Old 05-06-2005, 09:22 AM   #1
Entering the Generator World...
O.k now we are on to the generator.How does one learn the (math) to generator use?I need to know basic use to start out so I can then figure out which one to buy.Is there a book or method that I can use that is newbie proof?
cynthia is offline   Reply With Quote
Old 05-06-2005, 09:37 AM   #2
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
That depends...
I have been researching this for awhile now. There is a plethora of info on this forum. Generally, if you want to run the AC then you will need at least a 3000 watt generator. You could also run 2 of the Honda 2000EU's in tandem which is what many forum members are suggesting. The Hondas are supposed to be the quietest ones and the 2000EU's are very portable compared to a 3000 watt unit. Check this thread for lots more info.
Torii is offline   Reply With Quote
Old 05-06-2005, 09:44 AM   #3
7751
Torii's Avatar
1975 25' Tradewind
oops
I just re-read your question and realized that I didn't really address it in my reply. You are asking about the "math" or the calculations used to determine what you need in terms of generator output. I am not sure how that is done exactly. I assume that each item that you want to run will have a specific draw in terms of amps/watts. Perhaps someone with more electrical knowledge can explain this better for everyone's benefit.
Old 05-06-2005, 10:03 AM   #4
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Cynthia,
This is a common question, We decided to go with the 2 Honda EU 2000s. We can run everything except the A/C with one and run both when we need A/C. The Honda's weigh 47lbs each, so easy to lift and move around.
To figure how much power you need you take the rating of the generator for our EU 2000 max 2000 (watts divide by 120 = 16 amps max) Or more accurate rated output 1600 divided by 120 =13.3 amps. Each appliance has an amp rating so just add up the amps and decide how much power you need. As far as noise the Honda EU series are very quiet.
Good luck in your search. I enjoyed learning about all the choices out there. If you decide to buy this company was great for us.http://www.mayberrys.com/honda/gener...tgenerator.htm
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 05-06-2005, 10:32 AM   #5
Images: 59
Here is a good list of appliance loads: http://www.funroads.com/gensets/calcwattage.jhtml
. . . . and here is a selector program, although it applies to Onan, you can use it for other manufacturers if you find something of a similar size..
http://www.funroads.com/gensets/ogGensetSelector.jhtml#
Old 05-06-2005, 12:16 PM   #6
Wow got some great advice & directions to go in.
Thanks All!
Old 05-06-2005, 11:11 PM   #7
Tinsel Loaf's Avatar
Get yourself a copy of "Ugly's Electrical Referance" You will be able to figure out any electrical configuration.
Tinsel Loaf is offline   Reply With Quote
Breaking & Entering Navigator Doors & Locks 4 02-28-2004 07:34 AM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 11:01 AM
