Old 09-19-2011, 01:39 AM   #1
2012 23' FB International
Bismark , Bahamas
EU2000i Won't Start
My EU2000i won’t start.
Seems to me like no fuel is getting in the carburetor (the tank is 3 / 4 full).
If I spray starting fluid into air intake it runs for 5-10 seconds.
If I loosen the bottom screw on the carburetor no fuel runs out (this is the screw shown on pg. 52 of the manual used to drain the fuel -- for long term storage). I even opened the bottom of the carburetor and there were just a few drops of fuel inside.
Apparently EU2000i seems to have a fuel pump. So I disconnected the fuel line going to the carburetor and pulled the start a few times expecting to see fuel come out of the hose. No fuel came out. Does this reveal anything?
PaulR is offline   Reply With Quote
Old 09-19-2011, 02:51 AM   #2
Baltimore , Maryland
check the oil. If low it won't start...
Old 09-19-2011, 06:26 AM   #3
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
As I recall, Honda generators generally have a fuel tank vent on the fuel cap that has to be turned on before fuel will get to the carburetor and it will run ...
I have two different sized Yamahas, and they both also have a fuel shutoff, that needs to be turned on before the engine will run - not sure whether Hondas have such a feature ... but following the fuel line from the carburetor back to the fuel tank will lead you to such a critter if you have one.
AirsDream is offline   Reply With Quote
Old 09-19-2011, 06:52 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Fuel pumps do fail. A new one is around $30 and can be easily replaced.
Richard
Old 09-19-2011, 07:31 AM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
You didn't say if this was new or an old one you have. If you just bought it and are using it for the first time, make sure the vent cap is open or it won't start.
If it's a unit you've used for a while, then I would check the oil level, spark plug, and fuel pump (in that order).
Good Luck!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-19-2011, 07:36 AM   #6
My guess is carb is plugged with crud. It has very small openings that plug easily if fuel is not drained when generator stored.
DIY did not work for me and I ended up taking the generator to the Honda dealer.
handn is offline   Reply With Quote
Old 09-19-2011, 07:57 AM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
PaulR
How long has this Genni set not being used. IF its more then 45 days,then the fuel is old. Check all of the suggestions above first. I get this all the time. I have a vertical Honda/pressure washer in the shop now.The carb is so gummed up from leaving UNTREATED fuel in it that it displays the same symptoms. I pulled the bowl and confirmed my supisions. The needle valve has to be replaced.17 bucks.Bowl gaskets are not avaible from my suppliers at least,new bowl and gasket assembly 20bucks. Plus my labor so I just ordered a new carb for the customer $40 bucks including the shipping.IF you are not a qualified technician,and have the speciality tools it takes to work on this machine,I highly recommend you find a Quailfied Tech. to do this work. You will come out better in the long run. OH and empty the fuel out when not in use or use STABIL fuel treatment.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 09-19-2011, 10:26 AM   #8
Bismark , Bahamas
My EU2000i is about 6 years old but has only run probably 50hrs total – virtually nothing the past 4 years, though I would typically start it once a year.
The longer version of the story leading to yesterday's problems is:
I had used the EU a few weekends ago camping but it was running rough and only on choke so I did not use it much. Then yesterday I decided to give it a look, so I took apart the carburetor and cleaned it – sure I did find some deposits. When I put it back together the roughness was gone and it run fine, like new, both eco and non eco operation very smooth, I let it run for about ˝ hour.
I then saw a YouTube video about a trick that can presumably be used to run the carburetor dry before long storage. Basically you can disconnect the spark plug kill switch (a little white connector next to the main on/off switch), so that when you turn the switch to off, the fuel is cut off BUT the spark is not shorted so the EU2000 keeps running until it has burned all the fuel in the carb. I did so and sure enough the EU run for about 2 minutes, gasped twice and stopped --- presumably dry.
But then a couple of hours later I put clean gas because I thought I’d run some Techron through.
Alas, the EU would start no more. Got blisters on both hands from pulling. Starting fluid gets it going but apparently no fuel reaches the carb. I took the carb apart one more time, thinking perhaps some bigger pieces of varnish had gotten loose and clogged it up again but no, the carb was clean, all jets were open, there was just no fuel in the bottom of the carb (ok perhaps a few drops only).
Old 09-19-2011, 12:04 PM   #9
dznf0g's Avatar
Oswego , Illinois
Check the fuel filter where the fuel line goes into the tank. Since you have no fuel coming out of the pump down stream while pulling the rope, you eithe have a plugged filter or the pump itself isn't functioning.
The low oil switch won't stop the pump from operating, just won't deliver spark to start it.
Get the fuel flowing, then see where you are at.
Old 09-19-2011, 12:08 PM   #10
dznf0g's Avatar
Oswego , Illinois
It's possible, I suppose that the fuel valve could be malfunctioning too. Disconnect the fuel line from the shut-off valve on the tank side and see if fuel runs out by gravity. If it does, reconnect and remove the line from the shut off valve on the fuel pump side. Fuel should flow under gravity. If it doesn't, the valve has an issue.
Old 09-19-2011, 12:52 PM   #11
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Anothercheap and easy thing to try is to pull the plug, wipe it clean and wire-brush it.
This has made me look like a genius more than once. Come to think of it, the only times.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 09-19-2011, 09:09 PM   #12
Bismark , Bahamas
That you for your suggestions. I will follow the fuel line to the tank -- see if I can find a clogged filter, non working on/off valve or bad fuel pump. Its just that from what I can tell, getting to the fuel lines and the fuel pump requires quite a bit more disassembly (the carburetor was easier to access) so I’ll have to find some horizontal surface in my garage to do the surgery and … well finding such a surface may require some garage cleanup, so may have to wait until next weekend…
BTW, here is the video I found and followed to run the EU 2000i dry (perhaps foolishly so?)
I’m posting it to inject a word of caution, because if indeed my fuel pump went bad right after this, perhaps the fuel pump does not like running dry, or against a vacuum, after all. So I’d advise to at least wait and see what happened to my fuel pump before trying the procedure described in the video.
Old 09-22-2011, 11:26 PM   #13
Bismark , Bahamas
Thanks everyone. So seems like a fuel problem between the tank and carb.
So I want to trace the fuel path out of he tank. But the question is how do you access the fuel components?
The fuel line seems to come out of the tank…
…down into the on/off switch then…
….up to a white round assembly which I do not fully understand what it is.
Is this white round fuel thing the fuel pump? or the fuel filter? or both? And also out of this white round fuel thing a third line goes into the engine.
The question is how do you get to these fuel components? Looks like the red plastic housing needs to come out. Does anyone have a diagram how the EU2000i is put together? I'd rather not risk disassembling more tan I need to.
Old 09-23-2011, 01:27 AM   #14
2005 19' Safari
GLENDALE , AZ
Is your Honda still under warranty? I think it is two or three years, now. It might be easier to have it repaired at a Honda service center, if you are unfamiliar with maintenance. You might do more damage than good if you break something.
I have never used this service, but Camping World does seasonal maintenance; and we checked out several Honda models at a local equipment rental place that was a Honda generator dealer, before we bought the 2000i. Their service people were very knowledgeable and helpful.
In fact, the 3000 rental that we were looking at (to see how loud it was) was running real rough when they started it up; and the sales person immediately called over a technician who started working on it. Out of curiosity, we watched while he replaced the spark plug and adjusted the carburetor until it ran smoothly. So, they obviously knew what they were doing.
We were going to rent a 3000i over a weekend to test it with our Bambi, before we bought. However, we later decided to go the 2x2000i route due to the weight of the 3000.
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
Honda EU2000i Benjo Generators & Solar Power 24 02-08-2012 06:41 AM
Start capacitor for Armstrong 14 A/C pdwhitt Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-04-2011 03:01 PM
High idle, or maybe stuck throttle and hugely loud revving noise at start. PuffinPotter Classic Motorhomes 33 08-08-2011 11:47 AM
Honda EU2000i Vibrates in eco mode only? Patriot666 Mechanics Corner - Engines, Transmission & More... 11 05-10-2011 07:55 PM
