Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 11-27-2007, 07:46 PM   #15
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by Darol Ingalls
...the simplest solution is to keep the batteries warm...
a really agree with ya darol!
the heater venting is a great idea, you custom crafter...
with the agm batteries they could/should have an insulated/ducted/venting adjustable compartment,
instead of being way out front which is the absolutely farther-est distance from the home fire...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-22-2007, 11:01 PM   #16
akbearpaw
Profile:  Wasilla , Alaska
Thanks Darol for the ideas for cold weather battery tips. We just spent a night at -26 in our stationary 79 Sovereign and the (new) 40K furnace had to run all the time, never would have made it through the night without the Honda 2000. There are a few air leaks, mainly around the venting for the Univolt box. The Univolt wasn't working anyway and got removed a while ago, but the box was still in. After sealing the drafts my plan is to put the 2 group 24 batteries in sealed and vented boxes inside the heated area, and look for a small Toyo or similar that will draw a fraction of the 9.5 amps that the furnace uses. Of course we would need a true sine wave inverter to power a Toyo. Might even go with a non-electric LP heater. Have you heard of anyone else using an alternate heat source like this? We plan to use the trailer all winter and this seemed like a way to minimize need for battery draw. We are using the TT a few days every couple weeks and take the batteries home when we leave to keep them charged. We don't use the water system so don't have a need to keep pipes warm.
I have questions about the heat output of the furnace (85 degree air at -15 outside/+60 inside) but still have to research if that is normal.
Dan
akbearpaw is offline   Reply With Quote
Old 12-22-2007, 11:23 PM   #17
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Thank you, Rodney, Bryan, Darol and air2...for all this great information. There is much of it that I don't understand being a relative novice to this stuff, but at least I know who to ask and where to go for answers if i get stumped.
One thing that I learned that is comforting: I am not the only thing that changes as it ages...batteries do too!
Really, though, thanks for all this. We are not heavy into boon docking at this point, but it is calling, and the more I can learn the more comfortable I will feel when we go off the grid.
TB
TB & Greg...Cockers Annie & Sadie...and Homer the Desert Tortoise
WBCCI Four Corners Unit #3954
AirForums #21900
Please Visit Our...
Décor Site: AZBambi Décors
RVing in Cold Weather harryp Winter Living 30 04-06-2007 12:14 PM
Cold weather and diesels BillTex On The Road... 63 02-10-2007 11:25 PM
Cold weather Streamin' BillTex Off Topic Forum 6 01-18-2007 11:34 PM
Cold Weather Airstreaming gryphon Winter Living 38 04-16-2006 08:16 AM
Battery Bank Tarheel Batteries, Univolts, Converters & Inverters 19 03-06-2004 02:48 PM
