Old 06-03-2010, 02:59 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Charging battery from TV & generator ?ís
My TV is a 2005 Silverado, it is my understanding that when the battery is charged the alternator drops the current below charging level. If this is the case how do I charge my trailer battery when towing or is my Inteli power 9200 series converter doing the charging, is the 12 volt power at the trailer plug independent of the charge system on the truck. Iím confused.
Second question is there a 120 volt generator that can be mounted directly to the engine in my truck. I like the idea of having the generator permanently attached to the truck as appose to lugging a separate generator around. I would like to be able to use this to power the house in the event of a power outage also.
I know I can put an inverter in but isnít a generator more efficient.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 06-03-2010, 04:21 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The cost and the space required just about cuts out the generator in the truck. You could mount an inverter that would give you 120 but there are limits there.
Yes the alternate will drop back as soon as the voltage to the field is up thus halting the high charge rate generally put out after stating the truck. Now while on the road and any load is put on the truck battery the charge rate will go up again and all batteries will benefit with the trailer batteries getting a lower rate because of voltage loss in the length of the wires to the trailer.
About the only way to guarantee you are charging the trailer battery wile driving would be to install a second alternator and have it wired so it only sees the trailer batteries.
Do not get sold on a so called trailer battery Isolator. There is a diode in all of them and the voltage drop across a diode is .7 of a volt thus you are at a loss before you start, but Camper World has to make a buck some how.
2004 Excursion 4x4
Old 06-03-2010, 04:33 PM   #3
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
There are Power-Take-Off generators, but I can't imagine they'd be very cost effective without a diesel truck
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 06-05-2010, 11:02 PM   #4
san diego , California
what about running a invertor in the TV to run a battery charger in the trailer
Life's a dance, you learn as you go....
Finch is offline   Reply With Quote
Old 06-05-2010, 11:33 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Too many inefficiencies in this plan -- inverting to AC through small wires from cig lighter and converting back to DC. Length of the wiring runs would only compound the problem.
Alternator output has a variable and frequently fairly small excess of amps that it can spare for the umbilical. Allowing for a 50% discharged deep cycle coach battery (the most you'd want to discharge a lead-acid on a routine basis), word of mouth is that we shouldn't expect substantial coach battery recharge until a couple hundred or more miles have been driven. Results may vary depending on whether the alternator is being hit up to run headlights and air conditioning too.
5 meter Langford Nahanni
Old 06-06-2010, 09:53 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
This used to be true but isn't, necessarily, any more, though there are still cheap diode isolators out there. Avoid them.
There are two other kinds.
One uses a MOSFET or similar device to do the switching. These are semiconductors, but don't have an NP junction like a diode. No junction, no diode drop. The problem with them is that they are expensive and are easily damaged by overcurrent, and the ones that are big enough to handle a short long enough for the fuse to blow are really expensive.
The other kind uses a big relay, operated by logic of varying sophistication. The simplest of these close when the voltage goes up above 13.5 or so and open when it goes below 12.7. Others incorporate time delays to minimize nuisance cycling.
Batteries Not Charging With Generator timkim Batteries, Univolts, Converters & Inverters 5 08-09-2009 06:30 PM
Generator charging one battery and draining the other dalefox Classic Motorhomes 19 05-15-2009 10:54 AM
MH/Battery Charging? 345bill Classic Motorhomes 4 11-06-2008 12:13 AM
Battery charging tip & tricks... ostream Electrical - Systems, Generators, Batteries & Solar 2 10-12-2008 02:39 PM
Battery charging Dr Dan Electrical - Systems, Generators, Batteries & Solar 6 10-05-2008 06:04 PM
