Old 11-19-2011, 05:07 AM   #15
r carl's Avatar
Lin , Ne
He used the original 15ga 4x4 square tube bumper that is paper thin to bolt all that crap to. Look on the bumper where it was welded to the frame, there is 2 holes. If he would have cut off the original bumper and used 4x4 3/16 wall tube it would of worked. He was just smart enuff to get himself in a lot of trouble.
Old 11-19-2011, 07:34 AM   #16
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I offer this input. I am guilty of the same mistake in the picture. I was hunting in Colorado and had a fifth wheel at the time. I needed a way to haul an ATV with me.
I simply U-Bolted a receiver hitch to the stock rear bumper of the trailer, loaded a mid-sized ATV on a 5x8 small utility trailer and took off from Arkansas to Colorado. I made it to Colby, KS where I stopped to eat and refuel. We walked around the rig, and as part of the “safety check” kicked the rear bumper of the fifth wheel witch almost fell off the trailer.
As mentioned previously, the light gauge tubing had torn away from the frame rails at the welds and was about to fall off. Luckily, Colby is a farming town and a kind hearted welding shop welded a section of heavy walled tubing back in place and off we went.
As to bolting something to the bumper of an Airstream, SOB trailers in the above stories are a “body on frame” design. The frame is intended to provide all the strength The walls and floor simply sit on the frame. The frame is heavy enough to tolerate additional loads.
An Airstream is entirely different. The frame is lighter and the “bubble” is intended to carry much of the load. The tanks in modern trailers are below the floor, and over the axels to let their weight ride in supports right above the axel. Not the skins.
I am a fan of the rear bath, I like the room. But look around. They take very special care and feeding to remain road worthy.
Some light loads like bicycles seem work, at least for a while. But, no equipment racks of any kind on the back of my AS.
Best of luck with any choice one may make,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-19-2011, 09:17 AM   #17
1994 30' Excella
Mississauga , Ontario
That is a white box trailer. Their frame actually supports the trailer whereas the Airstream monocoque type of shell construction helps the frame to support the complete structure.
I wouldn't add any weight at the rear of an Airstream.
Al
Al and Jean
TAC ON-3
Old 11-19-2011, 09:44 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Why not just get a good container and carry it in the AS or TV?
ActionPacker Werks 'fer us. No smell, no worry.
Bob.
Name:	HONDA CONVERSION add vid pix2-3 006.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-19-2011, 10:05 AM   #19
r carl's Avatar
Lin , Ne
Bob.
And it wont disappear off your bumper.
Old 11-19-2011, 10:40 AM   #20
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I say go ahead and mount it on the bumper. A 5 gallon gas can next to it would be cool. We need to keep this economy going somehow. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 11-20-2011, 09:48 AM   #21
1969 27' Overlander
Albuquerque , New Mexico
This is all important information, and I appreciate it.
I will examine the rear frame assembly carefully before "ass-uming" it can be done.
My instinct is that an additional 50lbs at close proximity to the rear cargo hatch shouldn't be impossible. How the bumper assembly is fastened to the frame is another issue.
Also, I already removed 40 lbs by relocating the group 27 battery from the cargo area. This should help.
I didn't know the waste tanks should be dumped before travel!
edglenn is offline   Reply With Quote
Old 11-20-2011, 10:25 AM   #22
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Back to the original topic... anyone considering getting one or two of these Champion generators from Costco should move quickly. I noticed yesterday at Costco that the price label on the rack for these generators had an asterisk in the upper-right corner, which is Costco code for an item they're selling down and won't restock. Sometimes when this happens it's being replaced with an updated SKU, but often they're just discontinuing it.
David
Old 11-20-2011, 11:16 AM   #23
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I'm as contrary as anyone, and mostly have to prove to myself that a thing is impossable before I accept it. I am also a certified welder and fabricater by trade. That being said in my opinion the amount of fabricating nessisary to stiffen the rear bumper in order to hold any additional weight is not worth the time & effort. Adios, John
Diesel1 is offline   Reply With Quote
Old 11-21-2011, 11:17 AM   #24
r carl's Avatar
Lin , Ne
Welding a 4x4x1/16 tube to the ends of the 6' I beam frame is a piece of cake for a welder John, weld a 3/8 plate to the ends of the I beam and then weld the tube to the plate. Thats enough for 100# of weight hanging behind the bumper.
Old 11-21-2011, 12:30 PM   #25
But I/we ask why?
So many easier, safer and more secure ways to transport.
Plus it adds nothing to the aesthetics.
PFC
"Tahawus"
RLC
John Prine
Old 11-21-2011, 06:20 PM   #26
r carl's Avatar
Lin , Ne
But I/we ask why?
Some people haul their firewood in a basket off the rear bumper because of the bugs and spiders.
Old 11-21-2011, 06:49 PM   #27
Wink
We prefer to carry just the bugs and spiders..DEC won't allow foreign firewood.
PFC
"Tahawus"
RLC
John Prine
Old 11-21-2011, 07:04 PM   #28
1969 27' Overlander
Well !!!......I certainly unleashed a "poop-storm" with the rear bumper mount issue, didn't I ?
A class ultra star champion airstream avion motor home eBay Watch Airstreams on eBay 0 08-18-2011 01:20 PM
A class ultra star champion airstream avion motor home eBay Watch Airstreams on eBay 0 08-09-2011 02:00 PM
A class ultra star champion airstream avion motor home eBay Watch Airstreams on eBay 0 07-29-2011 10:00 PM
Champion 73531i Generator Experiences Anyone? eberrobw Generators & Solar Power 12 07-16-2011 10:05 AM
Making a generator more quiet polarlyse Generators & Solar Power 18 03-07-2011 09:39 AM
