Old 11-24-2015, 03:38 PM   #15
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
You'll need to accessorize that Honda generator. You need an adaptor for 30-amp to 20-amp, maybe a short 20-amp extension cord if you don't want to drag out your 30-amp cord, plasticized cable and heavy lock, gas can, high-test ethylene-free gas, stabilizer, oil and oil-changing apparatus, etc., etc., etc. And you'll need to run that generator every month for 15 minutes, year round. If you don't, it won't start when you need it. Hauling a small generator or two is no small commitment in time, energy and cash.
JBinKC is offline   Reply With Quote
Old 11-24-2015, 03:46 PM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
No need to make things more complicated than they are. It can be hard to find ethANOL-free gas at the drop of a hat, but if you burn all the gas in the tank before storage it's not a big issue. (One reason I prefer Yamaha generators is that they all have fuel shut-off valves so I can easily burn all the gas out of the carburetor at every shut-down.) If by "high-test" you mean high octane, I don't think that matters at all for any of the consumer-available generators. I burn the same regular unleaded in my Yamaha that I put in the F150.
Yes you'll need an adapter from the 30A twist-lock to a 30A RV socket, and a cable and lock is a great idea if you'd like to keep it, but you need that for a good bicycle as well.
David
Old 11-24-2015, 06:05 PM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am currently using a charger, but I have a new converter that I will install when I get home.
I installed the charger because I had it and I was being cheap, but overall it was a bad compromise and generally a bad idea.
Brevi tempore!
Old 11-27-2015, 09:15 AM   #18
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I see Battery charges on special for very little money. Yes, I would get a 2000 and then plug the Battery charger into the generator after reading A/S instructions for charging batteries.
larryglarson is offline   Reply With Quote
Old 01-10-2016, 12:36 PM   #19
2014 23' Flying Cloud
Park City , Utah
Test
Test
pcskier is offline   Reply With Quote
Old 01-10-2016, 01:42 PM   #20
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I think you'll be happy you bought the 2000 watt.
I bought mine for use power the trailer when needed but have also found it handy in teh event of power failures at home, and also to use in places where 110v is not readily available to run power tools up to and including a small 140amp mig welder I have.
I have ever used the DC 8 amp output - I just plug the trailer into teh gennie and use teh 50 amp charger in the trailer.
Incidentally we also have just the basic charger in the trailer as originally equipped and so if we camp any place on shore power, I disconnect the batteries to avoid any chance of
"cooking" them with the the trailer's charger.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-11-2016, 04:09 AM   #21
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Wow, air conditioning is really nice and then there are coffee makers and toasters etc. With my twin 2000 I have it all. Just plug int he shore cord and off we go.
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 28 12-16-2017 06:32 AM
Charging batteries w/ generator Skee75 Electrical - Systems, Generators, Batteries & Solar 1 04-20-2015 09:59 PM
Generator not charging batteries r.i.p._FZ Land Yacht/Legacy Motorhomes 13 02-27-2015 06:58 AM
Batteries Not Charging With Generator timkim Batteries, Univolts, Converters & Inverters 5 08-09-2009 06:30 PM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
