Old 08-31-2010, 12:17 PM   #1
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
Breaker, Breaker!!
My GFIC 20 amp breaker is tripping and won't stay on. I've checked the outside plug and unplugged everything inside the trailer. I still have power to the AC and microwave from the other 2 breakers just not the refer, bath and kitchen receptacles. I replaced the breaker with a new G.E. breaker with GFIC to no avail. It would seem to me like I must have a short in that line. Any thoughts? We will be in Hondo, Texas in 3 weeks and wondered if anyone has any experience with the Airstream dealer in San Antonio?
Bing-Bing is offline   Reply With Quote
Old 08-31-2010, 01:47 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The usual cause is a short between neutral and ground. Best way to troubleshoot is to disconnect and lock out shore power and any inverter or generator you may have, then use an ohmmeter to measure resistance between neutral and ground for the 20A circuit. You can isolate it by disconnecting the neutral at various points in the wiring loop around the trailer. It's a nuisance to do but there's no better way.
Old 08-31-2010, 02:04 PM   #3
richinny's Avatar
2011 34' Classic
i'd also check for moisture in the outside outlet. prop it open or hair dryer to dry it out. the fridge outlet can do that too but i think it is on a different breaker. i forget which breaker the converter is on but you can hit the cutoff switch to test that.
Ricky
Old 09-01-2010, 08:20 AM   #4
Bing-Bing's Avatar
1994 34' Excella
Ricky, you may be right about the outside outlet as it was a little bit wet after the rainstorm we had. I tried to take the plate off the kitchen receptacle thinking it was the culprit and found I couldn't get the whole "box" out of the hole in the wall. So just for fun I popped the breaker on and it stayed on and has worked all night. So it was either the wet outside receptacle or pulling on the kitchen receptacle fixed the problem. Thanks for the troubleshooting advice Jammer I'll use that in the future.
Old 09-01-2010, 08:24 AM   #5
Bing-Bing's Avatar
1994 34' Excella
By the way does anyone know how to get the receptacle box out of the wall???
Old 09-01-2010, 03:27 PM   #6
richinny's Avatar
2011 34' Classic
i'm glad it is working. i read about the moisture issue in a thread here :-)
Ricky
Old 09-23-2010, 07:56 AM   #7
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
Gfci
I have recently had a similar problem. When using an inverter, a 2000watt unit to supply power...the GFCI breaker trips...it seem to be connected with heat around the breaker box as if i circulate air to cool area it does not trip breaker...any thoughts???
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 09-23-2010, 08:18 AM   #8
Islander
gfci again
what are the pros and cons of replacing the gfci breaker with just a standard breaker....it can be done...???
Kingfisher24
WBCCI 2541
4CU
Old 09-23-2010, 08:18 AM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I just saw in Consumer Reports that there has been a significant recall of circuit breakers. Big brand types....check you home and Airstream.
Old 09-23-2010, 09:18 AM   #10
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
hmm,
pros - it's less expensive by $30, more or less.
cons - possible electrocution, and possible permanent injuries, or death.
I think I'd spend the $$.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 09-23-2010, 09:28 AM   #11
1977 Argosy 24
Milltown , Wisconsin
Not to hijack but I have a question. If I put a 110 adapter on my 30 amp RV plug it will always trip a 110 GFI shore power outlet. Even with everything off in the trailer. Is this normal?
ventport is offline   Reply With Quote
Old 09-23-2010, 12:55 PM   #12
Islander
gfci
electrocution is possible anytime you mess with electricty,...a GFCI is a government mandated device to keep you from doing what a prudent person woould not do in the first place....
Kingfisher24
WBCCI 2541
4CU
Old 09-23-2010, 01:37 PM   #13
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
A GFI circuit is an assumptive form of protection.
Circuitry in the GFI device constantly measures current flowing in both the hot and neutral wires of an AC circuit.
If there is less current flowing on the neutral wire, the GFI device assumes something other than what is suppose to be using the electricity is shorting the missing amount of current to ground and breaks the circuit. In theory the unknown transporter of electricity is you.
The case above is not so sinister; the carrier of the missing electrons was simply water (or more correctly, the minerals in the water) in the affected power outlet.
Removing a GFI device solves a pain the butt when it is not you getting shocked.
But, might be a pain the butt when you are the one causing the short….
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-23-2010, 02:23 PM   #14
2005 19' Safari
GLENDALE , AZ
Ventport, this doesn't sound normal to me. I'd check this with a different adapter to see if the first adapter is defective. If the second one does the same thing, I'd worry about something wrong in the wiring in your trailer or home outlet.
breaker keeps trippin' happypill Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:49 AM
Record Breaker Air2Go Our Community 0 05-31-2009 01:20 PM
Breaker? Can't find it. TCM1 Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-07-2008 10:47 AM
breaker? air66stream Lights - Interior & Exterior 1 09-10-2007 09:46 PM
a/c tripping breaker? rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 13 08-01-2006 02:59 PM
