Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 11-28-2005, 12:16 AM   #1
MarkR
MarkR's Avatar
Profile:  1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
eu2000i
I have a Yamaha ef1000 generator, which is great 99 percent of the time, but I'm thinking lately that I'd like something that will run our full size side by side refrigerator (for the house)(the ef1000 won't). Can owners of Honda eu2000i's let me know if their unit will run a Full Size Refrigerator - I'd appreciate it (mathmatically it seems like it should, I just want some assurance that it does . . . especially when the frig first starts up).
Mark
Led Balloon in Drag
MarkR is online now   Reply With Quote
Old 11-28-2005, 12:41 AM   #2
Buttercup
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
Mark,
This really depends on the fridge. Do you have more info on the fridge? Most modern fridges should run on less than 1000 watts including start-up.
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally!
Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
2008 Mouse count =
WBCCI # 17330, VAC Membership Chair, CAC Member
Buttercup is offline   Reply With Quote
Old 11-28-2005, 09:45 AM   #3
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
if you do the math, a 1000 watt generator will supply 8.3 amps. check your frig for f.l.a.( full load amps) if it is less you will be fine. i will note, that i am not taking into consideration the surge on start up, and the ability of the generator to handle the initial surge.
norby
you also need to consider the resistance of the extension cord. the ext. should be as short as possible. also most cheap extention cords have small wire( that is why they are so cheap).
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 11-28-2005, 10:55 AM   #4
norbert
norbert's Avatar
Images: 24
here is a chart i hope you find handy.
Old 11-28-2005, 12:18 PM   #5
MarkR
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
I'm away from home at the moment but our regrigerator/freezer is your basic Side by Side 36" wide General Electric w/the Water & Ice Maker/Dispenser in the door. I had a "heavy duty", relatively short, extension chord and when I turned on the Refrigerator (hooked to my Yamaha ef1000) the RPM's went up and then shut down from "overload" after about 5 seconds. I just figured it couldn't handle the "start up", could it be something else?
Thanks for the replys.
Mark
Led Balloon in Drag
Old 11-28-2005, 12:47 PM   #6
norbert
norbert's Avatar
Images: 24
conjecture is the same as pissing into the wind...you have to have more info.
norby
Old 11-28-2005, 01:38 PM   #7
Buttercup
Buttercup's Avatar
1954 25' Cruiser
Not having enough info I will guess the following... the generator could not deliver enough VOLTAGE to get the rotor on the compressor to start turning to full speed. Result is what is called a locked rotor condition where the rotor doesn't turn but still draws full current doing so.
In my business we call this a voltage collapse.
I will bet that your fridge draws less than 500 watts running but almost 3 times that starting. These solid state inverter type of generators can have trouble delivering voltage for inductive loads (like a fridge) when the load is close to the generators steady state loading capability.
2008 Mouse count =
Old 11-28-2005, 02:24 PM   #8
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I ran my full size, side by side Fridgidaire on my EU2000i for 6 days, during hurricane Fraces last year. It had a little trouble on eco-throttle, but not running full-bore.
I now have a transfer switch, right at the main electrical panel.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 11-28-2005, 03:16 PM   #9
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Pick was that on regular gasoline or propane? ......just wondering.
Old 11-28-2005, 03:18 PM   #10
MarkR
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Thanks Pick, that's basically what I wanted to know. And thanks for all the other info on the mysteries of electricity, sounds like if I could "push start" my frig then a 1000 watt generator would keep it going fine.
Led Balloon in Drag
Old 11-28-2005, 03:38 PM   #11
markdoane
Profile:  , Minnesota
Images: 59
I know it's a different brand, but Honda recommends a 2500w generator.
http://www.hondapowerequipment.com/genwat.asp
Non-contributing deadbeat.
Old 11-28-2005, 04:33 PM   #12
MarkR
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Actually I was looking to replace w/a Honda, but it was the eu2000i which is less than the 2200w that that website recommends . . . sorry this isn't really directly related to AirStreams . . . and thanks for that link.
Led Balloon in Drag
Can you link a EU2000i with a EU1000i? Raptorrider2001 Generators & Solar Power 21 01-30-2008 07:14 PM
Honda EU2000i dmac Generators & Solar Power 33 07-18-2007 11:24 PM
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 05:39 PM
Propane Powered EU2000i? Pick Generators & Solar Power 6 01-22-2004 04:09 PM
My EU2000i & gas can & boondocking Raptorrider2001 Generators & Solar Power 5 04-03-2003 10:12 AM
