Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 01-09-2020, 06:37 PM   #1
2019 25' International
Colorado Springs , Colorado
Does Renogy suitcase need an adapter for solar port?
For those of you using the Renogy suitcase solar panels.... is an adapter needed to plug it into the factory solar port on newer Airstream trailers? I've read that a polarity adapter may be needed but haven't been able to get confirmation on exactly what is required. Part numbers or Amazon links are always appreciated.
Thanks.
Xbc3 is offline   Reply With Quote
Old 01-09-2020, 06:46 PM   #2
2020 25' Globetrotter
Los Gatos , California
This
https://www.renogy.com/mc4-to-sae-adapter-12-awg-cable/
And polarity reverse adapter
Garfish is offline   Reply With Quote
Old 01-09-2020, 06:47 PM   #3
And this
https://www.zampsolar.com/polaroty-adapter
Note that Renogy must be one with built in controller. Unless you have roof solar already the solar connectors on the roof do not connect to anything yet
Old 01-09-2020, 09:01 PM   #4
Originally Posted by Garfish View Post
And this
Yes. The suitcase I’m looking at does have a controller. Thank you!
Old 01-10-2020, 04:26 AM   #5
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
I have a Renogy suitcase, but my trailer is older and does not have a factory solar port. But it looks like those other links are for the same parts I bought for my setup. Would this accomplish the same thing as those?
https://smile.amazon.com/gp/product/B07K8GMRDJ/
teagues is offline   Reply With Quote
Old 01-10-2020, 06:58 AM   #6
TCwheels's Avatar
Traverse City , Michigan
I have the 200 watt Renogy suitcase with controller. Connected directly to the batteries. Works great.
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 01-10-2020, 12:26 PM   #7
Philadelphia , Pennsylvania
And this
I'm taking liberty to jump on this thread and ask a related question - if you DO have factory installed roof solar but want to add a suitcase panel to the port (which I understand will work INSTEAD of roof panel NOT at same time as roof panel) - does the suitcase need its own controller too?
Czarina is offline   Reply With Quote
Old 01-10-2020, 03:48 PM   #8
2018 16' Sport
St. Louis , Missouri
Others can answer as well. If your current controller is large enough you can take a suitcase without a controller run wires thru existing hole with the battery cables and splice into the wires from the rooftop panels. Use a 3 way connector. Simpler and more efficient when using one controller. I am not an electrical expert and it was a fairly easy job.
Sport 16 STL is offline   Reply With Quote
Old 01-10-2020, 05:52 PM   #9
Yes, will work
Old 01-10-2020, 06:02 PM   #10
Renogy suitcase can be wired in parallel if you have roof panels but needs to be suitcase without controller as two will fight each other. There were 3 plugs on roof so fixed panels in parallel into one plug and suitcase into second plug. All are now in parallel. I did this on my 22 and had MC4 connector on roof and just plugged the suitcase in with long extension and moved to sun. Got 300 watts that way all going through roof connector to Victron solar controller under bed. Also could plug in 2nd suitcase with controller to 7 PIN (had to fashion the adapter). Did not interfer with roof controller.
Old 01-10-2020, 07:58 PM   #11
Thanks.
That looks like it would be perfect! Thank you!
Old 05-06-2020, 05:22 PM   #12
TCwheels's Avatar
What problems might be caused with my factory solar system if I direct connect the Renology suitcase panels to the batteries through their own controller. The batteries don’t care where or from how many sources they get their juice, do they?
Old 05-06-2020, 05:47 PM   #13
"Cloudsplitter"
No, they don't.
I charge with two 180w Suitcase panels directly to the batteries thru the 7pin umbilical cord.
ID:	367398   Click image for larger version
Old 05-06-2020, 06:01 PM   #14
Originally Posted by ROBERT CROSS View Post
No, they don't.
7 pin is a great way to do but if you use a Renogy then you need to splice in MC4 cable to 7 pin like I did. The 7 pin adapter in pic is for Zamp only I believe
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
Renogy Solar Suitcase Problem & Solution DaveP Generators & Solar Power 1 11-11-2019 08:34 AM
Test of Renogy 100w Eclipse Suitcase w/Voyager Con blacklab Generators & Solar Power 13 07-26-2019 05:32 PM
Renogy 100 Watts 12 Volts Monocrystalline Foldable Solar Suitcase Panels jamienate Airstream Classifieds 0 07-01-2018 03:39 PM
Connecting Renogy Suitcase to Zamp connection on 2017 Flying Cloud D44 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2017 11:43 AM
Renogy 100 watt suitcase AWCHIEF Generators & Solar Power 24 02-07-2016 08:25 AM
