Old 01-16-2013, 09:43 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Breeze Extended Run Tank (dual feed)
I am thinking about spending the ~ $170 for a Bergs extended run dual feed fuel tank for my Honda EU2000 set.
Of course I have seen many posts on extended run tanks, etc. But I am looking for specific experience and feedback with this Berg dual setup. (function, quality, durability, value, . . . )
Thanks in advance,
Alan
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 01-21-2013, 08:23 PM   #2
My only concern is that the fuel caps are metal. Some extended run kits use CNC machined aluminum caps, others use plastic caps.
After a while, the metal ones can strip, while the plastic ones don't have that issue.
mlts22 is offline   Reply With Quote
Old 01-21-2013, 08:35 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I have one. It works great.
The caps on the one shown are machined aluminum. They will be no trouble, ever.
I switched the quick-couplers around so the hoses stay with the caps. That way, the tank has no hoses to contend with. I bought generator covers off of Ebay with pockets to hold the hoses and caps.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-21-2013, 08:43 PM   #4
Alphonse's Avatar
Lower Alabama , USA
JD
I assume you can run one generator without the companion hooked up if you want??
Have you had any issues with priming the fuel lines? (i. e. Needing a primer bulb)
Alan
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 01-21-2013, 08:50 PM   #5
jdalrymple's Avatar
Jay , Oklahoma
Yes, the quick-couplers have spring loaded valves and close when no hose is connected.
I do have the twin Honda 2000s. They have fuel pumps, so no need to worry with priming.
Just start with the on-board tanks full. The gensets will pull fuel from the big tank until it is empty.
JD
Jeff & Cindy
'91 350 LE MH
Old 01-22-2013, 02:47 AM   #6
ctdair's Avatar
I have the same set up and no issues with using it.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 02-03-2013, 11:47 AM   #7
Alphonse's Avatar
Lower Alabama , USA
Thanks for the feedback JD and ctdair.
I bought the tank and dual set-up from Wise. It came very quickly, well packaged, and I like what I see with the components. All are pieces and parts are of good quality and the dry disconnects on the hoses will come in mighty handy. The fuel hose is Parker and is first class and flexible. The anodized aluminum caps are very nice and well gasketed.
I am betting that this set-up will perform to my expectations with no problems.
Alan
Air #64439
TAC AL-8
2018 Canopenian
