Old 06-16-2019, 06:51 PM   #1
2013 28' International
Bozeman , Montana
Disabling new Ford's charging circuit
Has anyone come up with a way to disable the new Ford trucks trailer battery charging circuit? We just had Lewster work his magic on our International with 700 watts of solar, Victron chargers, larger AGM's, etc. I do not want our 2017 F350 to be putting a pretty much unregulated charge on our new batteries.
The newer Superduty's and apparently the current generation F150's do not have a trailer battery charge relay nor a corresponding fuse installed (they are listed in the manual but nether are present on our truck). However, the have some type of trailer control module and do make the charge circuit live when sensing a trailer which I have verified.
Any suggestions on killing off the charge circuit would be appreciated. I'm very concerned with all the auto sensing stuff going on with a newer vehicle that I could create other problems if I attempt some type of mod on the truck. At the moment, I'm thinking my safest bet is to disconnect the positive charge wire on the ubilical cord at the trailer junction box.
Any thoughts or experience with this would be most appreciated.
HeadWest is offline   Reply With Quote
Old 06-16-2019, 07:32 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Did Lewster install a DC - DC converter or its equivalent? That controls any charging to your trailer batteries from the TV (it is adjusted to only supply within the range your batteries' specs require for charging). Mine system is 2 years old (all purchased through AM Solar) and at that time they used an Orion DC-DC converter, not sure what is the replacement now. Victron has updated a lot of the equipment since I purchased.
Suggest you contact Lew and get clarification.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 06-16-2019, 09:05 PM   #3
Paradise , Texas
Or, just open up the 7 way junction box in the front of your trailer, pull the black wire out of it and cap it. If things are set up properly, you won't have any issues running the jack or breakaway switch with your capacity.this way, you can still pull other trailers with no issues, and no other tow vehicle will damage yours.
Crackerman is offline   Reply With Quote
Old 06-17-2019, 12:28 AM   #4
2018 25' Flying Cloud
Portland , Oregon
I ran my 7pin cableís charge line through a Victron Omicron to charge our batteries but we have Lithium so the TV line needed boosting and regulating. With AGM I doubt the truck would hurt anything but if you are worried, yes, pull the aux charging line.
daleyocum is offline   Reply With Quote
Old 06-17-2019, 09:59 AM   #5
2016 25' Flying Cloud
Holly Springs , Mississippi
Look in your owner's manual. I bet you will find that there is a fuse that, if removed, will disable the charging circuit. It's one of those square, black "box"-looking fuses.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 06-17-2019, 10:48 AM   #6
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Yes, what Crackerman said.
jimfa440 is offline   Reply With Quote
Old 06-17-2019, 02:31 PM   #7
1976 31' Excella 500
Chappell Hill , Texas
"Or, just open up the 7 way junction box in the front of your trailer, pull the black wire out of it and cap it"
Or put an on/off switch on the trailer's black wire.
tbashin is offline   Reply With Quote
Old 06-17-2019, 03:10 PM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
For whatever reason the fuse locations shown in the owner's manual are incorrect. They have been incorrect for .... errr ... a while now. Just why Ford can't get them right ... no idea.
As mentioned above, better to cap the wire off the 7 pin or put in a DC/DC converter than to mess with the truck.
Old 06-17-2019, 10:51 PM   #9
Bozeman , Montana
Thanks all. Yes, Iím going to cap the wire on the 7 pin and leave the truck alone. Seems like my best option and no I donít have a dc/dc converter.
Old 06-18-2019, 09:06 AM   #10
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Lewster disconnected the truck's charging capability to my unit - I'd be real surprised if he did not do so for you.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-19-2019, 06:42 AM   #11
Half a Rivet Short
Hi
The DC/DC converters are a < $100 sort of option. Putting one in isn't much more work than digging in to disconnect the cable.
Disabling CO detector elgo Sprinter and B-van Forum 11 09-30-2017 10:35 AM
Disabling electric jack StreamAholic Towing, Tow Vehicles & Hitches 5 04-12-2015 04:35 PM
Trailer charging circuit from TV HowieE Lights - Interior & Exterior 11 04-19-2014 09:26 AM
Charging Circuit woes ralley Mechanics Corner - Engines, Transmission & More... 2 08-28-2006 07:16 PM
Disabling Tongue Jack Cracker Jacks, Stabilizers, Lifting and Leveling 10 11-14-2003 11:32 AM
