Old 03-29-2017, 06:09 PM   #81
2014 25' FB Flying Cloud
Grand Rapids , Michigan
Now Costco has a sale running on their dual fuel unit.
https://www.costco.com/Champion-DUAL...100284958.html
MIFC is offline   Reply With Quote
Old 03-29-2017, 09:16 PM   #82
Rob Edgerton's Avatar
2020 25' Flying Cloud
Yamhill , Oregon
Originally Posted by Roadtech View Post
I have not tried it yet, but I have read on this forum and rv.net forum from several Champion users that they are successfully running the 3400/3500 Champions directly from the Airstream low pressure port without any additional regulator between the AS port and the generator. One person said they did have to close the propane tank shutoff valve slightly to get it to run "smoothly". I will be trying this in the next few days and will report back.
Got my Costco 3100 dual fuel yesterday. Made up the quick disconnect hose, but can't get it to start. Runs great on the tank and regulator. How far are you opening the valve? When I open the valve all the way I hear gas flowing. Do I need to connect the large regulator?
Rob Edgerton is offline   Reply With Quote
Old 03-29-2017, 09:44 PM   #83
mojoe7009's Avatar
Green Cove Springs , Florida
Don't open the gas all the way. I opened mine about 2/3rds. Once it cranked it started surging. By slowly closing the valve down, a little bit at a time, I found the sweet spot where it purred like a kitten.
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 03-30-2017, 05:30 AM   #84
2023 23' International
Macon , Georgia
I had a 20 foot propane hose made up with quick connects on both ends. After reading Mojoe's experience having to close down the tank valve, I had the bright idea of adding a valve (same connection size as the hose) in the hose about 2 feet from one end, so I could adjust it at the generator and not have to go to the tank valve. That was a mistake. I think there was too much pressure drop across the valve. The engine ran smooth but noticeably quieter than it does with the tank and Champion regulator. I took that to mean it was somewhat fuel starved and running at lower hp. I removed the valve and it runs great now by adjusting the tank valve.
Roadtech is offline   Reply With Quote
Old 03-30-2017, 08:00 PM   #85
Yamhill , Oregon
So here are pictures of how I plumbed mine up today.
Unscrewed the first high pressure regulator and tank connection from the second regulator. Bought two quick connect sets. First female connector along with a 1/8"x1/4" FxM to attach QC to the regulator. I replaced the cheap 1/4" valve and QC from airstream with a new one from the propane supplier. They also made up the 3/8" hose with 1/4" male QC's for me. Works perfect. No messing with the valve just connect, open the valve and crank it up.
Old 05-02-2017, 08:25 PM   #86
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Rob, Very nice. If I were going to run off the quick disconnect port that is exactly what I would do. I decided to run my generator off a propane tank so I built a high pressure 15' extension hose with an LP tank female connection on the bottle side and a LP tank male bottle connector that connects to the high pressure hose supplied with the generator.
I also tested my Champion 100263 Dual fuel inverter generator with my 15000 BTU Airstream AC tonight. It ran at a slightly higher RPM than with my 11500 BTU Casita AC at near idle. This also increased the sound level to 70 DB near the side of the pickup truck bed with the generator running the AC and refrigerator. The DBs dropped to 60 to 65 DB under the awning (also picking up the AC noise) and 55 DB at about 25'. The surrounding noise level was about 50 DB so again after about 30' the generator sound begins to be overtaken by other noises. I think these sound levels agree with what others have reported testing this model generator with an Airstream.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 05-12-2017, 07:19 AM   #87
FCStreamer's Avatar
2014 30' Flying Cloud
This just posted. A review of the 3100. Interesting.
https://youtu.be/00fkBB3IZrU
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-13-2017, 05:38 AM   #88
mojoe7009's Avatar
I have the 3500 watt dual fuel and love it. Pretty much the same experience as the video describes except more power and having the dual fuel allows me to not carry gasoline. The 3500 can be paralleled if required. One of the primary purchase decisions was having a generator that fit under my locking bed cover. The price was also right. Honda and Yamaha make great gensets but I am completely happy with my Champion.
Old 05-13-2017, 08:47 AM   #89
ObviouslyKnot
james.mileur's Avatar
KAILUA , HI
Originally Posted by AirMiles View Post
Champion 100263 3400 Watt vs 100264 3500 Watt
http://www.championpowerequipment.co...2Finverters%2F
Only difference I see is that the 3400 Watt weighs less than 1 lb. more. Same horsepower engine and every other specification.
The 3100 specs are quite different. Smaller engine, longer runtime and 1.1 lb heavier.
I chose the 3400 because I could see the horsepower difference from the 3100 in the specs and felt 10% more wattage was significant. I believe the 3100 says it will run a 13,500 BTU A/C versus the 3400 saying it will run a 15,000 BTU.
I chose to save money with the 3400 versus the 3500 because I saw the same engine size and they both say they will run a 15,000 BTU A/C.
On the Champion website FAQ or maybe in an email with Champion, I was told the Retailer asked for the 3500 version to be relabeled as a 3400w. They said not uncommon, so customers will be impressed and not try to overload as much?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 05-13-2017, 09:04 AM   #90
mojoe7009's Avatar
The 3500 and the 3400 are essentially the same units. Camping World gets them labeled as 3500's. That's where I got mine but I caught it on a great sale for a grand with the free shipping.
Old 06-13-2017, 01:25 PM   #91
mojoe7009's Avatar
Attachment 282436Attachment 282437
Where did you purchase the parts? I've been to three propane suppliers to no avail. I would like to make the same set up for my Champion. Already have the hose and male quick connects.
Old 06-13-2017, 02:37 PM   #92
mojoe7009's Avatar
Old 06-14-2017, 11:14 AM   #93
Yamhill , Oregon
I went to BlueStar Propane who is a local commercial/residential supplier. The made up the hose and ha the male/female connectors and the new valve. You can also find the fittings on Amazon.
Any reputable bulk propane vendor who sells appliances will have the fittings.
Old 06-14-2017, 01:53 PM   #94
Crazycanucks's Avatar
2016 26' Flying Cloud
Oxford Mills , Ontario
Not powering my 15k AC unit ?
My duel fuel unit is not powering my 26U 's AC unit ? Tried with propane and it set the red light off on the generator, and sent code E7 to the Dometic.
Put gas in it for the first time to get the extra power and the generator keeps red lighting , but the E7 code is gone. Nothing else is on in the AS.
Does it make a difference in I plug in from the front outlet or the rear side ?
Suggestions welcomed .
It did work in a dry run in my lane way when the temp was mid 70's ran the AC for an hour on propane , sitting in Dovet DE today at 81 but almost 💯 humidity.......
Crazycanucks is offline   Reply With Quote
Old 06-14-2017, 03:35 PM   #95
mojoe7009's Avatar
I've been to four major bulk propane vendors and they all look at me like I have 3 heads. All I need is the adapter and the quick connect you used on the generator regulator. I already have the 20 ft. hose with the male quick connects on each end.
Old 06-14-2017, 03:55 PM   #96
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Maybe it's a Florida thing. I couldn't find anyone around here in Jupiter to help either. "It's for an RV? Sorry, I can't even talk to you."
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 06-14-2017, 05:39 PM   #97
mojoe7009's Avatar
It's North Carolina too!
Old 06-15-2017, 05:48 AM   #98
ObviouslyKnot
KAILUA , HI
Google MB STURGIS fittings and/or shop at etrailer.com for 1/4 inch lpg fittings.
Old 06-15-2017, 01:54 PM   #99
2016 30' International
redondo beach , California
I used JME Ellsworth for propane hoses and propane quick connects.
You can use flare fittings or NPT fittings with pipe dope for propane plumbing.
http://www.jmesales.com/Default.aspx
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 11-01-2017, 09:10 AM   #100
c3po's Avatar
2017 25' Flying Cloud
McDonough , Georgia
Champion Generator Model 100263 VS 100264
Originally Posted by Crazycanucks View Post
The 3400/3500 decal difference is more likely part of an agreement with the retailer(s) / mfg to have an exclusive product and not be as easily price compared ( because we consumers can't tell the difference)
Crazycanucks is correct, and you can read it if you go to the Model #100263
3400-Watt Dual Fuel Inverter Q&A. FYI, I couldn't copy/paste it to post here.
https://www.championpowerequipment.c...fuel-inverter/
c3po is offline   Reply With Quote
Champion Dual Fuel Generator - What do you think? trekerboy Generators & Solar Power 40 01-16-2018 10:41 PM
2001 airstream safari bambi 19' rear bed 1/2 ton tow bath shower 3400 lbs rv nr eBay Watch Airstreams on eBay 0 09-17-2013 06:40 PM
Removing dual fuel QuietWater General Motorhome Topics 0 08-09-2011 09:14 AM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Dual Fuel Gas regulator thenewkid64 LP Gas, Piping, Tanks & Regulators 5 03-12-2003 02:26 PM
