Old 10-24-2014, 07:09 PM   #295
lewster's Avatar
Naples, FL , Hood River, OR
Airstream places a fuse on the positive terminal inside the junction box that is bonded to the under side of the panel.
Remove 4 screws and pop the cover off. The fuse should be in a weatherproof holder. Check there first.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-25-2014, 05:56 AM   #296
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
The fuse is good, I don't get any current flowing from the panel.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 10-25-2014, 07:41 AM   #297
lewster's Avatar
Did you check the diodes?
If they are good, then it looks like the panel shorted and is a gonner........
Old 10-25-2014, 07:55 AM   #298
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Wouldn't the diodes protect against reverse polarity? Assuming they have a high enough peak reverse rating....
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-25-2014, 09:50 AM   #299
lewster's Avatar
Not necessarily. I've seen good diodes in bad panels. He could also have a bad connection/ wire internal internally connecting the cells.
Hard to tell without being there.
Lew Farber
541-490-6357
Old 10-26-2014, 06:01 AM   #300
macofpei's Avatar
2003 30' Classic
I think the problem is a dead panel due to reverse polarity because of someone crossing the positive and negative wires, sometime before I bought my AS. I didn't know about the fuse under the panel , I thought you meant the fuse on the controller. As I have already stored Belle for the winter, this will be my spring project.
Thanks.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
Old 02-14-2015, 07:25 PM   #301
richw46's Avatar
Lexington , Kentucky
Sun Explorer Panel Question
We have a factory installed solar panel and the Sun Explorer monitor. I have replaced the original Lifeline batteries with brand new ones. Running on house AC the Sun Explorer panel, in the battery voltage position, normally shows 12.1 to 13 volts, never more. At night the battery percentage remaining, with LED lights in the overhead, is typically 75-85%, according to the Sun Explorer panel. If I turn on a light with an incandescent bulb, the percentage will drop to 65%. If I turn off most of the lights it will rise to 90 to 95% by bedtime. By morning it will 100% and 13 volts, never more.
I don't think the converter is putting out enough, or any, DC power. I would think that when voltage is below 12.5 the converter would be at 13.2 volts or higher. I've tested the voltage with a multimeter and it matches what the Sun Explorer shows.
Is it time to replace the converter???
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 02-14-2015, 07:33 PM   #302
lewster's Avatar
YES! It should have been replaced long ago and is primarily responsible for killing your Lifelines.
Also, the charging set points if your solar are not doing your Lifelines any favors either.
Lew Farber
541-490-6357
Old 02-14-2015, 10:10 PM   #303
Gary W Wong's Avatar
Milpitas , California
Thanks for starting the solar category.. I will post my information soon.
Gary W Wong is offline   Reply With Quote
Old 02-14-2015, 10:43 PM   #304
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Yes, you need to protect your Lifeline AGM batteries with at least a 3-stage converter, not with the OEM converter.
Here is how I found out:
Battery at 45% even though connected to shore power
Here is the converter that I installed that serves and protects my AGMs:
Parallax Converter Replacement with Xantrex
Not all 3-stage converters are AGM friendly:
How my Airstream lost its mojo in the carport
SilverGate is offline   Reply With Quote
Old 02-15-2015, 08:07 AM   #305
Oakland , California
You should probably think about replacing the factory installed Sun Explorer monitor and Atkinson Electronics solar charge controller, too. I suspected that the controller wasn't putting out the proper voltages to charge the Lifeline AGM batteries and it cannot be reprogrammed. In addition, the Sun Explorer monitor only uses voltage to calculate a percentage charged. It uses 12.8vdc as the point for 100%. See the spec sheet on the page 14:
http://www.atkinsonelectronics.com/m...DM4-LC-KIT.pdf
When you place loads on the battery or the controller charges the battery, you're going to get rapidly changing values for the percentage since the voltage at the charge controller shunt is also changing.
For myself, these components' way of charging and measuring battery charge were unacceptably inaccurate. I replaced the factory charge controller with a Bogart Engineering SC-2030 combined with a TM-2030 Trimetric monitor. I also upgraded the cables to my battery, and installed a thermal breaker to the controller and on-off switch to the solar panels. It was a DIY install. I left the SunExplorer panel on the wall and it is not functional. Now I can assure the solar charging has proper voltages and accurately measure the batteries' charge. (If only I could figure out an easy way to place the Trimetric where the SunExplorer was in the galley of my 2014 27FB Eddie Bauer -- has anyone done this? Please help!)
Any of the recommended replacements on these forums would be better than the Atkinson Electronics kit. Think about replacing your charge controller and monitor if you want more accurate charging and monitoring.
mikebee is offline   Reply With Quote
Old 02-15-2015, 10:05 AM   #306
lewster's Avatar
I am in the middle of a 540 watt solar installation on a 27 EB and after removing the 2 50 watt stock panels, found the Atkinson wiring in the curb side rat's nest of wires. The OEM 10 AWG solar wiring (green and yellow) terminated there as well.
The positive solar wire (too small to call a cable) was connected to the tiny solar controller with a wire nut. The red charge line from the controller then was attached to a 14 AWG fuse holder, which then went the positive bur bar.
Do you think there was just a bit of voltage drop in this system????? I am amazed that they work at all!!
Lew Farber
541-490-6357
Old 02-15-2015, 03:23 PM   #307
Lew Farber
No kidding! I had the same experience and found the wiring hub to be confusing and terrible. They used a wire nut to connect the 10awg positive solar wire from the roof to the permanently-affixed 14awg lead coming off the Atkinson charge controller. There was also a 10 amp inline fuse.
I disconnected the factory install WFCO inverter which had its own 6awg cables to the batteries. Rather than using the bus bar as originally installed, I used one of the 6awg cables to connect the new solar controller positive side directly to the batteries. A negative 6awg goes to the shunt.
Next step will be to run new cables to the roof and add more panels. Last step will be to re-install a better inverter with an upgraded set of cables to the batteries.
Now if I could only figure out how to install the Magnum inverter/charger and eliminate the Parallax from charging..... Anybody have any good pictures of upgraded installs with a magnum inverter/charger?
Old 02-15-2015, 04:12 PM   #308
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
If you go to handybob'ssolarblog and look under his 2014 solar ideas, batteries, there is a good picture of the magnum installed for a small full time trailer.
George
gandttimes is offline   Reply With Quote
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
Forgive my ignorance spinolio Airstream Motorhome Forums 35 01-08-2003 05:05 PM
BatteryMinder charging time davidz71 Our Community 1 12-13-2002 09:55 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
The forums private message system PeterH-Airstreamer Forum Admin, News and Member Account Info 0 04-10-2002 12:25 PM
