Old 04-28-2007, 12:08 PM   #15
1976 25' Caravanner
Campton , New Hampshire
The down side of making one up with the three prong plugs that if one should come out accidentally it will be live if the other gen. is running . The torpedo type plugs for the honda parellel cable is protected on the outside.
ticki2 is offline   Reply With Quote
Old 04-28-2007, 01:50 PM   #16
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
I do not use the parallel setup as a 30 to 15 adapter. I use a seperate 30 to 15 adapter.
Michelle TAC MT-0
Sarah, Snowball
Old 04-28-2007, 02:55 PM   #17
1976 25' Caravanner
I was refering to the picture in n2916s post , not sure what your set up is .
Old 04-28-2007, 04:09 PM   #18
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Confused
How do you keep from connecting the generators "out of phase" with each other?
Pop Rivet is offline   Reply With Quote
Old 04-28-2007, 05:31 PM   #19
1976 25' Caravanner
When you use the banana plugs on the parellel cable the gererators automatically adjust for it.
Old 04-28-2007, 05:48 PM   #20
Cracker's Avatar
Pittsfield , Maine
I know that a buck saved is a buck earned but, when you're dropping close to 2 grand for the two Hondas, and you're not that savvy with the electrical side of things, go ahead and spring for the peace of mind afforded by someone else's sound engineering! This is, by no means, meant to discredit those who know what they're doing - or are otherwise comfortable with a home-built setup. I applaud their skill and bravado!
Cracker
Cracker is offline   Reply With Quote
Old 04-29-2007, 04:29 PM   #21
If you look at the wiring diagram the Standard outlets are in parallel with the bananna plugs. Just not fuse protected. You can get a couple extra amps that way. That is what I recall.
Michelle TAC MT-0
Sarah, Snowball
Old 04-29-2007, 04:50 PM   #22
1976 25' Caravanner
That is correct , either will work fine . My only caution was when using the standard outlets , if one should come out with the gen. running you would have a live end exposed.
Old 06-25-2007, 11:28 AM   #23
2007 25' International CCD
Arlington , Virginia
I agree with Cracker. Unless you know what you are doing, being a "cheapskate" can come back to bite you on your rear-end big time!
Streamer1 is offline   Reply With Quote
Old 05-13-2012, 02:37 PM   #24
Lexington , Kentucky
EU2000i Parallel Kit
I have read some forum posts stating that combining the 110v outlets on the two generators limits total output to 20 amps (due to circuit breaker on each generator). They state that the banana plug circuit bypasses the circuit breaker so the total output of the combined generators (26.6 amps) is available. Does anyone know if this is true?
wlanford is offline   Reply With Quote
Old 05-14-2012, 05:49 AM   #25
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
I know it to be a fact this method can provide at least 30 amps (tested with resistive heater/blow dryer elements). Unfortunately, MCM no longer carries the shielded banana plugs and I don't know of another source for them.
Maurice
You've mastered backing, now the next level... Parallel Parking! SilvrSausage Towing, Tow Vehicles & Hitches 8 05-22-2007 08:40 PM
dometic recall kits crestonrv Refrigerators 14 04-19-2007 08:34 AM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 07:44 AM
shower curtains gmc70 Upholstery, Blinds, Walls & Interior Finishes 12 10-20-2002 03:25 AM
