Old 06-05-2008, 05:13 PM   #15
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
Nilesrob - What did you use for the corner markers? Seems like they need to be fairly stiff to keep them from bending when traveling. Thanks.
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 06-05-2008, 05:34 PM   #16
Cracker's Avatar
Pittsfield , Maine
With reference to the GMC/Chevy pickups with the Duramax, 4 wd, etc. - and especially the crew cab - beware of the capacity of the front suspension. It's marginal at best - at least for the 2003 model year! You would think that the beast could carry anything you wanted to on the front end - but I would advise weighing it first. You might be in for a big surprise! I don't have the numbers right in front of me but I recall that my truck has a reserve capacity on the front suspension of less than 400 lbs. when loaded for travel, with just my wife and I in the cab. Three additional passengers could cut into that even more.
Cracker
Cracker is offline   Reply With Quote
Old 06-05-2008, 07:45 PM   #17
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
airflow
i too would be concerned about airflow to your engine on a hot road warrior day. how feasible would it be mounting your generators on a roof rack? you could even buy one of those fenders you see some truckers use to help streamline your already slick airstream and protect your hondas from the road kill ala nilesrob's setup.
then again after you've setup camp it may look goofy driving around with a couple of genny's on the roof because theyre a hassle to take down
what would wally do!?
elbundi is offline   Reply With Quote
Old 06-05-2008, 08:13 PM   #18
Streamline Imperial
SilvrSausage's Avatar
Bellflower , California
Lightbulb
Mounting the gennys on the roof is a bad idea. First of all, they are dense enough to possibly damage the roof. Second, this will raise the center of gravity of your truck and substantially increase the risk of rollover.
I also shuddered at the sight of the large generator completely covering the most important part of the grill. That's the last thing you need when towing.
There are good reasons to have the genny at the front of the truck, though. It is secure, and away from the trailer with its (minimal) noise and fumes. A 2000, or even a pair oriented correctly, might be a better fit than that refrigerator-door-looking 3000 right in front of the radiator.
I know this idea won't work on every TV, but my 1990 Suburban has cubic YARDS of space under the hood and under the rear. The gas tank would have to be dealt with, but think how secure a generator would be there!
Only downside is the fuel economy of this big old thing, like 10 gallons per mile.
The front of the TV is a great place, as long as the radiator gets its air.
For security around camp, I have several thick, non-cheap cables and good locks, and some chain for good measure. The nice thing about cable is, it bends and ruins all but the best bolt cutters! It has kept the quads and bikes safe so far. If I had a generator with plastic handles, I would figure out a way to have a lock hoop of some kind attached to the frame, or bolted deep inside under the covers. Most eyebolts are easy to bend, open, or snap the threads. Consider using a good alloy of bar stock, and case harden it after shaping. A top notch welder can do this easily.
-SilvrSausage
It seems I love the mountains and deserts more than my friends do. I sure miss them!
1971 Streamline Imperial project "Silver Snausage", 1985 Coleman tent trailer, 1964 Little Dipper, 1975 Northwest "Proto Toyhauler", 2004 Harbor Freight folding, still seeking my Airstream.
SilvrSausage is offline   Reply With Quote
Old 06-05-2008, 10:08 PM   #19
2005 30' Classic
Milton , Washington
Thanks all for answers to my incomplete question. The problems that occur are numerous and I have already lost a trailer hitch off my truck as it was not locked and I didn't want to lose my generator. Strapping and locking are the only solutions. Thanks
Kenyon is offline   Reply With Quote
Old 06-09-2008, 01:12 PM   #20
Silvertherapy's Avatar
2008 27' International FB
Shoreacres , Texas
Generator info
I have been thinking about a pair of Honda EU200i generators hooked up together to power my 2008 27 FB Intnl CCD. I have the 15,000 btu AC. I am wondering if that gives enough power to run everything at the same time?
Silvertherapy is offline   Reply With Quote
Old 06-09-2008, 05:05 PM   #21
Crusty's Avatar
1992 34' Excella
Take a look here for some stainless steel pad eyes and other hardware that is quite a bit stronger than Homer's fare.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 06-13-2008, 11:21 AM   #22
nilesrob's Avatar
Marietta , Georgia
Images: 12
The corner posts came with the rack/tray. They are fairly sturdy and don't bend even at highway speeds. They are pretty handy though - keep you from forgetting the rack is there.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
I Love my Honda EU2000i Generators panabax Generators & Solar Power 30 10-30-2016 02:10 PM
Honda vs Yamaha Generators ROBERTSUNRUS Generators & Solar Power 115 06-13-2016 09:32 AM
Why are Honda Generators quiet? JimGolden Generators & Solar Power 48 02-18-2008 05:34 AM
biodiesel for honda 2000 generators? silver suz Generators & Solar Power 34 08-07-2005 10:08 AM
Running Honda Generators in Parallel Cracker Generators & Solar Power 16 05-16-2004 06:49 PM
