Old 05-31-2011, 10:01 PM   #1
2006 16' Safari
Minden , Nevada
Eco-mode on or off?
I just bought a Honda 2000EU Companion generator to use with the standard 2000 watt Honda generator that I already own. I also purchased a parallel kit for them. My question is this. Can I run both generators in Eco-mode and still power up my A/C unit? I know the initial start-up takes a fair amount of amperage to get the compressor turning. My 30' has a 15000 btu A/C unit and my 16' has a 11000 btu A/C. Any help would be appreciated!
A/S Squared is offline   Reply With Quote
Old 06-01-2011, 05:22 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I turn the eco off any time I know i will be turning on a high demand accessory...just seems to relieve a little strain on the unit.
Any time you stress the AC start-up you chance shortening it's life.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-01-2011, 05:41 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What I have done with ours, is as Robert suggested. Turn off eco mode when you are going to start a high-demand device. If you're going to have the a/c running for a long time, like all day, you can switch on eco mode after the a/c has been running for a few minutes. That will reduce noise and wear on the generators, without stressing the a/c. The downside to this plan is, if the a/c cycles off, you will have to run outside to switch eco mode back off before the compressor comes back on.
Old 06-01-2011, 08:09 AM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I'm just curious about the two different generators you have... do they really parallel ok? Ones an EU and the other standard? Don't them make different "kinds" of electricity waves... one "clean" and one "dirty?"
Old 06-01-2011, 10:14 AM   #5
2008 19' International CCD
Spring , Texas
They are both the same generator; except that the EU Companion has a 30 AMP outlet. I believe that they both "pure sine wave" generators. I have both generators; they work perfectly for me.
Ed
eleighj is offline   Reply With Quote
Old 06-01-2011, 02:11 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Ed is correct. The "standard" is an EU2000i..and the "Companion" models is the same generator but with a 30 amp outlet incorporated. This makes paralleling much easy (you don't need the parallel "box" needed when paralleling 2 regular EU2000i gennies...just cables). We have both as well.
NOTE: With the Companion you DO need a small adapter that converts the generator's twist-n-lock 30-amp outlet to a standard 30-amp outlet required by your shore power cord.
TB & Greg and Abbey Schnauzer
#3954
Old 06-01-2011, 04:08 PM   #7
1975 Argosy 26
1963 24' Tradewind
Huh, learn something every day! That's kinda cool... I like the built in 30amp plug.
Thanks!
Marc
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
Honda EU2000i Benjo Generators & Solar Power 24 02-08-2012 06:41 AM
Honda EU2000i Vibrates in eco mode only? Patriot666 Mechanics Corner - Engines, Transmission & More... 11 05-10-2011 07:55 PM
Erratic Duotherm AC performance HCR Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-09-2011 01:28 PM
