Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 10-01-2005, 11:41 PM   #1
Raptorrider2001
Raptorrider2001's Avatar
Profile:  Richardson , Texas
Images: 14
Can you link a EU2000i with a EU1000i?
I am sure this has probably been beat to death a gazillion times, but I can't seem to find it in a search. Can you link a EU2000i with a EU1000i just as if you were connecting 2-EU2000is? I have been running my 11K a/c on my 1999 25' Safari for 2 1/2 years. It is very marginal and would like to have that little extra I could get from the 1000. Thanks
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 10-02-2005, 06:29 AM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Short answer, NO. According to Honda you can link 2 EU2000i's together. There is not that much of a price difference between a 1000 and 2000. I do not think you can even link 2 1000's together or even 2 3000's.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-02-2005, 09:25 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Honda has cable kits for the 1000, 2000 and 3000 models. You can not mix and match, the two units must be the same.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-02-2005, 12:38 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
To explain, ....
If you try to hook up a 1000 and a 2000, the lower rated generator will cut out, because, of course, it is rated lower, and will protect itself when it see amps and watts go over its rating, leaving the larger unit to shoulder the burden by itself.
You can't even hook up a horse and a mule for the same reason.
Change is inevitable, except from a vending machine
AIR#2611
Old 01-28-2008, 06:59 PM   #5
Kajtek1
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
It is the same issue like using 100% bio-diesel, towing with close to 100% capacity, or towing car with 4 wheels down.
Manufacturers don't recommend it because there is no money in it for them, so why take a risk? Lot of owners do it successfully regardless.
Lot of good technical advice on the subject on rv.net forum.
Kajtek1 is offline   Reply With Quote
Old 01-28-2008, 07:11 PM   #6
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
No. You need two 2000s. The 1000 will try to keep up with the 2000 and fail.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 01-28-2008, 08:03 PM   #7
overlander63
Images: 58
The generators will not share proportions of the load. If you have a 2000 watt load, the 1000 will be going flat-out, and the 2000 will be loafing at half-load. if you exceed 2000 watts, the 1000 will overload and shut down to protect itself, quickly followed by the suddenly-overloaded 2000.
This is the same reason you can't (or shouldn't) use a pair of battery chargers on a single load (battery), the lesser-capacity one will be the weak link.
AIR#2611
Old 01-28-2008, 08:22 PM   #8
elbundi
elbundi's Avatar
Profile:  Leesburg , Georgia
rewire and dedicate one genny (2k) to your ac and let the other take care of the rest
elbundi is offline   Reply With Quote
Old 01-29-2008, 08:19 AM   #9
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
I actually Googled the topic and waded through some threads on RvNet forum and found some people who have claimed, what I would consider to be rather limited success, at linking two different generators by using some 'homemade' cables. I surely didn't see anything that would compell me to conduct experiments on any kind of generators, or my Airstream. I'd spend the extra dime and do it right.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 01-29-2008, 10:20 AM   #10
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 33
Nothing in that thread stated that posters were qualified to be making such modifications or claims. If anything, all I saw was "It works, but I'm not sure why".
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 01-29-2008, 10:33 AM   #11
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Suggestion....
Let's keep it constructive.
Fyrzowt is offline   Reply With Quote
Old 01-29-2008, 12:52 PM   #12
Pick
Pick's Avatar
Images: 36
The bottom line is "Not recommended or approved by the manufacturer". Use at your own risk and don't come crying, when you burn something up.
Lots of Hot Sauce!
Air # 283
Old 01-29-2008, 02:56 PM   #13
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
For the sake of discussion—
If I had a 1000eui and a 2000eui and the equipment to place a variable load on each unit, I would record output voltage verses current on each unit from no-load to full load. Then I would test under 2 assumptions (I know the definition of assumption )
1) Hondas have been shown to frequency match between two different size generators and
2) the big guess… Inverter technology will react to loads similar to conventional low tech generators.
For example – at a known load, a low tech generator will output a known output voltage, no load on my coleman is 130 volts, full load is 115 v. (pretty crappy)
Let’s say the 2000eui put out 800 w at 124 volts and the 1000eui at the same voltage is 300 watts. Testing the two tied together at 1100 watts should be 124 volts.( That would be the test for the theory )
Where things fall apart is if the curves are miss-matched, such as a 2000 at max load is 120 volts and the 1000 is 122 volts. The 1000 will trip out at 121 volts and the 2000 never got fully loaded.
This is all based on how I understand the inverter technology units work but, then again, I don't have one!
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 01-29-2008, 05:14 PM   #14
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Hmmm...when the manual says not to parallel unlike models or types of generators, I think it's probably prudent to heed the instructions. Just because some folks have done it and it seems to work "just fine" for them doesn't mean that they don't run a heavy risk of damaging appliances, electical systems or generators...or that one day or after extended use they won't find out why it's not wise. Just my opinion, but then I tend to follow instructions when operating equipment.
TB
TB & Greg...and The Girls, Annie & Sadie...and Homer the Tortoise
Members of the Four Corners Unit
NEW! Visit AZBambi Décors: http://www.tbrich.com/azbambi/decors.html
Visit our Travel Log: http://www.tbrich.com/azbambi/trips.html
TBRich is online now   Reply With Quote
Profile photo link bug? Moonshot Forum How-To's & Support 2 03-10-2005 02:55 PM
Interesting link GMC coop ALANSD Link Archive 8 03-14-2002 01:40 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
