Old 04-20-2019, 07:02 PM   #1
stevejones's Avatar
2019 27' Globetrotter
Martinsburg , West Virginia
EMS with Generator?
If you have an EMS device that you normally use for shore power, do you use it with your generator?
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4W LT
stevejones is offline   Reply With Quote
Old 04-20-2019, 08:10 PM   #2
2007 22' International CCD
EMS with Generator?
Same device. Mine is built in, and i always use mine with a 3400 Champion dual fuel inverter generator. With a slight modification on the generator.
Just add a neutral to ground jumper plug to the generator so the EMS operates properly. The EMS expects a ground to neutral connection outside the trailer, typically at a campground power pedestal or the main panel at home. The jumper makes the generator look like a standard, proper power source.
Portable Generators typically donít bond ground and neutral because they donít need to.
Doesnít matter if itís a contractor or inverter generator the ground to neutral connection makes them work correctly with an EMS.
Look in the forums for more details.
Old 04-21-2019, 04:50 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
No
My EMS is too sensitive to use with my generator. I have an Easy Start on my A/C, a 2k generator. Although I use a grounding plug the A/C start drops the voltage enough to trigger the EMS, but the generator recovers fine and runs the A/C so I do not use the EMS. You really do not need the same protection from a generator that you do from a campground. I suppose a larger generator would not give me the same result.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-21-2019, 06:05 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not use the portable EMS with the generator. The people who sold me the unit told me not to use it with the generator. I have one of the grounding plugs for the generator but so far have not used that either. The inverter generator is an EMS. sorta.
Old 04-21-2019, 06:47 AM   #5
Mollysdad's Avatar
Why do you use an EMS?
To protect your RV from things beyond your control?
When you're on your generator, you have control of everything, so I think a EMS is superfluous.
Old 04-28-2019, 08:36 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The main thing that is out of your control would be a generator failure that puts over voltage (or significant under voltage) on the line. I agree that this is a pretty rare occurrence.
Interstate EMS System Questions FlaBucki Sprinter and B-van Forum 5 04-08-2019 08:44 PM
Generator Working EMS won't come on. CaptainTina Electrical - Systems, Generators, Batteries & Solar 3 07-24-2018 05:43 AM
EMS delay with generator Titus Sprinter and B-van Forum 5 04-19-2016 04:51 AM
Ems-hw50c cwf Electronics & Connectivity 1 03-26-2015 03:58 PM
EMS from Progressive Industries markjoandall Electrical - Systems, Generators, Batteries & Solar 0 08-02-2005 07:14 AM
