Old 06-21-2003, 07:27 AM   #15
LOST , Hawaii
but what happens when you have weather like we've been having here in the northeast?
It it is not only the weather that hurts solar. Boondocking to me usually is back in the woods and all the shade really hurts solar, it is not a really an efficient means of electrical production for an a RV. The panels are fixed and no consideration is given to solar when sites are established.
A generator is necessary for extended stays. I would look for one of the 1800 rpm engines, noise is cut in half by reducing the rpm's and the life is longer. On the downside these are usually Kohler or Onan and they are heavy compared to B&S. The alternator does neeed to turn faster than this but that can be done with pulley ratios.
Supertrapp makes some awesome mufflers. They have a website but it is cars and bikes. They actually make mufflers for everything from small gas engines to large stationary diesels. I can stand next to my 4 kw onan and speak at a normal level.
John
74Argosy24MH is offline   Reply With Quote
Old 06-21-2003, 08:06 AM   #16
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
speaking of sparks...
one other thing to consider is a spark arrestor when camping on federal lands or any where else for that matter.
wouldn't want to be responsible for a fire like they have in arizona now
john
Old 06-23-2003, 08:55 AM   #17
H.P. needed per KW
in a previous post:
"a good rule of thumb to follow is 750 watts per horsepower. "
Actually, this is not the case.
Yes, it is true that there are about 745 watts per 1 horse power. However, alternators aren't 100% efficient, so, the generator industry uses a 500 watts per horse power rule of thumb.
So, a 3 h.p. Briggs would be rated as adequate for a 1500 watt generator.
Marc Denis
a wannabee full timer
working on the road
mldenis is offline   Reply With Quote
Old 06-23-2003, 09:42 AM   #18
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
good point
marc
good point on the losses, the rule of thumb i was reffering to was for transformers.
most of them are around 86% efficent anyway. the other 15% is copper/core losses and heat.
your formula would be better because it would take into account reactive losses.
it takes power to push reactive load as well as resistive load.
at the power company we spend millions to eliminate reactive (var) loads with capacitor banks.
the 500 watt rule would give one enough headroom in a genset to prevent wearing/burning it out.
john
Old 06-23-2003, 01:25 PM   #19
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Here's a site that may help in the generator project:
Home made generator parts
How to Generator Page
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-23-2003, 05:45 PM   #20
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
cool links!
pick
cool links!
john
Old 06-24-2003, 03:16 AM   #21
sjptak's Avatar
GREAT links!! I visited the epicenter and saw a couple of books that I may add to my "how to" library. John, Pick, If I do this with a GM alternator with a built in regulator, will I have to be concerned with overhcarging?
Stan and the Lou
Together Forever
BTW, that's MaryLou
sjptak is offline   Reply With Quote
Old 06-24-2003, 04:41 AM   #22
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
stan
i don't think you would need to worry about overcharging.
you could add a 5 dollar shunt ammeter into the charge line to be sure.
john
Old 06-24-2003, 05:24 AM   #23
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Very, very cool links Pic! I feel like I just took a community college class in power generation!
I have a motor laying around somewhere, maybe I'll play around with it... in the meantime, I think I may be Honda 1000 bound.
Eric
