Old 05-23-2008, 07:07 PM   #1
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
Carrying and securing Honda Generators
I intend to mount a receiver hitch on the front of my truck with a platform carrier to carry 2 Honda 2000i generators.
MY questions is, does anyone have suggestions on how to lock the gens. to the carrier or truck? Running a chain, etc through the carrying handle is not what I want to do because it wold be to easy to cut the plastic handle. I would like to have some way to mount them permently to the carrier if possible yet be able to remove them if needed. Thanks for any ideas.
'99 25' Safari
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 05-23-2008, 07:14 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The idea I have is simple, but the execution may take a little explanation.
You can install a flat mount on the front of the truck for the generators to sit on, with a flat eye bolt extending from the bottom of the generator through the platform. You would use a flat steel bar under the platform with holes for the eyebolts to stick through, and a pair of padlocks to secure them.
Old 05-23-2008, 07:35 PM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
I used (hard to see in picture) some straps that crank to tighten - to keep our 3000i secured to the platform - so it did not shift around. I then used a bicycle lock with padlock to secure it to the TV frame - for security. Worked like a champ.
Name:	IMG_0183 (Small).JPG
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 05-23-2008, 07:37 PM   #4
nilesrob's Avatar
Marietta , Georgia
Images: 12
Please pardon the roadkill on the generator - maybe a better picture of the straps and security...
Name:	IMG_0231 (Large).JPG
The Slowsky's
WBCCI #1271
Old 05-24-2008, 08:59 AM   #5
Richardson , Texas
Images: 14
Overlander63- I thinnk I understand what you are saying but am wondering how to connect the gens. to the eyebolts? The 2000s don't have metal handles llike Nilesrob's 3000. The handles are plastic. I had also thought of some metal brackets similar to what A/S uses to hold down the battery. I like Nilesrob also but am concerned about someone just cutting the cable or lock. We were in Quartzite, Az. the past two Jan. and Feb. and stealing gens was rampant. I would put ours inside when we went to bed and that is a hassle. I would like to mount them permently enough that it will take some work to get them off in a hurry. Thanks to both of you for your input and pictures. I at least having a starting place now. Thanks again.
'99 25' Safari
'08 Chevy Duramax
Old 05-24-2008, 09:30 AM   #6
lsinclair's Avatar
2008 30' Classic
Pagosa Springs , Colorado
Make sure the airflow is not being restricted to your Duramax engine. This type of set up is apt to increase engine operating temperature.
Larry & Sandy
08 Classic 30
05 GMC K2500 Duramax
Four Courners Unit
WBCCI # 2460 AIR # 17259
lsinclair is offline   Reply With Quote
Old 05-24-2008, 10:22 AM   #7
Well Preserved
1993 21' Sovereign
Yes, I'm suggeesting running the eyebolts through the BOTTOM of the generators, rather than the handles. A thief would take a look at that, and try to find easier pickings. With the keys, you could unlock the padlocks and have the generators off the front of your truck in a couple of minutes.
Old 05-24-2008, 11:12 AM   #8
Richardson , Texas
Images: 14
Got ya! Not sure how much room insite the little gens.there is. The bolts would have to go through the plastic with mabe a small piece of f;at metal to back up the nut and make it harder to just rip them through the plastic. I will pull the covers off and take a closer look. If it is like I am picturing it, the eye bolts would stick out the bottom of the gen. and Would need to sit on something while on the ground.
'99 25' Safari
'08 Chevy Duramax
Old 05-24-2008, 06:41 PM   #9
Ottawa , ON
newbie question
Just curious what the generators are there to power: is it so that you can have hot water and A/C while camped where there is no power to connect to?
Aage
Old 05-24-2008, 11:57 PM   #10
Richardson , Texas
Images: 14
Right. My water heater is gas only. I use the gens. for recharging the battery (1) and for running the a/c and microwave. Most of our camping is primitive.
'99 25' Safari
'08 Chevy Duramax
Old 05-29-2008, 05:18 PM   #11
2005 30' Classic
Milton , Washington
Other than attaching the generator other than the front of the tow vehicle?
Kenyon is offline   Reply With Quote
Old 05-29-2008, 05:28 PM   #12
Richardson , Texas
Images: 14
Kenyon - Not sure what you are asking. Thanks
'99 25' Safari
'08 Chevy Duramax
Old 05-29-2008, 06:06 PM   #13
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I lock mine with a 6 ft motorcycle cable lock.Binetto Steel Cable Locks & Chain Locks: T-Series, P-Series, G-Series & S-Series - Binetto Gas Scooter Accessories - CBXManMotorcycles.com.
Then, I attach an alarm that activates when a pin is pulled out of it.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 05-29-2008, 06:39 PM   #14
norsea's Avatar
2008 30' Classic
On the road since 2000 , norseaodyssey.com
Locking an i3000 Honda Generator
Hi,
This may be more what you had in mind.
Name:	generator locks front view.jpg
Name:	generator locks side view.jpg
I used stainless steel eye bolts to go through the bed of my truck; ya, it's an aluminum flat bed.
Then I bought a 3' section of 1/2" round steel. I then got the locks I wanted to use; drilled holes in the rods with my drill press. I had to use a larger drill on the hole opening on one side where the shackle goes into the rod in order to get the shackle far enough past the other side of the rod to actually lock into the body of the lock.
The rods go through the pieces of metal that the rubber feet of the generator are mounted too. This allows me to adjust how tightly the generator is held down using the nuts on the eye bolts.
Yes, someone could go under the truck and remove the nuts on the eye bolts that are on the inner portion of the generator. But, the outer rod eye bolts have a large box that has tools, etc., in it directly under them. In order to remove them the box would have to be removed; not possible without the box being open.
I took off the two handles on the generator so I could use an aluminum box to keep the generator out of the weather when not in use. It wasn't necessary to do this but I wanted a smaller foot print for the box and removing the handles saved 10+ inches in the space the box takes.
Hope this helps....
We are travelers with an attitude. We get to go anywhere, anytime, and have attitudes about what we see and hear.
"Travel is fatal to bigotry, prejudice and being narrow minded."
norsea is offline   Reply With Quote
I Love my Honda EU2000i Generators panabax Generators & Solar Power 30 10-30-2016 02:10 PM
Honda vs Yamaha Generators ROBERTSUNRUS Generators & Solar Power 115 06-13-2016 09:32 AM
Why are Honda Generators quiet? JimGolden Generators & Solar Power 48 02-18-2008 05:34 AM
biodiesel for honda 2000 generators? silver suz Generators & Solar Power 34 08-07-2005 10:08 AM
Running Honda Generators in Parallel Cracker Generators & Solar Power 16 05-16-2004 06:49 PM
