Old 07-16-2007, 10:45 PM   #29
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by memartinde
With the integrated inverter of the hondas and yamahas I envision a "pseudo-hybrid" solution:
A lot of RVs have inverters aboard to provide AC energy while boondocking on 12V DC. Modern inverters (some at least) have the potential to "boost" an existing grid power..
sooo
The genset is running (e.g. a convieniently small honda 2000) the microwave and maybe some small lights - then the AC kick in and starts. The start up current is what overloads the little honda - but the onboard inverter (battery powered) in the RV synchs to the honda's unit - et voilá: a small gen can run a relativly big load - or in other words:
The need for drastically oversizing the gen-set just for that fraction of a second when ACs kick in with their big start-up current would be gone / reduced.
best of it:
one would not buy anything new/extra - just some smarter firmware on the inverter (at least if it is a true sine type) would to the trick.
Any electronics gurus tried this before - could not find anything similar so far as a product...
M
The Yamaha EF3000iSB already uses this technology to provide a 'boost' for motor (air conditioner) starting by utilizing the gen's battery thru the inverter for a boost in starting amperage.
Old 10-27-2009, 07:01 PM   #30
San Antonio , Texas
Do any of you guys have an opinion on Onan propane generators? Are they as reliable as the Hondas?
ppkfink is offline   Reply With Quote
tow cars Cruiser Tow Vehicles 38 10-30-2003 01:58 PM
Brakes good enough? Jabba Brakes & Brake Controllers 7 10-14-2002 03:43 PM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
Too hot but had a good time suekozin On The Road... 11 07-20-2002 02:45 AM
