Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 03-07-2014, 05:04 AM   #221
Naples , Florida
Tsumani,
I would be glad to if I wasn't opening the installation center. I will be on a very tight time frame to be back in FL for Nov.1 when my 'season' there starts up again. How about a FL vacation this winter??????????
PM me if you have any other questions.
Thanks!
lewster
Old 03-07-2014, 05:17 AM   #222
Naples , Florida
Originally Posted by gmeikle View Post
Lester. Traveluminum asked for other sources. I suggested one. I never said Bob was an expert. Bob actually says he is not an expert.
I for one will listen to and read his whole blog and take from it what I want to from someone who lives totally off the grid.
I will also read other sources he has noted.
I found him a very refreshing person of knowledge to speak to who offered to help with my installation with
suggestions of where I could go to buy my equipment at retail where someone could make money.
I have even gone to the AM solar site for information and they have some good Ideas too.
Methinks thou dost protest too much.
George
George, that post was from a couple of years ago when old Bob's blog was first mentioned on these Forums and I was asked to comment…..which I did from a professional's point of view. Since becoming deeply involved in the RV solar business, I have found that there is a wealth of mis-information available on the web about any topic that you can imagine, often posted by self-styled 'experts' who happen to have a working system……..usually through no fault of their own! RV solar happens to be one of them.
My comment was not meant in disrespect to you or anyone else who posts information or links here, and I hope that you did not take it personally! Folks will glean whatever they find useful from myriad sources, including Bob. My comments were from an engineer's and working professional's perspective only. I am not a 'my way or the highway' type of guy.
Doing this every day gives me a wide overview of what works and what doesn't. I have been called upon to correct a lot of poorly installed solar charging systems (and other types of work) and have seen the direct results of poorly designed and installed system using low-end components.
My comments to this Forum are always intended to help it's members make educated decisions within their RV microcosm and to avoid the costly mistakes that I see others suffer. I hope you take them in that spirit.
lewster
Old 03-07-2014, 05:44 AM   #223
Shelly and Richard
traveluminum's Avatar
1959 24' Tradewind
Kopperl , Texas
Thanks Lewster. I am trying to learn more about solar, and you are right about all the misinformation. Through Bob's ranting, I was able to use these tips. Use the right size wire, get a good battery monitor, and follow the battery manufacturers charging instructions. I've seen all these suggestions before, but for some reason it never really got through. My thick skull probably has something to do with that. And me not wanting to spend any more money than I have to. I appreciate everyone's input.
traveluminum is offline   Reply With Quote
Old 03-08-2014, 10:25 AM   #224
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I like to wander several sites ,not only A/S to get all the information that I can on RV solar.Just came across this the other day.Thought those who are still searching would be interrested,
The Truth About Solar Power for Your RV
George
gandttimes is offline   Reply With Quote
Old 03-10-2014, 11:27 PM   #225
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Zamp Solar
So, I double-checked our dealer-installed solar system. It's a 150 watt system from Zamp Solar with a Model ZS-30AP controller. They installed the panel, the controller and the requisite wiring.
You experts out there, let me know what I've got here. Good? Bad? Pretty much ok but nothing special?
Thanks.
Old 03-11-2014, 11:02 AM   #226
Naples , Florida
Your proposed solar controller is a very basic PWM unit ( no MPPT) with no settings for battery type or temperature compensation. Both of these are very important features if you want to get the most from your solar panels and battery longevity.
lewster
Old 03-11-2014, 02:43 PM   #227
Rocinante's Avatar
Thanks, Lewster. That's the system my Airstream dealer *already* installed, though it's clearly good of you to urge others to shop around for more bang for the buck. I also should have shopped around more, I suppose.
Anyway, it does have an optional battery temp sensor input. Seems that could help a bit. Worth adding at this point?
It also has a few different charging algorithms, set by dip switches. I'll have to double check to see they are set correctly for the stock batteries in our TT.
In the end it's still a PWM controller, whatever that means, but maybe with a temp sensor and optimal dip settings we can eek out a bit more performance until we decide to upgrade to something better. Thoughts?
Old 03-11-2014, 05:50 PM   #228
Naples , Florida
Battery temperature sensing and battery type settings are indeed much better than none at all! Even though you will not be getting the benefit of MPPT, I would use what you have (as long as it is keeping your batteries full) until you decide on an overall upgrade.
lewster
Old 03-13-2014, 09:52 AM   #229
Rocinante's Avatar
Thanks again. We'll check on / add the battery temp sensor option to the PWM system we have, and we'll run that until we finally decide it's time to upgrade to MPPT. If we had it to do over again, we'd use what we've learned here to have a more efficient system installed.
Honestly, it just never occurred to us that we could customize our Airstream so much outside of what the dealer would do for us. We know more today!
Old 04-14-2014, 03:29 PM   #230
Hood River , Oregon
Lew! Hey, It's Mark from Hood River Coffee Co.! We just bought a 1997 B190 Airstream and I was thinking I'd like some solar panels on it! Are you ever in Hood River these days?
Cheers,
Mark
Mark_Hudon is offline   Reply With Quote
Old 04-14-2014, 04:08 PM   #231
Ag&Au's Avatar
Port Orchard , Washington
Cheers,
Mark
Hi Mark,Welcome to the Forums.
If Lew doesn't read this thread, you can send him a private message using this link.
http://www.airforums.com/forums/priv...=newpm&u=10325
If you click on his user ID on the left of any of his posts, you will also see some other ways to contact him,
Ken
Old 04-14-2014, 04:29 PM   #232
Hood River , Oregon
Thanks.
I went to his page but the email address is bad, it came right back. I'll send him a PM.
Mark
Old 05-22-2014, 10:27 AM   #233
2003 28' Classic
Ladysmith , Wisconsin
Name:	ImageUploadedByAirstream Forums1400776054.848608.jpg
ID:	212498does this look like a factory installed unit ?
JacobMerridy is offline   Reply With Quote
Old 05-22-2014, 10:11 PM   #234
Victoria , BC
Hi JacobMerridy,
From a quick look that looks like a ICP/Sunsei Solar Panel. I don't believe they are in business any more.
AirSolarGuy
AirSolarGuy is offline   Reply With Quote
Old 05-27-2014, 12:30 AM   #235
Gary W Wong's Avatar
Milpitas , California
Name:	ImageUploadedByAirstream Forums1401172035.295838.jpg
ID:	212948Click image for larger version
Name:	ImageUploadedByAirstream Forums1401172086.369274.jpg
ID:	212949Click image for larger version
Name:	ImageUploadedByAirstream Forums1401172115.906274.jpg
ID:	212950Click image for larger version
Name:	ImageUploadedByAirstream Forums1401172134.867651.jpg
ID:	212951xClick image for larger version
Name:	ImageUploadedByAirstream Forums1401172172.941543.jpg
Gary W Wong is offline   Reply With Quote
Old 05-27-2014, 01:02 AM   #236
These photos are of the airstream dealership install from fairfield ca and. They installed a 200 amp zamp solar system with ZS-30ap controller.
I am new to solar so I may have done something wrong while charging. I was out dry camping, boondocking this weekend from Saturday to Monday noon.
5 of us, my wife and three kids and I were at Lawson landing in tomalas bay and we had the sun out all day. Saturday we arrived at 3pm and set up camp with the airstream. Our first time boondocking and not saving much on utilities as we should have.
TV and DVD player on, heater at 67 degrees, charging our 5 iPhones, stove on cooking dinner, refrigerator in electric, water pump on, lights on after dark. Showering and washing dishes. Two fantastic fans running.
All fine the first night. Next day Sunday, we left the airstream after morning washing up, breakfasts from stove, tv on. We did turn off he heater. We thought after we leave solar would charge our batteries to full. While. We left .
I left the inventor on and airstream on instead of on store to shut down all systems. Came back around 7pm. We turned on the led lights, and wife washing dishes while I was outside bio camp grilling oysters and charging my cell phone with the heat exchanger component. My daughters were charging their iPhones and using them and also reading books. My son was outside with me playing. We went in after cooking the oysters and eat. Stove heated up the water for tea, heater was at 70 degrees, and now TV was on. Two Fantastatic fans running. I was concerned about the power but did not think of checking the level of charge on batteries. The zamp controller read 11.3 amp at time.
At around 10:30 pm the power dropped and shut down the DVD and TV. I may have made the mistake of not shutting everything down before leaving which may have caused some of the power usage.
We were going to shower and clean up also but we filled the grey water tank and were close to no water. I figured this would happen. So we went to bed and heater was still at 70 degrees.
Next morning, we woke around 8:30 am and stove working, inverter still on, refrigerator on electric, and iPhone charging on radio USB slot. TV and DVD player not working until I saw the batter meter read to orange and not red. And so kids wanted to finish the movie. Turned it on and it worked. The solar controller was at 4-6 for gain. Fantastic fans off and only movie playing. Water pump off. Refrigerator on. The batteries were gaining power as I see the meter read from red to orange to now green. In about 2 hours time. Sun was out full.
So the only thing I was confused about is the Sunday when our tv and DVD ran out and the batteries were not fully charged. Or did not family use it all before I get inside.
Lester you may have the answer but if anyone else has an answer also that would be great.
My airstream is a 2014 23 ft. international series.
Appreciate any answers as to what I did wrong or what when wrong for I will be dry camping again in October for the same amount of time but the sun may not be in full exposure at that October date.
Thanks ahead of time.
Gary wong
Old 05-27-2014, 10:15 PM   #237
Victoria , BC
Hi Gary,
There's a lot going on here, but to make it shorten it up I think you just were running too much and not monitoring your battery voltage. I think when you said the solar controller was showing 11.3 Amps this might have been Volts, which is pretty low. This is also probably why later on that night your inverter went into low voltage shut down, which is generally 10.5 volts +- .2 Volts. As for the Inverter its best to turn it on when you want power then turn it off when your done. This will help you conserve power. As for the solar, they weren't placed in all that great of a location, and you can see that you will be getting shadowing from the AC unit. Also did the dealership ask you what kind of RVing you planned to do and then sized both the solar system, and the batteries to go along with them? Any other questions just ask. I try to comment when I can, but I have way too many emails as it is
AirSolarGuy
Old 05-27-2014, 10:17 PM   #238
Victoria , BC
Originally Posted by AirSolarGuy View Post
Hi JacobMerridy,
AirSolarGuy
Sorry ...are not in business any more...just noticed that
Old 05-28-2014, 05:09 AM   #239
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Like AirSolarGuy said, there's a LOT going on here - you have (by my count) 5 people using battery power for several days, and that's a lot of load.
But one thing I saw: Definitely learn how to force your fridge into propane mode. It'll still use some 12 volt power for the electronics, but that's minimal. Running the fridge off the inverters will run down your batteries quickly. Our fridge has two settings - Auto and Propane. Auto uses electricity, unless it goes out, then it switches to propane. Propane mode means it stays in propane even if 120 volt power is available.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-03-2014, 11:48 PM   #240
2012 25' International
Prosser , Washington
Gary wong
We had a similar experience at Grand Canyon National Park. We dry camp at the North Rim. Our refrigerator is on propane, but the original equipment fan to dissipate heat runs incessantly. We do not run the TV, minimal use of lights at night, and no fans, TV…ZIP. Despite full sun 160 watt 9 amp solar, and 80 in the day 40 at night temps, our fan never quit, and we were drained by AM. What we found was that the fan to dissipate heat should be replaced by a quieter and less energy draining fan. In addition, we realized that our OEM batteries were shot. We replaced these with AGM and upgraded the OEM solar to 320 watts/18 amps. We have a 30 amp Zamp controller. It should be on float when fully charged. I ordered a new more efficient refrigerator fan. Upgrading the fan + solar +AGM batteries, we hope to boondock for a long time….but just in case, we also travel with a Honda 2000 watt generator and a really large ice chest.
Tim and Tam is offline   Reply With Quote
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
Forgive my ignorance spinolio Airstream Motorhome Forums 35 01-08-2003 05:05 PM
BatteryMinder charging time davidz71 Our Community 1 12-13-2002 09:55 PM
Solar Installation cactushead 2000 - 2004 Safari 19 10-21-2002 05:56 PM
The forums private message system PeterH-350LE Forum Admin, News and Member Account Info 0 04-10-2002 12:25 PM
