Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 05-02-2008, 06:16 PM   #1
Profile:  Carson City , Nevada
EU2000i and AC
The '77 Argosy I am buying has AC - amp draw unknown to me at this time. I am thinking that I will buy a Honda eu2000i generator. BUT... I think the AC is the highest draw and wanted to calibrate for loads before buying a generator (or generators).
Anybody hazard a guess as to the amp draw of AC running on 120V? I think I can figure out the rest of the amp load, but need AC help.
Thanks.
Mike S is offline   Reply With Quote
Old 05-02-2008, 06:39 PM   #2
Profile:  1973 25' Tradewind
Romulus , New York
It is the startup that needs all the wattage. A 3000i will do it or two 2000i connected togeather.
jayray5 is offline   Reply With Quote
Old 05-02-2008, 06:40 PM   #3
Tom O
Toldfield's Avatar
Profile:  1966 17' Caravel
1968 26' Overlander
Altadena , California
I tried to use my EU200i to run the AC on our Caravel once. When the compressor kicked in the poor generator almost did a snap roll in the driveway. It was not happy. I am not sure what the power requirements are for the AC but it was obviously too much the little Honda.
Tom
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
Toldfield is offline   Reply With Quote
Old 05-02-2008, 06:50 PM   #4
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
The Honda will run our 12,000 btu roof air--barely. The generator grunts and groans, the a/c compressor does the same, thent he compressor leaps to life, and the generator relaxes a bit. It is not recommended because of the chance of burning up the compressor, generator, or both. Everyone has pretty much agreed a single 3000 is too awkward to schlep around, and 2 2000's will give you a total of 4000 watts for about the same money as a single 3000. It's easier to tote around a pair of 2000's,one at a time, than lugging the hernia-producing 3000 by yourself.
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 05-02-2008, 06:53 PM   #5
wolverine's Avatar
Profile:  2005 31' Classic
Sunrise Beach , Missouri
We use two EU2000i running in parallel and it handles both the air and other smaller electrical draws with no problem. As was reported earlier, the startup of the A/C is the major draw.
wolverine is offline   Reply With Quote
Old 05-02-2008, 07:12 PM   #6
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Most roof A/C units pull about 12 amps for the compressor and another 4-5 for the blower motor (depending on the ambient temps). That is NOT counting compressor start-up....which can draw a momentary 25-30 amps!
Yamaha states that their EF2400iS will run a 13.5K roof air, and there are several folks on these Forums that have done so successfully with said unit.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-02-2008, 07:16 PM   #7
Images: 52
That extra 400 watts helps. Really.
AIR#2611
Old 05-03-2008, 09:12 AM   #8
Thank you all. I thought the little Honda was not up to the task, it would probably be running at 3/4 speed and making more noise as well. I thought of dual Hondas, which has a lot of advantages, but the Yamaha EF2800i would do the job with less work, and it weighs only 20 lbs more - and less than my outboard engine.
Obviously need to study a bit more.
Thanks again.
Old 05-03-2008, 09:20 AM   #9
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Well, almost everybody.
Mike there are reams of pages on this subject and everything else you may ask about Generators; their use, their weight, Honda vs Yamaha, how to put wheels on the 3000 on the cheap, Lots of facts, lots of opinions.
Click on the link below for a bunch of generator threads found with a search.
Dave
http://www.airforums.com/forums/sear...archid=1050566
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-03-2008, 11:44 AM   #10
Commercial Vendor
lewster's Avatar
Thanks again.
Mike,
Be careful about which Yami you pick. The EF280i is a construction site type rig....very noisy when compared to either the EF2400iS of the Hondas.
AIR # 10325
Old 05-03-2008, 01:03 PM   #11
freedom's Avatar
Profile:  1958 22' Flying Cloud
1993 34' Limited
Quartzsite , Arizona
We use a Yamaha 2400is with a 13.5BTU and it works very well. It has enough power to run the AC, TV (27" Bravia), surround sound and satellite receiver. I usually turn the fridge to gas and avoid any other power drains. This little gen is very quiet, easy to handle (I think about 68#), and has been flawless in it's operation.
Best of luck with your genset search, and enjoy your day!
freedom is offline   Reply With Quote
Pingbacks are On
Can you link a EU2000i with a EU1000i? Raptorrider2001 Generators & Solar Power 21 01-30-2008 06:14 PM
Honda EU2000i dmac Generators & Solar Power 33 07-18-2007 10:24 PM
EU2000i Parallel Kits 2dabeach Generators & Solar Power 22 06-25-2007 10:28 AM
eu2000i MarkR Generators & Solar Power 11 11-28-2005 03:33 PM
Propane Powered EU2000i? Pick Generators & Solar Power 6 01-22-2004 03:09 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
