Old 12-28-2015, 06:25 PM   #1
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Eco mode on 2 Honda 2000i and A/C
Does anyone here run 2 honda gens in parallel to run the A/C do you use eco mode or not? Will it stress the A/C too much or over load the gens? Thanks for any input. Good camping Rand
grizbear is offline   Reply With Quote
Old 12-28-2015, 06:38 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My opinion is that the gens take too long to speed up and that will result in low voltage and high current to the AC.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 12-28-2015, 06:41 PM   #3
1955 26' Cruiser/Overlander
Mena , Arkansas
You are not supposed to run parallels and use Eco-Throttle mode, but it can be done. What wattage is your AC, what is the startup (inductive) load in watts?
The EU2000i is really good at ramp-up times, its one of the features of the generator that the cheap copies don't have.
uc71953 is offline   Reply With Quote
Old 12-28-2015, 08:29 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I use ECO on mine. I turn it off on both, start them, let them equalize, start the air conditioner, then turn it back on.
And Honda stated having ECO on or off was less important than having it either on or off on both.
Old 12-28-2015, 08:50 PM   #5
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Thanks all I only have one now but was looking ahead to days I may need A/C. Thanks again
Old 12-28-2015, 09:43 PM   #6
Central , Mississippi
None of my AC's like the ECO mode, big surge, growl and grunt, finally the AC is running and the gen is spun up.
ECO off, a slight burp and things are running.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-29-2015, 11:10 AM   #7
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
I have the Yamaha Es2000i, similar gens, eco mode is used only if you are not using high current equipment such as AC or Microwave. I believe all gens have a delay delivering the power. It becomes a question of long will it last? If you are in the desert in the summer, leaving eco on will likely not engage since likely the AC will always be running and the gens will always be running high.
If you are just charging your batteries and running everything else besides AC and Microwave, use eco as it will help make your gens fuel last.
I saw these, Dual Fuel Extender for Generators, and have been trying to convince the wife to let me get one, with the yahama adaptor.
cazual6 is offline   Reply With Quote
Old 12-29-2015, 11:51 AM   #8
2000 30' Excella
Toledo , Ohio
I bought one of those for my Hondas ran AC for 12 hrs. only used 3 gal's of gas very well worth it .
woodfox45 is offline   Reply With Quote
Old 12-29-2015, 02:53 PM   #9
SKEETER's Avatar
2016 30' Classic
SAN ANTONIO , Texas
I don't run my paralled Hondo 2000 on econo mode.
SKEETER is offline   Reply With Quote
Old 12-29-2015, 03:00 PM   #10
2015 30' International
FREDERICK , Maryland
I don't either. Was told the A/C "would not like it".
With an extender gas tank I can get over 12 hours with the A/C running full blast.
Doc Foster is offline   Reply With Quote
Old 12-29-2015, 04:27 PM   #11
2007 25' Safari
Attleboro , Massachusetts
I sold my EB3000 since it was too heavy to get into my pickup truck bed by myself and bought a pair of EU2000's. I've never thought about it, I just always used them on eco and they work fine. But here's a suggestion for keeping them dry at night and during the rain. This is a four foot table from BJs wholesale club(like Costco) that cost $30 and fits perfectly(has adjustable legs) and doesn't compromise ventilation.
romeb is offline   Reply With Quote
Old 12-29-2015, 04:28 PM   #12
2007 25' Safari
I thought I posted a picture....not sure why it doesn't show.
Old 12-30-2015, 06:34 AM   #13
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I always run my Honda's on Eco mode, saves noise and gas. Have ran them this way for over 4 years with no trouble. No problem when A/C starts.
larryglarson is offline   Reply With Quote
Old 12-30-2015, 04:28 PM   #14
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
I have two Honda 2000 generators and have used them in tandem to power my AC. I fire up the generators in Eco mode then turn on the AC. I've had no problems. Another option if you're concerned would be to power up the generators with the Eco mode off. Turn on the AC. Then, once the AC is running, turn on the Eco mode on both generators. They'll be there with full power when the AC needs more juice at start up, then they'll settle in to the running speed needed to power the AC after start up.
Nomad518 is offline   Reply With Quote
Two Honda EU2000s, Eco mode, and A/C barrettjl Generators & Solar Power 13 Today 09:32 AM
Honda 3000is vs 2x Honda 2000i ILOVESALLY On The Road... 64 05-16-2014 09:13 AM
Paralleling Honda 2000i, and Eco system Headhog Generators & Solar Power 18 09-17-2011 04:04 PM
Honda EU2000i Vibrates in eco mode only? Patriot666 Mechanics Corner - Engines, Transmission & More... 11 05-10-2011 07:55 PM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 02:53 PM
