Old 02-20-2013, 06:38 PM   #169
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Images: 14
tkowalyk,
I have the factory solar (two 55w panels) and inverter in my 2012 FB. LOVE it and highly recommend it... My understanding though is that solar only charges batteries to about 80-85% true capacity and that you may want to have a battery tender ($40) for extended storage. I have one and use it over the winter to keep the batteries at full capacity.
Hibby
Hibby is offline   Reply With Quote
Old 02-20-2013, 09:44 PM   #170
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Originally Posted by Hibby View Post
tkowalyk,
Thanks Hibby. I have a battery tender already. A definite must. Do you have AGM batteries?
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 02-21-2013, 11:31 AM   #171
2007 25' Safari FB SE
Florence , Montana
Checking on Lifeline AGM batteries, I've gotten to wonder if I could replace my 24T's with a 31T. The battery box seems to have the room, the problem might be the plastic tray, but I think I could rig up a replacement. I'm pretty ignorant on the subject, would the solar charger have any problem charging the larger batteries? SilverGate, thanks for the post on changing batteries, it's really well done and extremely helpful. Bill
MTStream is offline   Reply With Quote
Old 02-21-2013, 11:35 AM   #172
Not sure who told you solar only charges batteries to 85%, that is not correct. I have one 120 watt panel and it still charges my 5 year old AGM's to a full charge. 12.85 to 12.9 volts or so. When charging it goes much higher, which it should. Maybe something is wrong with your charging system. AGM's are the way to go. I see some of the prices some are paying for panels, someone is making a killing, or worse. 600 dollars for a 120 panel? I paid 150 or so.
tkowalyk,
mrchinup is offline   Reply With Quote
Old 02-21-2013, 06:37 PM   #173
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Images: 14
I do have AGM batteries, which were standard with the factory system.
I don't remember where on the forums I read the charging limit of 85%... I also read that 95% of all statistics are made up, and I believed that too.
Although my Airstream solar charge indicator does show 100% after sitting in the sun for a day, it discharges to below 100% almost immediately when I begin using power. However, after using the battery tender, there is a noticeably longer time before the battery seems to begin discharging below 100% (2-4 hours depending on consumption).
Hibby
Old 02-21-2013, 07:20 PM   #174
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Thanks, MTStream for your comment. Carefully check and compare the dimensions of your battery box with the dimensions of Lifeline's AGM batteries listed here.
As you can see, it's a tight fit with all of the wires just using the 24T's. I personally would not want to try squeezing in the larger 31Ts.
Good luck with this.
-- Bill
Name:	DSC_0093 AGM batteries.jpg
SilverGate is offline   Reply With Quote
Old 02-23-2013, 07:06 AM   #175
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Orientation Questions to consider...
Not new to Airstreaming, but picking up my new 27 FB Classic limited this weekend.
The coach has the factory installed solar package, what should I look for during the orientation by the dealer relative to the solar system and monitor panel?
Aside from the obvious, it would be good to know from the seller basic solar details such as:
1. Stock wire size and length from PV modules to controller and controller to battery array;
2. Amp-hour consumption rates in "standby" or stored mode;
3. Proper battery storage size and PV module output and inverter size in "balance"? (look for at least 3.5A of charge current per 100AH of battery storage);
4. PV module output (nominal voltage and amperage);
5. Understand your "solar system needs" - ie: will you enjoy continuous dry camping? Or, just "long weekend" dry camping? In any case, you may want to understand how long your solar system will take to "refill" what you use each day - this depends on your projected electrical usage...
Just some thoughts. Good luck, amigo!
Art
MaxAB is offline   Reply With Quote
Old 02-24-2013, 06:54 PM   #176
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Thanks Art
Tom & Lori
Old 05-02-2013, 03:27 PM   #177
2009 34' Panamerica
weyburn , Saskatchewan
Is my factory solar system working proper
I just bought a 2009 panamerica with a factory solar system but not sure if it is works right. This last weekend we went camping and it was sunny all weekend and 80 during the day. The display say charg when I press the button 3 time which is charge amps but if I press it 4 time it say 0 amp/hours I thinks which is funny after 4 days of being in the sun. It also seem like battery did not top off during the day but since I had light plant it was no big deal but would be nice to know if it working right. Thanks for any help.
Pedecanada is offline   Reply With Quote
Old 05-02-2013, 03:57 PM   #178
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
My battery usually tops off mid-morning on a sunny day, depending how far it discharged the night before and how much power I am using at the time. Are the batteries original and still in good condition?
I have been told the original Airstream converter can overcharge and ruin the batteries if left on shore power for days at a time. The way to avoid this is to put the "Battery Disconnect" switch (usually located near the door) in the "Store" position when on shore power, and the solar system will charge the battery. Be sure to return it to the "Use" position when disconnecting shore power and hooking up to tow, or the refrigerator will not automatically run on propane.
doug k
Old 05-03-2013, 07:56 AM   #179
2009 34' Panamerica
So when solar system is charging what should display say. My battery are ok in that they can run heater all night but are low buy morning. It was cold that night around 20-30 and furnace ran a lot.
Old 05-03-2013, 08:43 AM   #180
SilverGate's Avatar
2007 23' Safari SE
Assuming you have the factory installed SUNEXPLORER display panel, each time you push its button it displays the following information consecutively: Battery % Remaining, Battery Voltage, Solar Charge Amps, and Solar Amp Hours. If you are camping without hook-ups, and the sun is shining on your solar panels, you should see the how many amps are being produced (Solar Charge Amps) and the running total of the accumulation of amps (Solar Amp Hours). When doing non-hook-up camping, I keep a log of this which you can see by clicking the Attached Thumbnail a couple of times in post #9 of this thread.
Additional note, using the furnace can rapidly deplete your batteries, and it may take longer for your batteries to recover, and you may be using too many appliances during the day.
Old 05-03-2013, 10:10 AM   #181
2009 34' Panamerica
Mine is a Sunexplorer and when trailer is out in sun it says charg no number on charge amps display and on solar amp hours display it says 0. So why is it not working. Or has anybody else had this problem is there something that I need to adjust or look at. Thanks for any help.
Old 05-03-2013, 11:30 AM   #182
richinny's Avatar
2011 34' Classic
what is the battery voltage. the controller will only charge the batteries when the voltage drops below about 12.4 or so volts. the manual gives the exact specs.
Ricky
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
Forgive my ignorance spinolio Airstream Motorhome Forums 35 01-08-2003 05:05 PM
BatteryMinder charging time davidz71 Our Community 1 12-13-2002 09:55 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
The forums private message system PeterH-Airstreamer Forum Admin, News and Member Account Info 0 04-10-2002 12:25 PM
