Old 03-02-2016, 03:37 PM   #1
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Can I power my 25FB with a single eu2000is
I am about to purchase a single Honda eu2000is and would like to plug it directly into my generator plug on the front of my trailer. I have 30amp service. I won't run the AC and will be careful to have everything else off if I run the microwave. I was reading up on Generator ground bonding and I am not clear on whether I need to do something to make this method work for me or if this is required only for running 2 generators. I have the automatic transfer switch and have hardwired a Progressive industries surge protector before the transfer switch. If I make a plug to go from the generator duplex receptacle to the generator input of the trailer will that work or do I have to do something else?
TRIPPPIN is offline   Reply With Quote
Old 03-02-2016, 04:52 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Get the Companion instead of the straight 2000is. It already has a 30 amp connection, and you will only need the commercial to RV adapter. Then, if you decide later you want to get a second one, you can get the 2000is, and parallel it to run the a/c.
Old 03-02-2016, 05:07 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You don't need the 30 amp connection just use an adapter and you got 15 amp, enjoy your honda....
Old 03-02-2016, 05:16 PM   #4
TRIPPPIN's Avatar
Originally Posted by overlander63 View Post
Get the Companion instead of the straight 2000is. It already has a 30 amp connection, and you will only need the commercial to RV adapter. Then, if you decide later you want to get a second one, you can get the 2000is, and parallel it.
For some reason Honda does nor sell the companion here in Canada but says you can parallel the regular Eu2000i. Maybe has to do with slightly different electrical codes here?
Old 03-02-2016, 05:18 PM   #5
Well Preserved
1993 21' Sovereign
It may. I know Canadian Airstreams are wired slightly differently. I was suggesting it because the "official" Honda parallel kit is significantly more $$$ than the simple cable kit to use the companion with a 2000is.
Old 03-02-2016, 05:58 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Per the NEC, any distinct AC power source requires a single neutral to ground (N-G) bond in the system. This bond is already in place in a residential or RV park electrical system, in any quality inverter/charger that has an internal transfer switching system, but NOT in a portable generator. The simplest way to provide the N-G bond is to use a 20 amp plug from a big box or hardware store, connect a jumper from the neutral lug to the ground lug and simple plug it in to the generator's available 120VAC 15 or 20 amp receptical.
You should also provide a solid ground connection from the generator's frame to the earth, as in a grounding rod or connection to an existing copper water pipe, but that is another topic.
Old 03-02-2016, 07:37 PM   #7
Well Preserved
1993 21' Sovereign
The 2000 series, and probably all the Hondas, have a screw-down connection for a ground wire. It is designated by the arrow/squiggly line icon signifying a ground.
Old 03-03-2016, 07:14 AM   #8
TRIPPPIN's Avatar
Thanks Lewster, I already have a 30A-125V female plug to connect to the trailer and a heavy duty moulded 20A plug and 10' cord (removed from an new air compressor) that I was planning on using. Will it still work the same way if I made the bond in the 30A plug? The 30A plug has the ability to have 2 wires under each screw plate for a secure contact. That leaves me the extra outlet on the Honda eu2000i for something else or is it only possible to do the bond at the generator outlet directly.
ps I read many of your comments on this website and appreciate your dedication to helping us.
Old 03-03-2016, 07:41 AM   #9
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
Progressive Industries sells a generator bonding plug if you are uncomfortable making one yourself. You can make one much cheaper than this yourself, but this takes the guesswork out of it: http://www.progressiveindustries.net...tor-plug/c1mwy
Echelon73 is offline   Reply With Quote
Old 03-03-2016, 07:49 AM   #10
1986 31' Sovereign
Miami , Florida
As to your original question: Your 2000i will cheerfully power everything in your trailer without breaking much of a sweat. However, do not plan on running the microwave while using your hair dryer...
While rated at 2000 watts, it actually delivers 1600 watts continuously which is a skosh less than 14 amps..
Enjoy!
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-03-2016, 08:02 AM   #11
TRIPPPIN's Avatar
Thank you. I can make one easily but my latest question is; Is it best to have it bonded right at the generator (with that bonded plug) or can l bond it - in the cord to the trailer, I am making up. Since no one seems to have done it that way I thought I would verify so I don't have any problems with this new setup for me. I know the plug right on the generator is easiest but if I can have an extra outlet available on the generator it could be handy.
Old 03-03-2016, 09:33 AM   #12
r carl's Avatar
Lin , Ne
Or you can just buy the Industrial EU2000 that has a ground fault receptacles.
Old 03-03-2016, 10:09 AM   #13
2012 25' FB Flying Cloud
Parker , Colorado
So are we saying that in order to use an inverter generator we NEED to use this bonded plug, if we are plugging directly into the trailer? I've never heard of this before. I always just plug in without one.
What could happen? Not sure if I understand
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 03-03-2016, 10:50 AM   #14
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
yes, ineteresting
twolanehwy is offline   Reply With Quote
Convert Frt Vent to Power on 2007 25FB 2dabeach Electrical - Systems, Generators, Batteries & Solar 3 10-09-2014 11:29 PM
2014 25FB FC Pioneer radio power off? btlayton 2009-2015 Flying Cloud 44 07-29-2014 10:52 AM
If I dont need a battery power can dispense with univolt? can I dispense fast fredy Batteries, Univolts, Converters & Inverters 7 04-14-2014 03:46 PM
The Can Can Can travelfables Member Introductions 3 02-01-2014 01:56 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
