Old 02-07-2010, 08:38 PM   #41
"Cloudsplitter"
Originally Posted by Wabbiteer View Post
Minnesota has recreational use gas which is high test without any ethanol, even the traces they sneak in to raise octane. What it comes down to is giving boaters and personal sport vehicle owners the safety margin of un-cut gas to face summer storms or -40° nights. Check your local Marinas to see if they have off-road blended fuels that might be all petroleum, we here have some normal stations with rec gas as well.
Just spoke to our Marina guy yesterday...has not been able to find a supplier for the good stuff yet, not really sure if it's just a NY thing or not. I sure would like some 91 straight for the Merc ob though.
Old 07-21-2010, 04:50 PM   #42
Kenosha , Wisconsin
no premeum gas!
the aluminum heads in your engine are not design to run with any thing over 87 octane, or they stand a good chance of warping. Use seafoam to add to your gas tank with new gas and runn the entire tank through while under load. it should clean up the carb. If not it may be rebuild time for the carb and fuel system.
Gentech is offline   Reply With Quote
Old 07-21-2010, 05:36 PM   #43
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
lo octane ng; hi octane oui, oui.
airports have higher octane fuel. plus most drag strips, some roundy-round tracks and if all else fails, buy a 55gallon bomb directly from VP.
wmarsha is offline   Reply With Quote
Old 07-21-2010, 07:05 PM   #44
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I will stick with the recommendations found in the owners manual.
FUEL RECOMMENDATIONS
This engine is certified to operate on regular unleaded gasoline with a
pump octane rating of 86 or higher.
Richard
Old 07-21-2010, 07:14 PM   #45
r carl's Avatar
Lin , Ne
Originally Posted by Gentech View Post
the aluminum heads in your engine are not design to run with any thing over 87 octane, or they stand a good chance of warping. .
Where do you come up with this stuff?
Old 07-23-2010, 06:58 PM   #46
ts8501's Avatar
2022 25' International
Savage , Minnesota
I stupidly left a small amount of fuel in my EU1000 for just two weeks, and then had to have the carb cleaned out, again. I had a run of three years with a perfectly runing unit, and I do/did not run mine every month. Lesson learned; again. If you're not going to run the gen for another couple of days, run it dry, and then drain what is left using the carb drain screw.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
