Old 02-03-2009, 01:33 AM   #1
2007 25' International CCD FB
Los Angeles , California
Carrying EU2000i on the trailer tongue
Does anyone stow their EU2000i on the tongue of the Airstream like the photo shows? there is just enough room there and I am contemplating strapping it down to secure it while we tow.
We tow with a GMC Savana Van so there is no external storage like a pickup truck does. I would prefer to not have to store it inside the passenger compartment just to be away form the oil and gas fumes.
I am interested knowing how everyone carry their EU2000i's while towing if you do not drive a pickup truck with external storage.
malimish is offline   Reply With Quote
Old 02-03-2009, 05:07 AM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Do a search this has been covered several times.
enter this in google."site:airforums.com EU2000i" should get you started. Do not include the quotes.
Rubber Maid makes a container which the unit fits in perfectly, you add a gasket and you have no odor. Work the search engine, check 2airishuman posts. I am leaving for work or would pull it up for you.
Check post 12 by Andy from Inland.http://www.airforums.com/forums/f48/...ting-4889.html
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 02-03-2009, 07:43 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
If you are going to do that I would definatley get a Honda cover. It is fitted.
Michelle TAC MT-0
Sarah, Snowball
Old 02-03-2009, 09:08 AM   #4
I was definitely thinking about getting a cover for it because it is a pretty snug fit between the trailer and the propane cover. One of the other issues is whether or not the battery box cover will be able to handle the weight of the generator.
Does anyone make a bracket that goes above the battery box for this application? One that is a direct bolt-on application with no other necessary mods would be very convenient. seems that there are enough airstreamers who use eu2000i for this to be a viable product in the market.
Old 02-03-2009, 10:49 AM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Malimish, welcome to the Forum.
I like the fit and hope you can work this out. I wouldn't want to have it inside the tow vehicle either, especially if there's an accident and gas spills.
I would consider whether it will damage the aluminum on the trailer or propane cover since as things flex, something will rub on something (or might). My propane cover was rubbing on a part from the Equalizer hitch and I had a small piece of rubber with a glue backing so I stuck it on the propane cover to prevent damage. It's still there after a year. How will you lock it in place?—it looks so tempting to a thief.
There are brackets for gas cans that can be mounted externally, perhaps on the back of your van. I wonder if a generator would fit in one?
Gene
Old 02-03-2009, 12:06 PM   #6
Jim Clark's Avatar
Here is the post and picture of the container look at post #4.
http://www.airforums.com/forums/f448...tor-44248.html
You can put the genset in side the container and lock it in the trailer or truck when you leave.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 02-03-2009, 07:44 PM   #7
Keymar , Maryland
I would consider whether it will damage the aluminum on the trailer or propane cover since as things flex, something will rub on something (or might). My propane cover was rubbing on a part from the Equalizer hitch and I had a small piece of rubber with a glue backing so I stuck it on the propane cover to prevent damage. It's still there after a year. How will you lock it in place?it looks so tempting to a thief.
Gene
Gene,
I will tell you that things do flex. Hitched up my "Battery box", in my case my actibrake housing, will not open. When released from the TV I can open the door without hitting the front panels.
Michelle TAC MT-0
Sarah, Snowball
Old 02-03-2009, 07:59 PM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Exclamation Never
IMHO
Would never mount it behind the tanks. I see a dented trailer and a vulnerable generator.
What we use, can store in the Burb or coach, no spills, no smells.
Name:	HONDA CONVERSION add vid pix2-3 006.jpg
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-03-2009, 08:07 PM   #9
Jim Clark's Avatar
I like the container because it hides the Generator and I carry my extra power cords and a few tools and a quart of oil in the container with the Generator. I sometimes cable the unit in the bed of my truck or to my trailer. It is a lot less conspicuous than a Generator sitting out in the open or even with a custom cover on it. Has worked great for me. It meets or exceeds the KISS specification.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 02-03-2009, 08:10 PM   #10
2005 16' International CCD
Ogden , Utah
Does your Honda generator really have gas & exhaust odors? In the winter time I keep my generators in the house in the family room so they're handy and warm (and easy to start) when the power goes out and I need them to run the furnace. I've never experienced any odors of any kind with them.
Another thought to carry it inside and contain odors is to slip it into a trash bag and tie it off - lost tech and low cost, and wouldn't take up the additional room as the storage container. Of course make sure it's cooled off well, regardless of the container you put it in.
RDM16CCD is offline   Reply With Quote
Old 02-04-2009, 04:24 AM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think you might get more noise inside the trailer if you ran the generator when it was mounted there. There might be vibration as well.
Old 02-04-2009, 05:32 AM   #12
Keymar , Maryland
I HOPE you are joking.
Michelle TAC MT-0
Sarah, Snowball
Old 02-04-2009, 05:37 AM   #13
Gainesville , Florida
The added 60 pounds on the tongue won't affect the balance of the rig? jim
Old 02-04-2009, 05:43 AM   #14
Hard to avoid them. The Honda cap seals very well, but pressure does build up in the tank and when the vent is opened for running, you do get some odor. On start-up when using the choke there can be a stronger gasoline smell as well
One of the nicest benefits of LPG is the lack of exhaust smell and lower running temp. Two nice benefits while running in it's "house".
Name:	PISECO LAKE CAMPING JULY 2008 132.jpg
PFC
RLC
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Carrying your toad!!! myoung General Motorhome Topics 13 03-26-2007 12:42 AM
trailer tongue cover? ALANSD Hitches, Couplers & Balls 5 10-06-2006 09:02 AM
trailer & tongue weight ??????? want310 Hitches, Couplers & Balls 2 01-18-2004 09:21 PM
