Old 02-09-2016, 10:22 AM   #1
Here4TheBeer's Avatar
2014 27' FB International
Brattleboro , Vermont
Expanding Factory Solar
I've been reading all of the threads on here and have not been able to find an answer to this question:
Can the factory installed solar (2014) be expanded with suitcase panels?
I understand the wiring to the existing roof panels is inadequate for more panels.
The factory solar is actually nearly enough for us most times. But I'd like to set up a connection to plug in some suitcase panels when we're boondocking for extended periods.
Without rehashing all of the commentary about how horrible the factory setup is, can Lew or BoldAdventure or someone else knowledgable offer an answer of how this could be accomplished?
Thanks for everyone's contributions to this forum, it's really an incredibly valuable resource.
Here4TheBeer is offline   Reply With Quote
Old 02-09-2016, 10:28 AM   #2
dznf0g's Avatar
Oswego , Illinois
I installed a pigtail from the front exterior to the controller, creating a parallel circuit. I use a supplementary ZAMP 160 watt suitcase solar setup (with disconnected attached controller). Here is a rough diagram:
Name:	solar digragm.jpg
-Rich-
Old 02-09-2016, 10:32 AM   #3
Thanks for the reply Dznf0g! That's exactly what I was thinking could work. Are you still using the factory controller in this setup?
Old 02-09-2016, 10:39 AM   #4
dznf0g's Avatar
Oswego , Illinois
I didn't have a factory system. I have a Morningstar 15A SunSaver MPPT.
-Rich-
Old 02-09-2016, 11:02 AM   #5
dznf0g's Avatar
Oswego , Illinois
Here is a thread with more discussion:
http://www.airforums.com/forums/f448...up-146405.html
-Rich-
Factory Installed Solar Charging System SilverGate Generators & Solar Power 423 04-08-2018 08:57 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Adding a New Panel to the Factory Solar richschafer Generators & Solar Power 1 04-03-2008 09:32 AM
expanding foam insulation DinubaDave Exterior Restoration Forum 8 06-30-2005 08:19 AM
