Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 05-10-2008, 09:29 AM
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton, California
Status: Online
Originally Posted by overlander63
Where I work, most everyone has their own tools, but I have many specialty tools you don't find every day that they need to borrow. I keep several pages of a legal pad with each person's name on it, and write down the tool they borrow. If they borrow the same tool twice, the third time they have to buy one of their own.
I like that system.
Years ago (1976-1980) I worked in a small engine repair shop. Out of that experience I also developed the policy of not loaning out power tools. There are too many people who don't have the concept of checking the oil, or of making sure you use mixed fuel in a 2-stroke engine, etc. It always amazed me how many people would simply return the equipment to the owner instead of having it repaired - especially when it was something that they had done to create the break-down.
I do loan out other tools from time to time. They usually come back...
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Get rid of these ads... register today, it's FREE
Old 05-10-2008, 10:16 AM
ts8501
Profile:  1990 34' Excella
Savage, Minnesota
EU1000 Stumble
I have the exact same unit. I have had it for 5 years now, and have had the exact same problem twice. Here is what I have learned, and how I now avoid the problem, and what you need to do.
Your carb jets are dirty. This is from the gas and/or Sta-bil. Clean or get the jets cleaned. Then in order to avoid the problem, do the following:
1) Before storing for more than a couple of weeks, run out all the gas out of the unit. Do not store it with any gas remaining. Run it until it stops from lack of fuel.
2) Do not use Sta-bil. I know this sounds wrong, but since you are not storing, you will not have to use Sta-bil. Sta-bil seems to add to the jetting problem.
3) Buy only the lowest octane unleaded fuel. Do not use any premium grade. The little guy can't handle the higher octanes.
Since doing 1-2-3, I have not had any further problems. A Honda Certified Tech gave me the information. I was tired of servicing the rough running unit every year!
-Tim
Old 05-10-2008, 11:59 AM
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula, Montana
-Tim
Ok this counters what I have been told. Evaporating gasoline leaves behind "varnish". That is why you want it a full as you can get it.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 05-10-2008, 02:29 PM
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix, Arizona
Status: Online
Sounds like we have some conflicting information. Let's see:
Sta-Bil is good/bad?
Keep the tank full/empty?
Gas should be low/high octane?
Richard
Charter Member Four Corners Unit
Old 05-10-2008, 02:41 PM
Fyrzowt
Fyrzowt's Avatar
Status: Online
As posted in an earlier post, I worked in the small engine repair business from '76-'80. Technology changes, but at that time the recommendations were:
Regular fuel in a 4 stroke, drain the carb and run it out of fuel prior to storage.
While it's true that "evaporating" gasoline leaves varnish, if there is no gasoline in the tank/carb to evaporate, there will be no varnish.
Dried out gaskets however,can be a problem if you run the carb dry.
I know nothing about Sta-bil other than hearsay.
Dave
AIR #15800
2000 Safari SS 25'
Old 05-10-2008, 04:25 PM
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by azflycaster
...Gas should be low/high octane?
owners manual suggests "octane rating of 86 or higher"
i try to avoid fuel with much ethanol content, for all the obvious reasons.
so in the winter that often means using premium fuel, which has NO negatives for the genset,
except price.
...Keep the tank full/empty?
really depends on the definition of 'storage'....
IF intentionally mothballing the genset, for 4-6 months or longer, i'd drain it.
but 2 months with a full tank should not be harmful, if the ethanol % is kept low...
...Sta-Bil is good/bad?
IF long term storage is necessary AND draining/burning all the gasoline isn't possible,
a little stabile in ONE tank should NOT be a problem...
i don't routinely put stabil in the fuel can however.
must be a slow weekend here.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 05-10-2008, 09:09 PM
  #21
safari 28
safari 28's Avatar
Profile:  2004 28' Safari
holland, Michigan
A product that over the years has been just incredible is Lucas fuel treatment. I use it in my boat every year in the spring. Tank has been filled and fuel conditioner from the dealer installed in the fall, but the gas is just old. This stuff makes it seem like fresh gas. It also works as a cleaner/lube for fuel injection systems. I use in all my kids cars, really helped in high altitude applications where older fuel injectors are clogging due to lack of air.
For my 10 kw back up generator at the house, I keep the tank filled and apply the Lucas. I run the unit monthly for 20 minutes under load/ when home??. I never use Stabil, had problems big time before I was turned on to this Lucas fuel conditioner. Once/ year I drain what is left if not used and start with a fresh tank.
Old 05-11-2008, 04:34 AM
  #22
henw
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere, Florida
All gasoline in Fla will now be 10% ethanol. The only exception will be at Marinas as the alcohol can damage fiberglass tanks on boats. But, the marinas are having a hard time in finding the real stuff. It does run hotter. And, I am concerned about what it will do to my generators.
Tom
2007 28' Int CCD.
2008 F 250 6.4L Diesel.
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Old 05-11-2008, 04:59 AM
  #23
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs, Florida
Solved all those problems by converting mine to propane! Really glad I did after reading this thread. My EU2000 is 7 years old, probably has about 250-300 hours on it.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 05-11-2008, 05:00 AM
  #24
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville, Maryland
if you test the gas in all 50 states you might find as many as 100 different blends. The blend of additives and the new addition of corn to our gas makes for a very inconsistent product. Small engines have a hard time coping with the drastically different blends.
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
Old 05-11-2008, 08:14 AM
  #25
ts8501
Savage, Minnesota
EU1000 Stumbles
I know it is counter intuitive (low Octane, no Stab-bil, run gas til empty). I use Sta-bil in everything, but not the Honda any more. I never usd to run fuel all the way out for just two weeks of storage. I now run out all gas in the EU1000. Lastly, it runs great on the lower Octane Unleaded (MN is also 10% Ethenol in all fuels). So I understand the head scratching. All I can say is that when I run mine in this manner, it runs like a champ. When I thought I knew better, and went back to my way, I was back to cleaning out the jets as it idled like a bad Model T. Do note that I have a 5 years old EU 1000. I believe they updated to model since then, so I cannot speak to whether the newer model requires the same treatment.
Old 05-12-2008, 10:56 AM
  #26
DFord79
DFord79's Avatar
Profile:  Currently Looking...
Yakima, Washington
I have used Sta-bil for 30 years. NO problems of any kind. I have many small engines from mowers, tillers etc. They always start easy for me in the spring. I just keep them clean and maintained and full of gas treated with Sta-bil over the winter.
YOU DO NOT NEED PREMIUM....in anything that is not specifically designed for premium. There are NO benifits. NOT my opionion but the advice of all manufacturers and information from Gas companys back up this.
Ethenol in an engine that is not designed for it causes problems with gaskets and fuel lines. My auto manual for my late model Ford Thunderbird say's DO NOT RUN MORE THAN 5% ethanol. My old truck started leaking fuel from the fuel lines just before that fuel tank. They were spongy and buldging. When I replaced the lines with new ones I took the old ones to a friend who works for Chevron. He told me the problem is ethanol in the gas I was burning. He was correct. I was using a cut rate gas with 10% ethanol. I stopped using that fuel and no more gas line deterioration. The newer cars that are flexfuel cars have fuel lines that will handle Ethanol without deterioration.
This all applies to small engines such as the Honda genny's.
One of the ways some gas is cheaper than others is they add ethanol to the limit allowed by the local or state regulations. Nothing wrong with ethanol of course as long as your vehicle/engine is designed for it. Ethanol also burns cleaner.
My friend at Chevron told me a rule of thumb is cheaper cut rate gas has more Ethanol in it. Also I found out that (all of us know) cut rate gas has the minimum additives allowed for the specific area it is sold in. This is the ONLY difference between cut rate and say...Chevron of Shell. But in the long run these cut rate gasses MIGHT????? cause some issues with clogged injectors and, and in my case with an old vehicle, some fuel line deterioration and dried up gaskets.
Old 05-12-2008, 04:13 PM
  #27
Beginner
Profile:  1984 31' Excella
Norfolk, Virginia
Gas
I can see that.
I have been buying Price Club Gas (COSTCO) for a couple of years. A friend that has a body shop tole me that he tried BP because of where the money goes (England Europe predominately).
He then noticed better milage and smother idle.
I got caught in a pinch Sunday and for the heck of it filled up at BP. Whin a couple of minutes I noticed a difference.
Today the 84 Camaro starts better and idles smother.
I'll let you know about the gas milage. Currently I get between 220 miles and 240 miles per fill up. We will see.
Old 05-12-2008, 04:33 PM
  #28
Pappy
Pappy's Avatar
Profile:  2006 25' Classic
Floyds Knobs, Indiana
Sta-bil
I have a 3 year old Honda Eu2000i which I start once a week.
I used some gas that had STA-BIL in it that was fresh and it stumbled.
The only way it would run was partial choke eco setting off. I let it
run for about 2 hours but it wouldn't run without partial choke. Dumped
the gas put in fresh ran it partially choked for about an hour now it runs
fine. I think there is something to the fact that STA-BIL seems to be
suspect here. For me no more STA-BIL in the Honda generator.
My 2 cents.
Pappy
vB code is On
Pingbacks are On
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
