Planning to do some dry camping and use my 2 Honda EU2000i's to run A/C on 2007 Safari 25'. Camping World sells paralleling kits from Gen-Tran ($214.99)and Reliance Controls ($179.99). I asked the salesperson what the difference was between the units and was told $35.00. Does anyone have any pro's or con's on these kits?
Another way is to buy the parallel cords from Honda ( about $30 ) and a pig tail adapter that has a 30A female RV end ( about $10 ) . Cut the 30A female end off , splice the wires together and your done . 40 bucks and a 1/2 hour .
No diagram. You can see in the pictures where the different colored wires connect on the generators. In the TT connector box:
Hot wires (black insulation) from generators joined at the hot screw (brass or black painted) of the TT outlet.
Neutral wires (white insulation) from generators joined at the neutral screw (silver) of the TT outlet.
Ground wires (green insulation) from generators joined at the ground screw (green painted) of the TT outlet.
The thickness of two 12AWG wires twisted together is a bit more than will fit on the TT plug connectors designed for 10AWG. I just trimmed away a few of the strands of the 12AWG wires. You aren't using all their 20 amp capacity even with the EU2000 at max output.
I've tested this with a 1500W space heater set on 900W, a 1500W hair dryer on high, and our 1500W microwave cycling on and off (not on Eco-Throttle). After 15-20 minutes or so (and shutting everything down) there were no hot spots at any of the connections.
My concern with using two EU1000 parallel cables with the ends cut off and joined at the TT connector is that these generators only put out about 8 amps and even 18AWG is more than enough for that. I'd want at least 14AWG (typically for 15A) for the EU2000s. Ticki2, did you measure the wire gauge of these cables?
I made one from high end parts for around $60. from the electrical supply house. If you look at the wiring diagram from Honda it is pretty easy to wire it yourself.
Michelle
Think you are having a bad day? Go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar) http://Michelles-Adventures.US
You're paying for the convenience, and the Honda name. As others have already pointed out, you can make the cables yourself for less than 1/4 of the price of genuine Honda. The only caveat I would have is if the generators are under waranty, you may not want to have the homemade cables in sight when returning them for warranty work.
