05-04-2013, 12:21 AM   #185
2009 34' Panamerica
Thanks for help will check out controller next
Old 05-07-2013, 11:37 PM   #186
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
It is quite nice to have all of the wiring hidden in the interior walls from the factory ...
Old 05-08-2013, 08:49 AM   #187
Florence , Montana
New Batteries
Gave up on trying to fit 31xt batteries in my battery box, with the cables, it just seemed too tight. I think they could be jammed in, but I went the easy route and replaced them with 24t's. Followed Silver Gate's great detailed instructions and it went perfectly. Thanks again for all the help. Bill
MTStream is offline   Reply With Quote
Old 01-25-2014, 07:51 AM   #188
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Number of Panels
Originally Posted by AirSolarGuy View Post
Hi Corky,
We are the provider of all the solar modules to Airstream. Just curious, did you request them to use the GP-RV-110 solar kit? Typically, Airstream installs our 50 watt solar modules. The GP-RV-110 is a great kit and will provide you with double the power.
AirSolarGuy (Mark)
I have a 2006 Safari with factory installed solar. My configuration has only 1 53 watt solar panel and 2 AGM batteries. Could a second panel be added (of course if space is available) to the existing config and would any down stream supporting electronic devices need to be replace/upgraded?
tsunami is offline   Reply With Quote
Old 01-25-2014, 11:32 AM   #189
Ag&Au's Avatar
Port Orchard , Washington
According to his profile, The user whose post you quoted has not visited Airforums since making that post nearly a year ago. Perhaps if you sent him a private message via the forums, he may get an email of your message, or If you click on his username to the left of the post you quoted, you will see a link to send him an email. Hopes this helps,
Ken
Old 01-25-2014, 02:03 PM   #190
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Tsunami,
I think the answer to your question is that everything downstream should be fine but you should look at the solar charge controller and be sure that its rating is sufficient. When I was shopping for a new controller even the smallest ones can handlee two 53 watt panels.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-01-2014, 11:39 AM   #191
2014 28' Flying Cloud
2021 16' Basecamp
Millsboro , Delaware
My '28 airstream FC is in order with a build date of 4/1. I was all set to include the solar but dealer told me to hold off and get an aftermarket
I am still torn, I know the up charge is steep but I wonder if the peace of mind knowing it is all factory installed and covered by airstream is worth it.
I need to make final decision this week to get it included.
Dealer is working up three options
1. All factory (list is $2900)
2. factory controller and dealer installed solar panels.
3. Dealer installed aftermarket system
Those who have done all factory would you do it again?
SchuHouse is offline   Reply With Quote
Old 03-01-2014, 12:15 PM   #192
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
Hard to guess exactly what system a dealer might install so it is hard to advise. We only have a 16' Bambi but it has the factory system and it works fine. The controller Airstream uses has enough reserve capacity that I even added a connection for more panels when we are parked off grid. Works great...I would not hesitate to purchase the factory system again...especially when the warranty is nationwide. If you ever have a falling out with your dealer who will provide warranty work?
Bruce
Sent from my SM-N900V using Airstream Forums mobile app
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
Bruce B is offline   Reply With Quote
Old 03-01-2014, 12:18 PM   #193
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the factory system and like it very much. It is plenty for our conservative use (lights, entertainment system, furnace fan) with propane supplying the other energy needs (fridge, water heater, furnace heat, range). We no longer carry a generator on our frequent cross-country tours.
The factory system (includes two Lifeline AGM batteries) is expensive but it is nicely installed and covered under the warranty. Many have said it is a relatively small system and you can get more for the money elsewhere. Probably, but we like ours.
Our Airstream was in stock with all options, which we did not think we wanted. If we bought again we would have all of them as well as a ProPride/Hensley hitch installed. They add a great deal to our use and enjoyment of the Airstream. We watch our spending and managed this extra cost by buying a more basic, well-matched tow vehicle.
Although list price is $2900 you should be able to negotiate this down considerably. Unless the dealer is making a fat profit installing them.
Doug and Cheryl
Old 03-01-2014, 01:01 PM   #194
SilverGate's Avatar
2007 23' Safari SE
Yes, we would do it again!
We still have and enjoy our factory-installed solar charging system. It meets our needs during non-hookup camping (water pump, FanTastic Fans, stove fan, refrigerator fan, led lights, stereo, etc.). On most days our two AGM batteries are back to 100% by mid-morning. Even on cloudy days, some power is produced by our solar panels.
See records below made during our last non-hookup camping trip to the mountains last October. (See the full story in "Snug as a bug in a safari" and "Airstream Safari trip notes".
Name:	DSC_0017 Solar records Oct.jpg
Old 03-01-2014, 01:12 PM   #195
Ag&Au's Avatar
Silvergate,
Thanks for the post. We also have the factory solar install. however we have never used it for longer than overnight. (not much sun then )
I will be examining your log.
Ken
Old 03-01-2014, 01:18 PM   #196
2021 16' Basecamp
Bruce
That was my thought exactly Bruce.
Old 03-01-2014, 01:26 PM   #197
2021 16' Basecamp
Although list price is $2900 you should be able to negotiate this down considerably. Unless the dealer is making a fat profit installing them.[/QUOTE]
Funny thing is I intended to order when we made the deal but they suggested I wait. I will try and get them to come down, so far they have been very reasonable in pricing.
We ordered with all the bells and whistles we think we need. Awnings package, 1000w inverter, convection oven, bike racks (my wife has very high end road bike and needed a cradle) and ultraleather. Based on dealer recommendation We ordered pro pride directly from Sean but it will be installed by the airstream dealer. My inclination is to get factory solar while I still have the chance.
Old 03-01-2014, 03:24 PM   #198
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
We had an aftermarket solar panel installed by the dealer because the trailer we liked was already on his lot and didn't have solar in it yet. To be honest it didn't even occur to us that Airstream would install them at the factory. I kind of wish we had thought about that option or at least compared the two to see which would've been better, spec-wise and cost-wise. That said, while we haven't really put our solar system to a major test it seems to be working fine and charging the batteries nicely.
Even better, having a solar panel on the roof helps me win arguments against myself when I begin to wonder whether I should invest in something like one or two of those Honda 2000i generators. Our motor home had an Onan generator, of course, and we found it very convenient from time to time. With the trailer, I occasionally have to arm-wrestle myself out of buying one, mostly because I don't want to carry the extra weight and the maintenance headaches. I really want to find that with a solar panel, a proper coffee pot and enough cross-ventilation, we can easily and serenely enjoy the occasional boondocking experience. Here's hoping!
Old 03-01-2014, 03:58 PM   #199
Ag&Au's Avatar
I had the panels installed at the factory because it would be under the factory warranty. I did and still do feel like a paid too much for what I got. If I had it to do over again, I would do a bunch of research, get the best parts I could find and do it myself. I have not been impressed with the RV service work that dealers do. I would prefer to find an independent technician to do work I don't want to do.
Ken
Old 03-01-2014, 04:31 PM   #200
2013 28' International
Bozeman , Montana
We've been very happy with our factory solar option on our 28' International. I planned on buying a pair of 2k Honda generators but so far have not. The solar has kept up with our needs when boon docking. We only used our A/C one night last year with a relatively cool summer so all of our electric needs have been met with the batteries, solar and the inverter for occasional 110.
A bit of a pricy option but one of the few things that has been reliable on our trailer.
HeadWest is offline   Reply With Quote
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
Forgive my ignorance spinolio Airstream Motorhome Forums 35 01-08-2003 05:05 PM
BatteryMinder charging time davidz71 Our Community 1 12-13-2002 09:55 PM
Solar Installation cactushead 2000 - 2004 Safari 19 10-21-2002 05:56 PM
The forums private message system PeterH-350LE Forum Admin, News and Member Account Info 0 04-10-2002 12:25 PM
