Old 11-29-2014, 01:44 AM   #1
benicia , California
Cant figure out how to connect my AS to power
I admit that I haven't read the manual as I have not received it yet. I do have the trailer now and would like to take it out next weekend. Hopefully the owners manual will arrive by then but in the meantime, I have a few real newbie questions.
How do I connect a generator to my AS? My AS has two male connectors - one on street side and the other behind the propane tanks. Each connector has three flat blades that probably takes locking plugs? Regardless, my new generator only has 120 VAC outlets. There are no cords that came with my AS so where can I buy such a cord? I intend to go to Camping World tomorrow. Would they carry that? Does the cord have a name?
Thanks for your help.
cantdrv55 is offline   Reply With Quote
Old 11-29-2014, 02:19 AM   #2
ottawa (greely) , Ontario
We need to know what year, model ,and length of airstream before we can help you.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 11-29-2014, 02:34 AM   #3
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Go online to Airstream and you should be able to download the manual. If it is a relatively new model with front connection you require 30 Amp service and any RV store can help you get the correct cord by photographing the connection points on trailer and generator and showing these to the clerk at Camping World.
I am curious about why no cords were supplied and why no manual.....if you do not have the sewer and water connection hoses these are more essentials.
If you give a Zip code maybe a forum member can PM you and possibly come over and help you out.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 11-29-2014, 04:21 AM   #4
Thank you do far for the responses.
I have a 2011 28' a Flying Cloud and live at zip 94510.
I bought the trailer used from a reseller. For some reason, the cords and manual was removed. The shop is sending me the manual which they forgot to put back in the trailer at time of sale.
Old 11-29-2014, 05:04 AM   #5
Ok so it sounds like the person that sold you the trailer didn't give you a power cord, on the street side (as you mentioned earlier) there is a grey door with a label indicating were your power cord 120 volt should be plugged in , if you flip open the door you will see the type of connection plug you will need ,first I would contact the person that sold you the trailer and ask him for the power cord as these are not cheap, once you get the power cord you simply open the door line up the pins push in and turn then tighten the power cord lock (threaded part) then plug the power cord into power outlet you maybe will need a adapter to match the plug outlet for power source , and depending on your generator ( you never mentioned what brand and model ) most rv dealers have these adapters, as for if you need to buy a power cord I would get one from a airstream dealer, now you mentioned a second plug up front behind the propane bottles ,I'm not familiar with this trailer model ,I looked at some pictures on airstream site and it looks like this trailer has a second a.c. Plug up front behind propane bottles , not sure if you use both power cords at same time due to power cord max allowed power through cord ( I'm sure this trailer has two a.c. Units)or if you can use either power plug due to location of supplied power from campground ,either way you need a power cord(s)and adapters to match your generator plug or campground plug
Old 11-29-2014, 06:10 AM   #6
Correction the second plug behind the propane bottles looks like a remote generator hook up,plug
Old 11-29-2014, 07:32 AM   #7
Msmoto's Avatar
2007 25' Safari
Images: 135
Well, maybe someone in the Oakland area can help you out. Look into the local unit of the WBCCI and they are usually pretty friendly and can be helpful.
AIR #31871 K4MTL
Old 11-29-2014, 07:40 AM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Research before you go to Camping World. There are many types of cords and adaptors in their display.
Old 11-29-2014, 08:07 AM   #9
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If you are going to go to Camping World, or any other source, for your cord purchase take the trailer along and they will help you to make sure you get what you need.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-29-2014, 03:58 PM   #10
2014 23' Flying Cloud
Rhinebeck , New York
Thumbs up Connecting a generator to an Airstream
You will need a special cable that allows you to connect the generator. Any camping oriented store such as Camping World will have them. The cable will have a standard grounded 110 volt male end for the generator and at the other end a port for the three flat blades the Airstream requires. When I purchased my Honda 3000 generator of late there were such cables hanging beside them!☺️
Adam Geuss is offline   Reply With Quote
Old 11-29-2014, 03:59 PM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The cord should have came with the trailer, they shorted you.You probably have a 30 amp service cord and you will need an adaptor to go down to 15 amp to use your generator...
Old 11-29-2014, 04:52 PM   #12
daveswenson's Avatar
2012 28' International
Issaquah , Washington
You need one of these.
30 Amp RV Cordset with Fault Smart LED - 25' - Furrion F30R25-SB - Electrical Cords - Camping World
And one of these.
30 Amp RV Female to 15 Amp Male Plug Pigtail Adapter - Furrion IP311R-SB - Electrical Adapters - Camping World
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 11-29-2014, 11:56 PM   #13
Thanks everyone. I was definitely shorted the power cord. I went to my local Airstream dealer and found the cord I need but did not buy it as it was $130!! I called the reseller and he promised to mail me the cord on Monday.
Dave, thanks for the links. If the reseller doesn't come through, at least I know Camping World carries it and for $50 cheaper!
Old 11-30-2014, 12:09 AM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Look in the BUMPER! The lid lifts up. Most people store the cord there.
Welcome to the Forums and to Airstream ownership.
Do try to meet forum members and/or WBCCI members - there's a lot to learn and there are wonderful people who would cheerfully spend an afternoon helping you to maximize your enjoyment (and avoid a few painful mistakes) with your Airstream.
Paula
What is this. Cant figure it out! 66aviont24 Repairing/Replacing Floor &/or Frame 1 10-23-2014 08:48 PM
Cant get hinge pin out kevinkatz Doors & Locks 4 07-17-2009 06:16 AM
New airstreamer..How I connect the power cord to test the appliances and AC yam777 Member Introductions 5 08-21-2006 08:06 PM
Cant get frige out of 65 Tradewind. lrichards Refrigerators 2 07-19-2005 06:13 AM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 05:41 AM
