Old 02-11-2009, 01:53 PM   #1
2010 27' FB Classic
N/A , Texas
EU2000i Honda Question
You guys that use 2 of the EU2000i's to run your (1) 13,500 Coleman air conditioner in the summer months. Approximately how long do both gens. run while electrically hooked together before running out of gas while the air conditioner is running and no other electrical devices?
Reason I'm asking is to see if a larger central feed tank is needed or if I could get by just filling the tank on the generator up every so often.
Need your comments to help me decide.
Old 02-11-2009, 02:39 PM   #2
2008 31' Classic
Sweet Valley , Pennsylvania
You should get about 5 hours, give or take.
TROPHYJIM2 is offline   Reply With Quote
Old 02-11-2009, 02:47 PM   #3
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I have run for over 4 hours before getting worried it WOULD run out of gas before I filled back up.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 02-11-2009, 04:32 PM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
Just Do It!!!
When Ike blew through last year I was up at TAHI and the entire park lost power....the two 2000i's running together stayed on line from about 9:30PM to 5:00AM (7.5 hours) - but I do not think that the compressor was on all of the time - bottom line - I will be in the market for some sort of a larger tank before I do any serious boondocking. I currently have two tanks for my 2000 40 hp Mercury outboard (automix in the injector system, so only straight gasoline in the poly tanks). One tank is the standard 6 gallon tank, the other is quite a bit larger - 10 or 12 gallons. I hope to find a set up to be able to utilize either of the tanks at any given time....
Please post your solution (with pics) and where you found the equipment.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-11-2009, 05:31 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
We have 2 2000i's and do exactly what you are talking about regularly.
The answer is, it depends on how hot it is during the night, and how many times the A/C cycles on during the night. When we use the generators overnight, we also leave the refer on ac power.
Generally speaking, we can get 7-8 hours on the one gallon tanks on the 2000i's. I usually top them off right before we go to bed, and we make it through the night.
We also sometimes use our six gallon auxiliary tank when needed. It works great and can feed both Hondas or just one.
Brian
SuEllyn & Brian McCabe
Old 02-11-2009, 05:54 PM   #6
2008 31' Classic
Its definately overkill but we have a 50 gallon Transflow refueler (regular gas) in the back of our HD2500 Silverado which has a cap. The Pickup has a long side window on the drivers side with a lock, So you can put the gas in the pickup anywhere or fill the generators easy. The refuler comes with an 8 foot hose, pump and a gas handle like at a gas station only somewhat smaller. Takes up 10 inches along the back of the truck. It is worth it to us to get the extra range while towing plus fill the generators or whateever as needed.
Old 02-11-2009, 07:00 PM   #7
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Check out Wise sales 6 gal. aux. tank
Phil Gobie is offline   Reply With Quote
Old 02-12-2009, 06:24 AM   #8
2010 27' FB Classic
N/A , Texas
Thanks everyone. Good to hear that at least 4 hours min. out of the tank on the units running the air an if not so warm a few more hours. I will look into an aux. fill tank to feed the 2 gens. I looked at the Wise set up and that seems like a good way to go. I'll have to get the measurements of the aux. tanks they carry to see which one will fit on the tongue of the trailer tucked behind the propane tanks. I really don't want to store the extra fuel in my TV as my bed is enclosed. Do any of you carry your Wise aux fuel tank there and if so what size(gals) tank fits? Does the 6gal.?
Is anyone using the little night light plug in alarm that sounds off if the electricity goes off? Seems to me like an nice touch against thieves in addition to chaining them up.
Old 03-02-2009, 08:59 PM   #9
1996 25' Excella
Delray Beach , Florida
aux fuel tanks
look for the six gal tanks that allow for siphon to either one or two eu2000's--it works well and provides many many hours depending on load.You can find these on the internet under honda generators or on ebay I have two on my sailboat and can run for many days (at night only)16000btu ac
kimbal88 is offline   Reply With Quote
Old 03-03-2009, 06:13 AM   #10
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I use the six gallon siphon tank. Hooks up to both generators. Alllows for all weekend running.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
I Love my Honda EU2000i Generators panabax Generators & Solar Power 30 10-30-2016 02:10 PM
Honda EU2000i dmac Generators & Solar Power 35 06-01-2010 11:09 AM
Hour meter for Honda EU2000i walter1 Generators & Solar Power 7 02-01-2008 05:48 PM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
